Need Help T1 Bars
Old 09-22-2008, 05:01 PM
PA Z06
PA Z06's Avatar
Default Need Help T1 Bars
Ok I have read every possible T1 sway bar thread. I have heard everything from John saying he has never heard a squeak or rattle in over 55k miles, to Tom saying it will rattle your teeth out, to people saying I should lock tight the bolts.
Anyone have any install tips and or suggestions before I put them on this weekend.
I bought a set of used bars and LG quiet end links, so hopefully that will solve some of the usual noise problems.
Thanks Nando
Old 09-22-2008, 05:10 PM
95jersey
95jersey's Avatar
Thanks Nando
It's the endlinks, not the bars. I had the T1 endlinks on my last car and they did make a ton of noise. I use the quiet endlinks on my new car and hear next to nothing. Maybe a slight creak or crack here or there, but nothing that would worry running them on the street.
Old 09-22-2008, 06:07 PM
Rob's 73
Rob's 73's Avatar
Grease the bushings. I had to shim my front bushing clamps to quiet them down. It might only be a problem until they get broken in. I have next to no noise now with solid endlinks. 3,000 miles or so. No matter what, you will love how flat your car will feel.
tigertank
tigertank's Avatar
just put them on mine easy done with a lift about and hour and a half so far no noise that cany handle BUT BIG BIG improvent over stock u will like them
Old 09-22-2008, 06:24 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
how does an endlink make noise?
Old 09-22-2008, 06:37 PM
95jersey
95jersey's Avatar
Ask LG, he makes quiet endlinks for some reason.
Old 09-22-2008, 07:11 PM
PA Z06
PA Z06's Avatar
Thanks guys for all the input on the endlinks, Im looking forward to giving them a try in Oct at Summit point.
Old 09-22-2008, 07:19 PM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
The squeek is definitely coming from the adjustable metal endlinks. I have the T1 sway bars and tried the Hotchkis Adjustable End Links - very noisey no matter how much they were lubricated or tighted. I replaced them with the GM non-adjustable metal end links - no noise. However, I haven't tried the LG "Quiet" Adjustable End Links. Good luck - sounds like a good combo.
Old 09-22-2008, 08:10 PM
John Shiels
I don't need any and mine never made noise. What free play is in an endlink to make the noise?
Old 09-22-2008, 08:12 PM
John Shiels
I have been spraying mine with PB Blaster once in a while for years.
Old 09-23-2008, 02:06 AM
Last C5
Last C5's Avatar
Hmmmmmm????? I have the exact same Hotchkis set up and they don't make a sound.
Old 09-23-2008, 07:28 AM
John Shiels
probably bushing making a noise as it is squeezed to tight or lack of lube. Not that much movement in a endlink to make noise from rotating.
Old 09-23-2008, 12:22 PM
FasterIsBetter
FasterIsBetter's Avatar
I installed the T1 bars this summer, and I have no problem with them. They do stiffen up the suspension a lot, but that's what I wanted. Really reduced body roll a lot. The only problem I have, occasionally, is hitting a bump, I'll get a little knocking sound, but think that may be the exhaust hitting something, not the bars.
Old 09-23-2008, 12:24 PM
PA Z06
PA Z06's Avatar
thanks for all the comments, i guess I will lube the hell out of everything.
Old 09-23-2008, 12:31 PM
John Shiels
look on the bar and see if it is hitting the a-arm. Make sure it is centered and can slide side to side and rubber isolators are not crushed.
Old 09-23-2008, 12:40 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Shims (washers) under the clamps are a very good thing. The factory clamps don't have the room to clamp a huge bar and the bushings. A couple washers under the clamp makes the bar "free" in the bushing.
Randy
Old 09-23-2008, 04:09 PM
redtopz
redtopz's Avatar
Randy
And be careful re-torquing the bolts because they are easy to cross thread. I would use some loc-tite on all the bolts and nuts to keep them from backing out. Also make sure you use synthetic lube or grease. Regular grease will harden real quick and seize up. I also suggest you keep the rear bar on the softest setting (outside hole) to reduce oversteer.
To Need Help T1 Bars
Old 09-23-2008, 04:42 PM
City Goat
City Goat's Avatar
Newb question...
Can I run the T1 bars on an otherwise completely stock (aside from tires/brakes) C5Z suspension? Stock endlinks and all?
Any issues with that setup?
Old 09-23-2008, 04:49 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I have T1s on my silver '98... that thing handles like a *****
Old 09-23-2008, 04:52 PM
John Shiels
Randy
DRM told me that 8 years ago when I was putting them on I said this don't fit . You need to check your bushing for wear also.
Quick Reply: Need Help T1 Bars
