Kick panel side vent door Seal
Old 11-01-2009, 11:07 PM
GPGG70
GPGG70's Avatar
Default Kick panel side vent door Seal
I'm rebuilding my heater & Ac. I decided to rebuild the side door vent once I hunkkerd down and looked at how jacked up the seal on the door was not to mention I better do it now while I can get to it with ease before I put the heater core/housing back in.
My Question is about the seal instalation. Are all the rivets on the door need to be removed to seperate the door to install the new seal?
I should get the seal tomorrow or tuesday. Just want to have the door ready to go back together once the seal arrives.
Is there any tricks of the trade working with the rivets on the door?
Thanks for any info.
Old 11-02-2009, 10:32 AM
GPGG70
GPGG70's Avatar
Never mind, I figured it out and got it going.
Old 11-02-2009, 12:51 PM
7T1vette
7T1vette's Avatar
Received 2,717 Likes on 2,275 Posts
If you have a Michael's Craft Store in your area, you can buy a single sheet of black "craft foam" (8" x 10") for about a buck. That is the exact stuff to replace that seal. Just drill out the rivets, clean and paint the metal pieces, cut the seal to the right size (which will be somewhat bigger than what you have left on the old one), assemble the parts, and Pop-Rivet it together. Piece-of-cake.
Old 11-02-2009, 09:45 PM
GPGG70
GPGG70's Avatar
7T1vette,
Dang, just one dollar? I new if I posted this sooner I would be lead to the same or better material then what I had ordered. Oh well.
Thanks for the information. Thats what I did today was strip the door apart and painted but will attempt to install the original rivets once the kit arrives. If the original style rivets are too difficult to manage the I'll put the pop rivets to it. I've been working on this project for some time now and it's time to move on. Once I install this door then eveyrthing goes back together. I may write up a paper on this whole ordeal.
Thanks Again.
To Kick panel side vent door Seal
Quick Reply: Kick panel side vent door Seal
