engine pad
Old Dec 28, 2006 | 09:04 PM
vetarun's Avatar
vetarun
Default engine pad
I have the original block and it is at the machine shop getting hot tanked and fluxed. It had been machined prior to me getting it and i just wanted to make sure it was right. I asked them about restamping the pad. He said I would be better off contacting a company out of Atlanta who sells you the proper sized numbers in a row so you can restamp it with one blow instead of having missaligned numbers and letters. Anybody have the company contact info?
Old Dec 28, 2006 | 09:42 PM
win1876's Avatar
win1876
I have seen them advertised in Hemmings in the Corvette section. I think there is a place in Wisconsin that rents the gang holder and numbers. Engines Limited
Old Dec 29, 2006 | 12:43 AM
Seaside63's Avatar
Seaside63
It's not only the stamping but also the machined surface that people are looking at. If it's been machined you're going to have to get the surface "re-broached" to have an original look.
And then you'll have to be very careful to make sure the new stampings look proper for the time your engine would have been assembled.
It's all very sophisticated now. There are guys with pictures of thousands of factory stampings and they'll find cars made on the same day as yours and engines assembled the same day to make sure everything lines up.
Unless a restamping is done by an expert (only a couple in the country) then almost anyone will be able to detect that it was redone.
If you kept pictures of the original stampings before they were ground off that would help a lot.
In the end it might not be worth the effort and expense.
Old Dec 29, 2006 | 06:55 AM
a560156's Avatar
a560156
Why do you feel you need to stamp it?
Old Dec 29, 2006 | 08:31 AM
ctjackster's Avatar
ctjackster
How do you know it's the "orginal block"?
all very true
the company identified by win1876 is one such "expert" (just ask some of the folks on this forum who shall go nameless for now) but you'd want the pad properly "broached-up" by them too, a properly-done restamp on a bad-looking pad will get you nowhere, and won't fool most folks these days when you try to pass off your "creation".
Old Dec 29, 2006 | 10:34 AM
Corbrastang's Avatar
Corbrastang
Classic Engine Company is the name of the place in Wisconsin.
However, just know that your pad will never be the same height as it once was an expert will most likely be able to tell that it is a restamp. However, with that said, i have seen many pads that i would have called fake, but were actually 100 percent correct-crooked numbers, deep deep broach marks, etc
Old Dec 29, 2006 | 10:42 AM
Kensmith's Avatar
Kensmith
What about us guys who have a correct motor, correct dates, not Vin numbers matching that are re-building the motor and do not care about broach marks or trying to pass the motor off as NUMBERS MATCHING but just correct and would like a original looking stamp on the pad? Not trying to cover anything up, just going for period correct and original looking. Still would want a clean looking stamp and not something home made or Bubba looking.
Old Dec 29, 2006 | 11:03 AM
ctjackster's Avatar
ctjackster
and what happens when this car changes hands after your ownership, and then changes hands again? (You should see my title history if this sounds odd to you, these cars get passed around). Your honest disclosure of "just restamped for my own pleasure, it's not really the original motor" gets lost, and another restamped car is out there in the mix . . . . .
Old Dec 29, 2006 | 12:38 PM
Seaside63's Avatar
Seaside63
If you're gonna do it then do it right. The only thing that won't look bubba is to get it properly rebroached and correctly stamped. Anything less is easily spotted and I would think embarrassing.
What's that old saying, "Go Big or Go Home" ???
Or for fun, just punch out your numbers on a Dymo label maker and stick 'em on the pad !
Old Dec 29, 2006 | 12:49 PM
Mr D.'s Avatar
Mr D.
Ken I'm with you on this one. If someone down the road claims otherwise that just one of the pit falls of the hobby.
And yes this is a hobby to 95% of Corvette owners.
