Another '77 Project
Old Feb 4, 2012 | 10:55 AM
  #61
AdamMeh's Avatar
AdamMeh
Originally Posted by wan2run
Who makes the headers, Hooker? I see the tag on the pics, but I can't read it.
Hi wan2run... here is a shot of the tag. They are Cyclone brand
Old Feb 4, 2012 | 03:11 PM
  #62
wan2run's Avatar
wan2run
They look great...never heard of Cyclone headers. I looked for an online presence, but they must be defunct. I'm trying to decide on long tubes for mine without trying to break the bank.
Old Feb 4, 2012 | 08:55 PM
  #63
Retro78's Avatar
Retro78
Originally Posted by AdamMeh
Most of the detail stuff is done on the motor now. Few more little things to do before we do the breakin runs.
Please dump that glass filter.. a fire waiting to happen.. garbage. I am surprised they are still selling these things. It is not the glass that is the problem, it is the the ends that easily backoff and the cheap seals.
Old Feb 4, 2012 | 09:02 PM
  #64
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
Man, you are really moving on that thing. Hope the engine runs as good as it looks.
Old Feb 4, 2012 | 11:11 PM
  #65
AdamMeh's Avatar
AdamMeh
Why do you say that? I've been using them for over 20 years and never had a problem at all. If the fuel line is secured properly it shouldn't have room to move or come loose.
On another note, IT IS ALIVE!
Did the first break in run late this afternoon. Sounds awesome! We ran out of daylight so we'll do the second run tomorrow. Some carb adjusting is needed etc, but it sounds great. Temp held between 190 and 210. Ran closer to 210 until I got the timing setup then dropped back down to about 190 and held there for the rest of the run.
I'll shoot a little video tomorrow and get it posted up. I'm going to get some sleep now, so see you in about 20 hours
Old Feb 4, 2012 | 11:51 PM
  #66
rogman16's Avatar
rogman16
Adam--
Awesome!! Know you must be stoked, congrats... Nothing like hearing it run for the first time, huh!!!!
Rogman
Old Feb 5, 2012 | 07:24 AM
  #67
AdamMeh's Avatar
AdamMeh
Hey Rogman,
You said it brother - after it fires up and you don't have any horrible clanging or odd fluids coming out anywhere, it gets much more enjoyable LOL
It was a good day
Adam
Old Feb 5, 2012 | 11:04 AM
  #68
rogman16's Avatar
rogman16
Sounds good!!
Rogman
Old Feb 13, 2012 | 05:32 PM
  #69
AdamMeh's Avatar
AdamMeh
OK... Since it moves now, I've started in on the brakes so it will stop
Took the rotors, pads, caliper and master cylinder kits over to have them put together. When we're done, we'll have a brand new brake system right down to the proportioning valve.
Old Feb 13, 2012 | 06:17 PM
  #70
Sunstroked's Avatar
Sunstroked
You've really made some great progress on it Adam. Seems like I'm dragging anchor. Other money pits (insert house) keep stalling my progress. But I have to ask who coated those headers? I have a set of Heddman sipe pipe headers that I may use, they have the factory black coating that is supposed to be painted over prior to use anyway, and that coating looks awesome.
Old Feb 13, 2012 | 07:27 PM
  #71
AdamMeh's Avatar
AdamMeh
Hey Kevin,
Thanks! We're working hard to make it driveable again, then we can slow down some and go at a as-we-can-afford-it pace.
I'll send you a PM with his contact info
Adam
Old Feb 14, 2012 | 09:23 AM
  #72
george2066's Avatar
george2066
Default glass gas gauge
I agree with getting rid of the gauge, first ride of mine with simular setup, smelled gas, swore it wasn't me, then pulled over, dripping gas on the maifold,WTF, no water to pour on it, hot in there, lucky it didn't go up in smoke after all the work I did, read on the forum, made a hard line from fuel pump to carb without splices, I was lucky
Old Feb 14, 2012 | 10:54 AM
  #73
AdamMeh's Avatar
AdamMeh
Hi George,
Do you mean the glass filter? I've never had a problem with those, but not against getting rid of it either. I've always used them after getting a new (old) car so I could see how full of junk the tank / lines were. It looks like someone has replaced the tank at some point, and so far I don't have even a speck of dirt in the filter.
All of my fuel lines are hard lines except the inch or so you see on both sides of the filter and a short section at the pump. I also secured the steel line in two places at the front of the motor to keep it away from the lower radiator hose heat.
You can see one of the rubber coated clamps I used in this photo - off of a water pump bolt:
The second clamp is at the bottom of the block by the oil pan.
Old Feb 15, 2012 | 04:38 PM
  #74
AdamMeh's Avatar
AdamMeh
Brakes are in progress now. Got the front rotors back and installed them with new seals, repacked bearings etc.
A a shot of a few of the brake parts that came with my buddies deal.
He has my calipers and master cylinder and is putting the kits in. He'll also be turining the back rotors, hopefully this week, so I can start putting in all the new / fresh parts.
Entre brake system will be new or rebuilt except the hard lines that run the length of the body.
Old Feb 15, 2012 | 08:24 PM
  #75
rogman16's Avatar
rogman16
Adam--
Your car is going to be brand new when your done!!! Keep the motivation high and the wrenches turning...
Rogman
Old Feb 15, 2012 | 08:30 PM
  #76
AdamMeh's Avatar
AdamMeh
Originally Posted by rogman16
Adam--
Rogman
Thanks for the feedback Rogman. Won't be as nice as your beauty, but it will be a fun car for us.
Old Feb 15, 2012 | 09:21 PM
  #77
Tim H's Avatar
Tim H
I like the Erson valve covers, I would think they are made by Sig Erson?
If so they make some Killer cams!
I ran some "Milodon" covers one time on a 79 and if they don't say edelbrock then people think you are running some kind of experimental engine.
To Another '77 Project
Old Feb 17, 2012 | 07:53 PM
  #78
AdamMeh's Avatar
AdamMeh
Rebuilding the e-brakes SUCKS when you do it without taking the axle out!!!!
end rant.
Old Feb 17, 2012 | 08:12 PM
  #79
rogman16's Avatar
rogman16
end rant.
I second that motion...
Rogman
Old Feb 17, 2012 | 09:02 PM
  #80
AdamMeh's Avatar
AdamMeh
Should have closed the garage door so my neighbors didn't have to listen to that.
WOW. One side done, the other tomorrow. I will defeat these brakes!
