C3's with 18" wheels only thread
Old Apr 23, 2016 | 10:40 PM
  #621
Dale760's Avatar
Dale760
Originally Posted by pltmgr
I'm not a fan of modified Corvettes but you have a fantastic looking vehicle.
I think your ride height is about perfect, sure they look great lowered more, but then you drag parts and have very little travel bump stop to trailing arm.
Cheers Dale
Old Apr 23, 2016 | 10:52 PM
  #622
Kris_K's Avatar
Kris_K
Originally Posted by Factor
Thanks guys!!! Love the look! makes me smile just looking at it sit in the garage!
Yes. Boss 338 18x9.5 all around. no change to suspension to fit, only rear TAs b/c wanted a working parking brake and clean look...but not needed.
Did not 'totally' change suspension to get ride height. Used 550 lb replacement springs for 454 iron bbc, but have huge aluminum heads. Rear is fiberglass monospring from VBP (they are a great contact to chat with for technical) and it is 360# rate...I did get 8" larger bolts to lower just slightly from stock. so I guess the answer to the question is Yes I did. I could get a little lower which is what I am debating on now...she is on the fence of just right VS too high. ***careful when buying monosprings...some come ridiculously high...I would err on the side of lower, hence VBP.
I did a ton of checking and researching tire and rim sizing, then actual total wheel diameters. Nitto had a great website for checking actual wheel diameters. then bozeforged has a great sidewall chart for making it all jive.
Have fun!
Would you lose the parking brake with the stock trailing arms?
Old Apr 23, 2016 | 10:58 PM
  #623
Dale760's Avatar
Dale760
Hi Kris
Mine were way to close, so I moved mine to the top of the trailing arm and routed the cables behind them, works like a charm.
Dale
Old Apr 24, 2016 | 10:42 PM
  #624
Kris_K's Avatar
Kris_K
Originally Posted by Nevada Silver
Hi Kris
Dale
Dale,
Do you have the 18x9.5 Boss wheels in the rear too?
Old Apr 24, 2016 | 10:56 PM
  #625
Gary Strader's Avatar
Gary Strader
7th Gear
My '69 running 18" Intro Pentia's. BF Goodrich g-force T/A 335/30zr18 on back with 275/35zr18 on the front.
Old Apr 24, 2016 | 10:57 PM
  #626
Dale760's Avatar
Dale760
Originally Posted by Kris_K
Dale,
No I have 18 X 9.5 Coys with 5.5" BS. I run a 1/4" spacer with ET lugs, and it cleared but was just to close for my liking Kris.
Old Apr 24, 2016 | 11:24 PM
  #627
Dale760's Avatar
Dale760
[QUOTE=Gary Strader;1592071307]My '69 running 18" Intro Pentia's. BF Goodrich g-force T/A 335/30zr18 on back with 275/35zr18 on the front.
Awesome Gary
Dale
Old Apr 25, 2016 | 02:26 AM
  #628
CraigH's Avatar
CraigH
Beautiful Gary
Old Apr 25, 2016 | 01:52 PM
  #629
Factor's Avatar
Factor
Hi Kris!,
As for me on the stock TAs and parking brake...well, I did alot of research and the answer is "maybe"...some people have issues...others not...all depends...
I wanted a working & clean parking brake...and felt it was easier to get the TAs switched than to modify/paying a shop. The only way to be sure is to mount the wheels and see...
Good Luck!
Ron
Old Apr 26, 2016 | 05:23 PM
  #630
stingraymaniac's Avatar
stingraymaniac
Originally Posted by kyaggie
Finally got my new wheels and tires on. Ended up replacing ball joints, control arm bushings, steering sleeves, rotors and brakes, etc, along with VB&P 550# front coils and Bilstein shocks all around. Waiting on the VB&P 360# mono for the rear so to lower another 1 to 1 1/2 inch.
American Racing Torque Thrust wheels. 17x8 front and 18x9 rear. Only clearance issue was in the front where I had to run a 1/4" billet spacer. Otherwise, all was good, did have to relocate emergency cable bracket.
Here's not the final product yet, but close. Will be painting over the winter of 2016.
Both positive and negative comments appreciated. Thank you,
Kevin
PS: I will be posting a second set of pictures, can't send them all at one time.
Nice ride!
What spinners do you have on your wheels? Looks great
Old Apr 26, 2016 | 05:35 PM
  #631
navet's Avatar
navet
Looks awesome
What are the wheel sizes front and rear thanks
Old Apr 26, 2016 | 09:33 PM
  #632
Gary Strader
7th Gear
Originally Posted by navet
Looks awesome
18x12 with 335/30zr18 on the back
18x10 with 275/35zr18 on the front.
Old May 16, 2016 | 09:26 AM
  #633
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
From https://www.corvetteforum.com/forums...thread-29.html post #577 to this using 3/16" spacers in the rear and lowered front 2".
Old May 16, 2016 | 09:42 AM
  #634
rastafford3164's Avatar
rastafford3164
That's looking good! I had already been studying those wheels before you brought them up in #577. I am leaning toward 17x8 for the front instead of the 18x8, 18x9.5 in the back with a 1/4" spacer since the backspace is 5.25. Did you give 17's on the front any consideration and would the rears have hit with less than the 3/16? I ams still on the stock suspension. Looks like you have adjustable struts. Any other modifications back there? Relocate the parking brake? US Mags had a good looking 69 on their website, and I had reached out to them with some questions but never got a response. Sorry to be a bother.
Allan
Old May 16, 2016 | 12:49 PM
  #635
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Allan
No bother at all, Allan. I did consider 17" for the front but my overriding consideration in wheel size was greater tire selection for 18's. I have no mods for the fronts. The wheels sit inboard a bit more due to BS and they just clear the calipers. In the rear, I have adjustable struts as you noted as well as 8" spring bolts. I also relocated the parking brake bracket but that was more to clear the cable vice the bracket. I have a replacement 7 leaf steel spring. I replaced the bottom spring bolt washer below the poly cushion to a smaller diameter to gain some clearance which worked well. With the car raised in the rear, the spring just touches the inside of the rim but clears the rim when the car is on the ground. The wheels themselves have a good chrome finish but the chrome is only on the front of the wheel. Hope this helps.
Old May 16, 2016 | 02:39 PM
  #636
rastafford3164
Absolutely!! Thanks Mike!
Old May 17, 2016 | 10:47 AM
  #637
Drewvious's Avatar
Drewvious
Here is my 79 L-82 that I just got back on the road. I really like the PVD TTII's! I tried to be a little different and not go with the polished, at first I was skeptical but I really like the muted chrome look. They are 17x8 front and 18x9 rear. I hope it's ok to post in the 18's only thread...
To C3's with 18" wheels only thread
Old May 22, 2016 | 10:16 PM
  #638
vetteman1981's Avatar
vetteman1981
A HAH! figured it out!
Great color choice. is that Atomic Orange?
Old May 23, 2016 | 09:02 AM
  #639
Factor's Avatar
Factor
Hi Vettemn!
Yes. It is 2009 z06 atomic orange metallic BUT with more pearl added. Made it w the paint shop. Great color initially from GM but was missing a little for the body to pop. LOVE It!
Old Jul 1, 2016 | 08:15 AM
  #640
wendellp601's Avatar
wendellp601
Default 1977 with Boss 338 in 18 x 8
The UPS guy dropped these off yesterday.