Old Dec 29, 2006 | 01:04 PM
Kensmith's Avatar
Kensmith
This is what I don't understand. Are you saying because I want a correct 327/365 motor with correct date castings that this car originally came with, I should make it look like it is the original motor and if I ever sold it, nobody would know the difference? That is not what my thoughts were. I just want what the car should have and as close as possible to being correct without fooling anyone but looking correct. If I had the broach marks, then I feel like I am trying to say this is a original matching numbers motor that was in the car when built. If I leave the pad clean and stamp it with correct numbers, I obviously would know along with everyone else this is a re-stamp done correctly and a correct motor for the vehicle but not the original motor. So why would that be embarrassing? It's no different than replacing broken/damaged parts that were not on the car originally. This is why I won't join NCRS either. All I want is to make the car like it was in 1965 with what is available at semi reasonable prices.
Old Dec 29, 2006 | 07:47 PM
Loren Smith's Avatar
Loren Smith
You can buy the stamps and gang holders from Columbia or Schmidt Marking, and go into the restamping business for yourself!
http://columbiamt.com/Hand%20Tools/H...w_to_order.htm
http://www.gtschmidt.com/typeholders/hand/index.html
Old Dec 29, 2006 | 08:24 PM
Kensmith's Avatar
Kensmith
Good information as it looks like you can get correct size stamps made. Don't think I would want to go into business but it would be easier to stamp a fresh pad than sending the motor cross country to get it stamped!
Old Dec 29, 2006 | 08:41 PM
ctjackster's Avatar
ctjackster
If you are so into having a correct looking stamp pad, buy a 327 from a C2 that bears a perfect, original stamp - just won't match your VIN, but anyone casually looking at your pad won't know that.
Or stamp the pad to say something fun, like "VIN GOES HERE" or something . . . .
but for God sakes don't put another fake restamp into circulation inside a C2 (ok, that last part was my own stupid opinion, sorry)
Old Dec 29, 2006 | 09:29 PM
a560156's Avatar
a560156
Loren, the fonts and characters on these stamp sets may, in some cases, appear correct but a judge will spot the difference right away.
Old Dec 29, 2006 | 09:33 PM
zim64's Avatar
zim64
My NOM Pad has "f#@k off" stamped on it, with cheap stamp set. I think they'll get the idea if they're looking.
Old Dec 29, 2006 | 09:38 PM
a560156's Avatar
a560156
Mr. D I have to disagree with you on this one and agree with Ctjackster.
You simply cannot control who buys/sells your car after you no longer own it. Ctjackster is right, these cars get flipped and passed around and five years from now someone is going to be selling an "orignial drivetrain" car to an uninformed buyer. That buyer is going to get screwed, period. So, yes it is a pitfall, but one we are trying to eliminate. How would you feel if you were that buyer?
Have you watched Barrett Jackson? This stopped being a "hobby" a long time ago. There is BIG money involved here and that attracts the "sharks". Unknowing buyers are shark bait.
To engine pad
Old Dec 29, 2006 | 09:42 PM
a560156's Avatar
a560156
Reminds me of Rodney Dangerfield's line that he was going to put on his tombstone "What the F*** are you looking at?"
Old Dec 30, 2006 | 06:00 AM
crw41's Avatar
crw41
Look at "The Last Stingray"
The reality is that this car is worth more money as a "numbers matching motor" car than not.
A good analogy would be the following.
Take 2 women:
- each has the following options:
impressive T&A
upgrades of fiscal responsibilty and intelligence
gymnast capabilties
both natural black haired women
Consider blonde hair to be the equivalent of "matching numbers." It seems that more men prefer the blonde - even though they know it's fake. Do the masses seem to care - NO. It's market driven.
A fake #'s matching stamp pad is worth more than no stampad at all - that's the reality.
At BJ (standing for Barret Jackson, no pun intended) you can get both a matching numbers car and a blonde - chances are you'll overpay for both. But, with a few shots and beers - nobody seems to care and they all seem to be quite content.
Old Dec 30, 2006 | 06:49 AM
a560156's Avatar
a560156
Take 2 women:
impressive T&A
gymnast capabilties
I am looking for the rarest options:
RPOClean
RPOCook
