68 frame
Old Sep 18, 2012 | 10:06 PM
Rjplum's Avatar
Rjplum
Cruising
Default 68 frame
Can anyone tell me what year model frames will fit under my 68 convertible. Its an automatic and im pretty sure the frame is history. I would like to do a frame swap with out spending a arm and leg.
Old Sep 19, 2012 | 07:17 AM
stpman's Avatar
stpman
68 to 72 will fit as will a 73 but the body mount height is a little different, IIRC the 68 didn't have the braces on the kickups.
Old Sep 19, 2012 | 07:56 AM
Alan 71's Avatar
Alan 71
Hi rjp,
I believe stpman is right!
Regards,
Alan
Old Sep 19, 2012 | 11:51 AM
Rjplum's Avatar
Rjplum
Cruising
Thanks for the information. I'll start looking .
Old Sep 19, 2012 | 04:46 PM
68sbShark's Avatar
68sbShark
I thought the braces were added in late '68. Can anyone confirm?
Old Sep 19, 2012 | 04:48 PM
stpman's Avatar
stpman
You may be right, I thought that but wasn't sure
Old Sep 19, 2012 | 06:59 PM
72LS1Vette's Avatar
72LS1Vette
If you look at the AIM specs of the 72 vs 73 frames the body mount height difference is insignificant - something like 1/8". I replaced my 72 frame with a 73 frame and the only problem I found was the front bumper bracket mounting holes were different. IIRC I had to elongate a couple holes on the brackets and drill 1 new hole to get everything to fit.
If you search around there is a post that has a reference to a website with frame specs for all C3 years.
Rick B.
Old Sep 24, 2012 | 02:49 PM
Rjplum's Avatar
Rjplum
Cruising
[QUOTE=72LS1Vette;1581871429]If you look at the AIM specs of the 72 vs 73 frames the body mount height difference is insignificant - something like 1/8". I replaced my 72 frame with a 73 frame and the only problem I found was the front bumper bracket mounting holes were different. IIRC I had to elongate a couple holes on the brackets and drill 1 new hole to get everything to fit.
Rick B.[/QUOTE.
Thanks : I found some good specs online , and may have found a good donor car . It's a 68 convertible as well the only difference is it a manual. I don't know but thought there was a difference in the cross member at the transmission . Would this manual frame work on my automatic?
Old Sep 24, 2012 | 03:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...the only difference is it a manual. I don't know but thought there was a difference in the cross member at the transmission . Would this manual frame work on my automatic?...
No, not without doing more work than you want to do. The crossmember for manual transmission cars is welded in.
Old Sep 24, 2012 | 04:42 PM
Rjplum's Avatar
Rjplum
Cruising
Thanks again I'll keep looking
To 68 frame
