Fixing a crack
Old Nov 12, 2011 | 03:49 PM
frake3's Avatar
frake3
Default Fixing a crack
I am contemplating the purchase of this Orange Vette. It has fairly low mileage (70k) and is at a great price. The only thing wrong is this crack on the drivers side back quarter panel. Can this be done myself? How much would you think it would cost to repair either way (myself or at a shop)?
Thanks!
Old Nov 12, 2011 | 04:14 PM
Bills17n72's Avatar
Bills17n72
that bad of a crack ,should be done by a shop ,I bet the whole back panel will have to come off ,expensive!!!
Old Nov 12, 2011 | 04:16 PM
Bills17n72's Avatar
Bills17n72
it looks like around a 75 model ,I wouldnt give him more that three grand for the car with that problem!!!
Old Nov 12, 2011 | 04:39 PM
frake3's Avatar
frake3
Its a 77....
Old Nov 12, 2011 | 04:50 PM
Alan 71's Avatar
Alan 71
Hi f,
The crack does look pretty involved.
There is a body seam in that area that runs from the front of the quarter panel to it's rear. It could be a problem with that seam.
BUT, I also see a crack running down from the long horizontal crack, and another at the front lip of the wheel arch, and another at the rear. They make me think there's something more serious going on that will take some work by a person with some fiberglass and paint experience.
Not a deal breaker, but certainly needs to be taken into consideration when considering a price for the car.
Good Luck!
Regards,
Alan
Old Nov 12, 2011 | 05:18 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
what caused the crack?
Old Nov 12, 2011 | 11:05 PM
markids77's Avatar
markids77
Lengthwise crack is the factory bonding strip area. It looks to me like there might have been a previous repair in the area and it was done poorly. The rear quarter is cracked at the wheelwell as also, and perhaps lower and farther back as well. So you have multiple repairs to complete just on this single panel. You can fix all this without (probably) replacing anything, but there will be extensive paint matching and blending to be done after the panel repair. If there is damage of any sort anywhere else on the car you are looking at $$$ for repair so if you want this car I would base my offer on the assumption of a complete strip and repaint... not cheap even if you can do it all yourself.
Old Nov 13, 2011 | 12:47 AM
milo30's Avatar
milo30
I'd want to replace the entire section. Not because you have to but I'd want to know what is behind it and if there were any further damage. I wonder what caused it...a blown tire maybe?
If I really wanted the car I'd rather pay a little more and have it already repaired before buying it than to get into unknowns with a new car.
Old Nov 13, 2011 | 02:06 AM
chstitans42's Avatar
chstitans42
TheCorvetteBen
I have a rear quarter panel for sale if you end up needing it. $100. PM me if interested
Old Nov 13, 2011 | 05:46 AM
7T1vette's Avatar
7T1vette
That crack is in the area of the bonding strip, but it is too jagged to be broken at that strip. There are other areas of cracking on that panel. It just looks like that panel was hit enough to crack it (front end of another car hit it at low speed, maybe). Big fix and tough to match the paint when done.
Old Nov 13, 2011 | 10:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by milo30
...I'd want to replace the entire section...
You're spending money you possibly do not need to spend.
Originally Posted by 7T1vette
...panel was hit enough to crack it...
Based on the pic, the damage I see is repairable. What does the seller say about the damage?
How are your fiberglass skills?
To Fixing a crack
