stock crossfire intake
Old Feb 8, 2013 | 03:07 PM
  #61
alconk's Avatar
alconk
Originally Posted by corvettenorway
Thank you, bought me some cutting bits.
Old Feb 8, 2013 | 03:45 PM
  #62
Wrecked82's Avatar
Wrecked82
Originally Posted by alconk
What kind of epoxy did you use for the EGR opening??
Don't know the brand. Probably something I got at Home Depot. It would have been the hard stuff you have to mix and blend together by hand and then press into the opening. Mixed very well and then made use it was in the hole totally. Then let cure for several days.
Old Feb 8, 2013 | 03:55 PM
  #63
Wrecked82's Avatar
Wrecked82
This is what I used for the most part. Used smaller ones for fine tuning the corners
http://www.dremel.com/en-us/Accessor...l.aspx?pid=115
Old Feb 8, 2013 | 03:59 PM
  #64
Wrecked82's Avatar
Wrecked82
BTW, here is my engine bay. Remember, it has 225,000 miles on it, so it is not a trailer queen.
Old Feb 8, 2013 | 04:00 PM
  #65
corvettenorway's Avatar
corvettenorway
read this !!http://www.digitalcorvettes.com/foru...d.php?t=101038
Old Feb 8, 2013 | 04:13 PM
  #66
Wrecked82's Avatar
Wrecked82
For balancing the tbi's, instead of constructing a water manometer, simply buy one of these:
http://www.amazon.com/DCI-International-Vacuum-Gauge-Bottom/dp/B009ME3NO0/ref=lp_15729801_1_13?ie=UTF8&qid=1360357766&sr=1-13 http://www.amazon.com/DCI-International-Vacuum-Gauge-Bottom/dp/B009ME3NO0/ref=lp_15729801_1_13?ie=UTF8&qid=1360357766&sr=1-13
Then use a rubber hose to connect guage to tbi connection. You will need to use two different rubber hoses with different id/od's to step the hose down from the guage connection to the tbi connection, but that is just a little inexpensive pieces of hose.
Old Feb 8, 2013 | 04:15 PM
  #67
Wrecked82's Avatar
Wrecked82
Here is the digital multimeter you need for setting the tps:
http://www.radioshack.com/family/ind...tent=CT2032235
Old Feb 8, 2013 | 04:20 PM
  #68
Wrecked82's Avatar
Wrecked82
Here is the connector for using the above multimeter for setting the tps:
http://www.mamotorworks.com/corvette?frame=1.900
Forget that Mid America says its for a C4 - it works on the 82 also.
Does that mean the 82 is just like an 84 except for cosmetics?
Old Feb 8, 2013 | 05:43 PM
  #69
corvettenorway
this is m[IMG][/IMG]y intake ported by me !!
Old Feb 8, 2013 | 05:44 PM
  #70
corvettenorway
Old Feb 8, 2013 | 05:45 PM
  #71
corvettenorway
Old Feb 8, 2013 | 05:46 PM
  #72
corvettenorway
Old Feb 8, 2013 | 05:48 PM
  #73
corvettenorway
Old Feb 8, 2013 | 05:50 PM
  #74
corvettenorway
i have burd out ca 1 liter (0.2642 gallons )
Old Feb 8, 2013 | 06:04 PM
  #75
Wrecked82's Avatar
Wrecked82
Good looking results. I also was amazed how much aluminum I took off. Wish I had pictures of my results. Lost them on a computer problem and owner of crossfire forum deleted all the pictures I had posted there because he was mad at me. Now that forum hardly exists, so guess there is justice in the world.
Old Feb 8, 2013 | 09:52 PM
  #76
alconk's Avatar
alconk
Awesome, I bought that tonight from Lowe's. Getting ready to try it in a little bit.
Old Feb 8, 2013 | 09:54 PM
  #77
alconk's Avatar
alconk
Man, now I'm really drooling. That looks great!!
To stock crossfire intake
Old Feb 8, 2013 | 09:55 PM
  #78
alconk's Avatar
alconk
Very nice Larry, always liked the silver.
Old Feb 8, 2013 | 09:56 PM
  #79
alconk's Avatar
alconk
http://www.amazon.com/DCI-Internatio...357766&sr=1-13
Ok but them how would the process go?
Old Feb 9, 2013 | 01:09 AM
  #80
alconk's Avatar
alconk
Well this is what I started with and was already ported but just detailing it up a little
