I painted my rally rims last weekend. Two trim rings went back on ok, albeit with a bit of work. The other two will not stay on. I get one clip clipped on, start on the second one and it snaps in place and the first one pops off! I cannot get all four to stay at one time. I spent over an hour on just one. I'm hot & sweaty and I'm having a burger and a beer. What's the trick or technique?
Thanks, Glenn
You started correctly, but forget the burger and have more beer.
Put one of the clips where you can snap it on, then put your knee against it. Work the next one with a rubber mallet and the one across from that. Then the 4th one should snap on. PITA, aren't they?
If they are aftermarket rings....good luck. The clips on those are either way too stiff or they are flimsy as he!!. You may have to bend the clips a bit to get them to fit well with adequate retention and still not too difficult to install. Ideally, you want to be able to pop them on with the heel of your hand [not a 'mallet' that will bend everything up]. It's best to put on one of the clips that is closest to the valve stem (to keep the stem centered in the hole), then the clip opposite from that one [keeping the gap between the unattached clips and the wheel rim about the same], then the other two (in any order).
They are the original 4 clip.
I started with the clip closest to the valve stem, then went to the opposite side. Then at the next clip as that started to snap on one of the others lets go. The heel of my hand is now pretty sore! I'll give it another try tomorrow.
Thanks, Glenn
3 of mine went on easy, the 4th one I had to do my orangatang impression by holding the valve stem side with my knees and working the opposite side in ...i had to tweak the tabs a bit, mine were also original 4 clip...patience is key
If you have tires larger than 205 r70-15 the rubber pushes up higher on the rim lip. It will not allow the clips to go deep enough to grab.
You may want to try taking the tire off the car and letting most of the air out before attaching the trim ring. The reinflate and you should be good to go.
Radial tires have a bulgy side wall and it is even more pronounced when there is weight on the tire.
The original f70 tires had a totally different sidewall profile than radials.
Hope this helps....
Interesting. They are 235's. I 'll see if this helps.
Glenn
Glenn,
I have 235's, also. Since you have the 4-clip design, look at the configuration of each clip from a side view. The middle 'loop' needs to be at nearly a 45* angle [to vertical] so that it will hold properly. If it is too steep, it will not hold well; if it is too shallow, it will be a real bear to get on. Also, the side 'hooks' need to be shaped so that they will slide into the tire/rim gap. I had a clip where those 'hooks' were opened up too much and the clip would not engage. If you have one clip on that wheel which goes on/comes off as you think it should, configure the other three clips just like it.
P.S. You need to do any bending carefully and without grabbing onto the bright sheet metal...or you will bend/damage the bright metal surface. Good luck!
Glenn,
I'll take a closer look at the angles of the middle loops and hooks on the ones that hold well and match those as closely as possible. I did try bending one of the hooks to hook more, because it didn't appear to be hooking on the rim edge at all. I have another project for the weekend. Yeah!
Thanks, Glenn
Anyone have their 4 clip trim rings off that can take a few pics of the clips at different angles? I'm curious to see what positions & angles they are at. My hand is still sore from last night.
Thanks!
Hi Glenn,
Are the wheel weights outside or inside?
Hope these help! Original production line ring.
Regards,
Alan
Hi Alan,
Weights are on the outside but are not near the clips.
My clips look pretty close to yours except one of the hooks had less curl. I tried to bend it and did a bit, but that spring steel is difficult to bend. I'll give it another shot tomorrow.
Thanks for the pics! Exactly what I was looking for.
Are you able to put yours on by using the heel of your hand or do you need to use a rubber mallet?
Glenn
Hope this helps....
But I just put a jack under to hold car up ,then lower the pressure. I use my knee and a rubber mallet and a bit of grease on each clip.
edit-with new paint you won't need the grease - grease is for squeaks
Hi Glenn,
I use my knee as Roger suggests and my hand.
I see original St. Louis rings that that fit so tight and evenly that the weights MUST be on the rear side of the wheel. I'm NOT saying that's your problem but may be worth looking at.
Good Luck.
Regards,
Alan
Hi Glenn,
Good Luck.
Regards,
Alan
When I removed them to paint the rims, they were very tight & difficult to remove. I'm going out now to give it another shot & see if any clips need a bit of bending.
Got them on. 7T1, your info re; the center loop was my problem. I needed to bend them out some, closer to 45 Degree angle you suggested and like Alan's pics. Alan, your pics were perfect reference. Thanks guys for all your suggestions. Luckily, I did not need to let any air out of the tires.
Here's the finished wheels. A big improvement!
Glenn
