Hey Bubba! Valve Covers..
Old Jun 4, 2011 | 11:14 AM
ATCmoose's Avatar
ATCmoose
Default Hey Bubba! Valve Covers..
Well, here is my 1st un-bubba on the 71. I noticed the oil was a little low, so I went to add a little. Hmm, the oil cap hits the compressor and wont come off. Gee that's probably because the covers are on the wrong side right? Geez.
So any special tips before I swap them to the correct sides? Should I replace the gaskets while I am at it?
Moose
Old Jun 4, 2011 | 12:32 PM
oldsarge's Avatar
oldsarge
Not a big deal, just swap them over, and yes, while you are in there, get some new gaskets, cheap fix.
7T1vette's Avatar
7T1vette
Absolutely change the gaskets. Also, don't overtighten the cover bolts.
Old Jun 4, 2011 | 12:48 PM
croaker's Avatar
croaker
So I wonder how po added oil?
Old Jun 4, 2011 | 12:53 PM
ATCmoose's Avatar
ATCmoose
I am guessing through the PCV.
Old Jun 4, 2011 | 01:50 PM
7T1vette's Avatar
7T1vette
Bubba??? Add oil???
Old Jun 4, 2011 | 02:31 PM
Alan 71's Avatar
Alan 71
Hi,
Bubba doesn't need to add oil because he uses the gas from the can for the weed-wacker.
Regards,
Alan
Old Jun 4, 2011 | 03:13 PM
ATCmoose's Avatar
ATCmoose
Originally Posted by 7T1vette
Bubba??? Add oil???
Yeah, no kidding. It was only about 1/2 qt low.
I am sure this won't be the last time I get to encounter his fine engineering...
Moose
Old Jun 4, 2011 | 03:41 PM
ATCmoose's Avatar
ATCmoose
So I see a bunch of different materials and thickness for the gaskets. What is the best? Cork/Rubber? If Cork, there are several thicknesses to choose from.
I want to make sure it is done right.
Thanks for the advice!
Moose
Old Jun 4, 2011 | 04:25 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I would go with cork
Old Jun 4, 2011 | 04:37 PM
oldsarge's Avatar
oldsarge
Get the standard Fel-Pro, cork gaskets.
Old Jun 4, 2011 | 05:09 PM
garage-ghost's Avatar
garage-ghost
I have been taking my valve covers off and cleaning them once a year, for 27+ years and have never replaced the gaskets. They are cork and stuck to the covers. Just put them in the sink scrub the covers and put them back on. Never leaked. Have a set in the garage in case I tear one, but never have. But you can't go wrong with new ones. Good luck with your swap.
Old Jun 4, 2011 | 05:16 PM
bluthundr's Avatar
bluthundr
Same here, they are glued with Permatex to the valve covers and then I just run a drop of oil around the mating surface with my finger and snug them down - no leaks.
Old Jun 4, 2011 | 06:02 PM
PeteZO6's Avatar
PeteZO6
Moose
Ditch that rubber hose from the fuel filter to the carb inlet pipe! Any rubber fuel hose on the pressure side of the fuel pump is a fire hazard and should be replaced with hard line, and not copper.
Pete
Old Jun 4, 2011 | 06:12 PM
kdf1986's Avatar
kdf1986
I think the PO would have replaced the oil through the valve cover breather filter because he couldnt get the oil cap off.
kdf
Old Jun 4, 2011 | 08:20 PM
ATCmoose's Avatar
ATCmoose
[QUOTE=PeteZO6;1577792719]Ditch that rubber hose from the fuel filter to the carb inlet pipe! Any rubber fuel hose on the pressure side of the fuel pump is a fire hazard and should be replaced with hard line, and not copper.
Pete[/QUOTe
Another Excellent idea! Keep em coming, I am making a small 87 page list
Moose
Old Jun 4, 2011 | 10:29 PM
7T1vette's Avatar
7T1vette
I like the composition cork/rubber Fel-Pro valve cover gaskets. They don't dry out like 100% cork...and they seal a lot better than 100% synthetic rubber./
To Hey Bubba! Valve Covers..
Old Jun 5, 2011 | 11:25 PM
earthquake68's Avatar
earthquake68
Pete
I don't use fuel hose anywhere. It dry rots too fast. I use fuel injection hose for everything. It's a much higher quality of hose. It's also a much higher price tag. The injection line will work just fine. If it scares you that much, buy -AN braided line.
Old Jun 6, 2011 | 10:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bubba??? Add oil???
Bubba removed the AC compressor each time he needed to add engine oil. He was a favorite customer at the AC shop.
Old Jun 6, 2011 | 02:00 PM
ATCmoose's Avatar
ATCmoose
Now I have to figure out how to get to the bolt under the A/C compressor. I needed some new tools anyway.
Moose
