cannot remove distributor
Old Feb 1, 2017 | 02:08 PM
  #101
GTOguy's Avatar
GTOguy
I like Lars' idea. I would not pull it apart. And roll pins are hard. It seems that the distributor body DOES rotate, as opposed to what was stated originally, and in that case, is not hung up on the intake. The obstruction has to be lower than the gear (roll pin) since the gear can not be lifted up and out of mesh with the cam gear. I have never seen a roll pin back out of a distributor gear/shaft, but there's always a first time. I like the idea of slowly rotating the engine by degrees and trying to lift it out by trial and error. Again, no way would I pull the oil pan and go that route. I'd pull the intake as a last resort and try to get enough angle on the distributor to fish it out of mesh with the cam gear.
Old Feb 1, 2017 | 02:11 PM
  #102
hope2's Avatar
hope2
accomplish same thing by turning the engine a little at a time and try to remove distributor.
I'm still in the camp of not enough pressure, but with the comments about clean oil and distributor removal for shimming, can't rule out roll pin.
When I had a tough one; hold pressure on back of distributor and "bump" with pry bar.
Wiggle right up.
Old Feb 1, 2017 | 02:32 PM
  #103
GCD1962's Avatar
GCD1962
Originally Posted by Daren67
The shaft cannot be rotated as it has not cleared the camshaft. The 1/2 inch up does not clear it
If the BODY (not the shaft) can not be rotated, then that is the problem, not a backed-out roll pin. I would try some muscle, money wrench? and try to twist the body free. Snug it up then keep tapping lightly on the wrench trying to get it to turn. Keep working it back and forth until it frees itself
Old Feb 1, 2017 | 02:42 PM
  #104
MikeM's Avatar
MikeM
This has all been suggested many times already.
By not reading the whole thread, you have missed pry bars, hammers, slide hammers, engine hoist, dynamite, etc...............
Old Feb 1, 2017 | 03:09 PM
  #105
emccomas's Avatar
emccomas
This guy is in Old Greenwich CT. Is there no one close enough to go over and see what is going on?
Old Feb 1, 2017 | 03:14 PM
  #106
MikeM's Avatar
MikeM
Yeah, Corelli, Pasta,.......................
Old Feb 1, 2017 | 03:25 PM
  #107
GCD1962's Avatar
GCD1962
All that is trying to pull it up and out. My suggestion is to twist first to break it loose.
Old Feb 1, 2017 | 03:26 PM
  #108
GCD1962's Avatar
GCD1962
Daren - I'm close by. Send me a PM
Old Feb 1, 2017 | 03:35 PM
  #109
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
I'm surprised no one has recommended a slide hammer to add a little impact to the straight pull up. Wrap a short small chain around it, bolt it through so it can't slip off and hook both ends of the chain to the hook end of the slide hammer and just tap it up. It'll come little by little. There's probably 40 years worth of varnish holding it in there.
Old Feb 1, 2017 | 03:36 PM
  #110
Black 03 Z06's Avatar
Black 03 Z06
I think someone did in fact suggest that. This truly is a mystery.
Old Feb 1, 2017 | 03:41 PM
  #111
GTOguy's Avatar
GTOguy
I recommended this 49 posts ago. Have done it a few times on old, and very crusty, Ford distributors. They were held in by varnish, though. A few light upward taps, and good to go.
Old Feb 1, 2017 | 03:49 PM
  #112
Robert61's Avatar
Robert61
If a cherry picker doesn't get it a slide hammer ain't got a chance
Old Feb 1, 2017 | 03:59 PM
  #113
GTOguy's Avatar
GTOguy
Totally different methods....a slide hammer will 'shock' a rusted or frozen part loose. A steady lift from a crane is not as effective.
Old Feb 1, 2017 | 05:29 PM
  #114
MikeM's Avatar
MikeM
You are taking things a little too seriously. The OP only has a 2' carpenter's crow bar and a paint stir stick.
Old Feb 1, 2017 | 05:30 PM
  #115
Robert61's Avatar
Robert61
That all depends on how many times you've wrestled the pig. Just yesterday I was pressing the pinion bearing on, for the third time, and after it bottomed out I let it set for a second. Then I whacked the press with a hammer. A young mechanic watching said what good did that do? I told him you could hear the bearing pop each time I pulled the lever and I was making sure the bearing was all the way down. So if he lifts the front tires off of the ground he now has as much force on the dist as he's gonna get then he can whack it with a hammer. Should do the trick.
Old Feb 1, 2017 | 05:34 PM
  #116
Frankie the Fink's Avatar
Frankie the Fink
Army
Yup, everything but somebody holding the distributor up and stationary while rotating the whole car around underneath it .... still waiting for that one
Old Feb 1, 2017 | 05:43 PM
  #117
GTOguy's Avatar
GTOguy
You just suggested it, Frankie! Great idea!
To cannot remove distributor
Old Feb 1, 2017 | 06:13 PM
  #118
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Turn everything upside down and give it a good shake - that sucker will drop right outta there!
Old Feb 1, 2017 | 06:45 PM
  #119
Robert61's Avatar
Robert61
Where were all of you comedians the last 4 days while I was changing my ring and pinion, in and out 3 complete times!
Old Feb 1, 2017 | 06:58 PM
  #120
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Uh, home having a couple beers maybe
