Gas Tank
Old Dec 26, 2008 | 03:16 PM
71 Green 454's Avatar
71 Green 454
Default Gas Tank
Well, it looks like it's my turn to replace the gas tank on my '71 LS5. I came home from a cruise and smelled gasoline in the garage. Any opinions or experiences as to where to purchase a new one before I order one from Eckler's?
Thanks,
Dave
Old Dec 26, 2008 | 03:25 PM
Duke94's Avatar
Duke94
I'd check out some of the other Vette parts suppliers as Ecklers is usually the high priced one.
A quick check:
ZIP=229.95
The Last Detail= 209.00
Riks=199.95
Ecklers= 233.99 On Sale today reg 259.00
Wilcox=183.99.
I guess I'd buy from Wilcox as he is the cheapest and is a major technical contributor to this Forum.
Old Dec 26, 2008 | 03:40 PM
71 Green 454
A quick check:
ZIP=229.95
Riks=199.95
Wilcox=183.99.
Good information....thanks Duke94!
Old Dec 26, 2008 | 03:59 PM
Alan 71's Avatar
Alan 71
Hi Dave,
What makes you think it's the tank? There are quite a few places that can leak gas and cause a gas smell.
Regards,
Alan
Old Dec 26, 2008 | 04:05 PM
Gordonm's Avatar
Gordonm
Check all your rubber hoses and your hard fuel lines first. They have a tendancy to rust out ond seep fuel.
Old Dec 26, 2008 | 04:27 PM
71 Green 454
Originally Posted by Alan 71
Hi Dave,
Regards,
Alan
Hi Alan,
I looked underneath and I could see that the support straps were wet. I didn't see any leakage at the hoses or gauge assembly.
Dave
Old Dec 26, 2008 | 05:50 PM
Gordonm's Avatar
Gordonm
Originally Posted by slk230red
Hi Alan,
Dave
If it leaks at the straps it has probably rusted right through the tank. Time for a new tank.
Old Dec 26, 2008 | 05:56 PM
speedreed8's Avatar
speedreed8
www.gastanks.com
Old Dec 26, 2008 | 07:45 PM
72LS1Vette's Avatar
72LS1Vette
Hi Alan,
Dave
Did you check the driver's side of the tank where the evaporative line resides? It's up high and kind of hard to see. By any chance did you fill the tank just before this problem started? There is a check valve in the evap line that has a hose going into it and a hose out to the tank. It's intended to keep fuel from flowing down the evap line but if the hose from the tank to the check valve is leaking you would see it when you have a full tank. If those hoses seem to be intact then it might be time for a new tank.
Rick B.
Old Dec 26, 2008 | 08:21 PM
71 Green 454
Rick B.
The last time I filled the tank was in 1976 I only keep about 1/4 tank of gas or less...that's probably not good for the gas tank. I'll remove the spare tire carrier next week and start looking closer to determine if it is the tank, but my gut feeling is that it needs replaced.
Old Dec 26, 2008 | 09:36 PM
72LS1Vette's Avatar
72LS1Vette
1/4 tank is way below where the evaporative system would come into play. I'd keep the car outside until you fix the leak.
Rick B.
Old Dec 26, 2008 | 11:56 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Thanks,
Dave
same thing happen to the 74 LS4 I just bought, went out and filled the tank with gas, came back and smelled gas after we turned off the engine. Looked underneath, but could not see anything leaking.
BTW...great thread
Rick B.
great info, I have been away from C3's for so long, that I forgot half of the stuff I used to remember....I will have to check that line.
BTW, the 74 has only 10,245 original miles on it, but I know that after 34 years things do wear out, even if they are not used....
Also not trying to highjack your thread Dave, just seems that we both have the same problemthanks............Tom
Old Dec 27, 2008 | 01:52 AM
Brass Pass's Avatar
Brass Pass
I just replaced the fuel tank in my 1972. The tank looked like it had been leaking for some time. I just noticed it when I put in 5 gallons after it had been sitting for a year and i was going to fire up a new motor. Tank had a bunch of pin hole leaks from rust and I think I made them worse when I had been working on the car.
I purchased from: http://www.quantaproducts.com
They had everything. Tank and all other items purchased were well packed, priced right and shipped quick. I would buy from them again.
You may want to replace all of the hoses and sending unit since your installing a new tank. Have fun, its not a bad project.
Old Dec 27, 2008 | 05:24 AM
c3_dk's Avatar
c3_dk
Hi Dave,
Regards,
Alan
Old Dec 27, 2008 | 08:46 AM
71 Green 454
Rick B.
It probably only has a few gallons in there now, so I'm going to siphon the gas out of the tank today and soak up the rest. My hand fits into the opening. I've never let it sit outside since I bought it in 1975, but I surely don't want to burn down the house.
Thanks,
Dave
Old Dec 27, 2008 | 02:44 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Quanta makes excellent repro gas tanks as one of the earlier posters said. I have used two of their tanks and was very pleased.
Old Dec 27, 2008 | 03:16 PM
bj1k's Avatar
bj1k
LEAVE IT SIT OUTSIDE ?? Depends on what neighborhood you live in !
To Gas Tank
Old Dec 27, 2008 | 09:35 PM
GUSTO14's Avatar
GUSTO14
As others have said, Quanta makes about the best "correct" gas tank for our Corvettes. The good news is that many of the vendors carry them. Original style tanks will have the “O.L. Anderson” logo. I would be sure to look for this on any offering.
Paragon has it for $229 which includes...
Fuel tank kit, w/correct square side indents, single evaporative emission control nipple, 24 gallon capacity. Kit includes screws, fuel sending unit locking cam, o-ring, & filler neck gasket. 1970 LT-1 w/E.E.C. 1971-72 All w/LT-1
Good luck... GUSTO
Old Dec 27, 2008 | 09:39 PM
Muddywaters's Avatar
Muddywaters
Good luck... GUSTO
This is the route I took...very happy!! Muddy
Old Dec 28, 2008 | 08:53 AM
71 Green 454
Good luck... GUSTO
Thanks for information GUSTO
