I was searching for a true chrome look paint that could be used on fiberglass sidepipe covers, and found a product called MirraChrome which is made by Alsa Corporation. They claim that it is not like the cheap immitation spray chrome and it can be clear coated with urethane clear. Has anyone used this or a similar product ?
I've not used it, but if you go to the Alsa website, they have video clips of items being painted. It looks very promising as a substitute for chrome and/or vacuum-metalized parts.
The pictures and descriptions are pretty impressive.
It would be interesting to see some actual samples.
Regards,
Alan
I wonder if the weather will cause this paint to bubble up in the same way it causes the chrome to bubble. I've often felt the problems are with the alloy the covers are cast from, not just the chrome plating.
I considered it when I was doing the exhaust on my 69. The rattle can version isn't that good. It looks like polished aluminum than chrome.
Even the polished aluminum look would look great compared to painting the sidepipe covers, and at a little over $100. for a three part system in arosol , that don't sound bad when you consider that you can't buy anything for a corvette for any less than $100. I just wonder how it will hold up. With the urethane topcoat it should hold up fairly well. Hopefully someone will chime in that has actually used it.
what about getting them powder coated with that chrome like powder? I saw somebody post a pic in here of thier intake that looked pretty close to chrome..
That might be an alternative. Any idea on the cost?
It's a good idea if you will be satisfied with the near chrome look. It's certainly better than paint. It will cost only a fraction of what original side pipes will cost.
On the other hand, if that car on which you are putting this on is an original side pipe car, I'd spend the extra dollars and put original covers on it.
Anything being powdercoated has to be able to withstand 500F degrees or more. I don't know what the sidepipe covers are able to handle.
....but, aren't those pipes getting pretty close to that temp anyways? And I thought you couldn't PC plastic because the part is electrically charged and then the powder has the opposite charge. How do you electrically charge plastic/fiberglass??
....but, aren't those pipes getting pretty close to that temp anyways? And I thought you couldn't PC plastic because the part is electrically charged and then the power has the opposite charge. How do you electrically charge plastic??
Good point ! Better stick with researching this MirraChrome product more.
Here's another Company that deals in Chrome Paint. Pretty impressive Gallery. The helmets look like real Chrome. The Truck they show, you can't tell the difference between the grill and the Paint. The Kit's are a bit cheaper than the ALSA Corp.too.
I have a set of Fiberglass Cover's stashed away and it's real tempting to try this system.
I have searched for well over a year for someone that can do something with refinishing the OEM sidepipes, powder coating requires bake out to 300 degrees.
at this tempature the parts will survive.... but the long main sections will curl like a potato chip! "don't ask how I know"
I am currently working with Jet-Hot to develop a process to refinish these,
we are not done yet, but very close. I will post with finished product once we are succesful. 69VETT
Marty , Sounds like a great product for someone wanting to make the investment and go into the business, but I don't know if this is what I am looking for. I don't see anything in the kit form for do it yourselfers and it says you need to bake it which would be a problem for larger items such as sidepipe covers.
From the webpage, Cosmichrome is only good for 300-350F. That seems pretty marginal for sidepipes. Is there any kind of insulation material between the exhaust pipes and the covers?
I saw these guys in the parts for sale section yesterday and they claim they can crome fiberglass. The questions was brought up regarding side pipe covers and he said 175.00. However he would have to look into putting the black strips on. http://www.a1motor-sports.com/sportbikes.htm
Warning to anyone attempting to refurbish the OEM side pipe covers,
IF you try and power coat or a type of process-Cermaric coating like JET Hot.
These parts must be taken to a temperature of 350 Degrees,
and if you do that the long middle section will curl like a potato chip,
closing up and will be no longer be use-able, I had to have a special jig made to keep the covers from distorting. during the bake process.
The biggest problem with these old covers is the stripping and prepping them.
The covers do not get near this hot when installed on the car.
The ALSA Corp. paint is the only paint I have ever seen that comes very close to Chrome.
69VETT
