Striping Engine Compartment
Old May 1, 2013 | 10:20 AM
BuffaloBILL's Avatar
BuffaloBILL
Default Striping Engine Compartment
Hey gang
I have stripped the 70 Vette completely geting it ready fro paint I have removed everything from the engine bay (Engine out for blue printing and ballancing) but I am having issues with the Air tank PITA my question I have removed the bolts holding it but I realy do not want to remove the clutch rod Is there a better way to get it out?
Any assistance would be appreciated
Bill
Old May 1, 2013 | 10:33 AM
Mooser's Avatar
Mooser
I've heard rumors that on manual brake cars you can unbolt the master and bend the lines far enough over to remove the tank.
On mine (72 PB) no way of doing that at all. I had removed the booster and the steering was already out so it went out fine.
HIH
Mooser
Old May 1, 2013 | 11:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by BuffaloBILL
...Is there a better way to get it out?...
No. Since you cannot see around the tank, leave it there and paint around it.
Old May 1, 2013 | 11:58 AM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I pulled the tank on my '70 through the side fender vent.
Old May 1, 2013 | 12:05 PM
Roco71's Avatar
Roco71
I can't remember how I got mine out but seems like I got it out through the side vent as well.
Old May 1, 2013 | 12:40 PM
BuffaloBILL
Impossible on the 70 model maybe on 71/72 I Spent hrs attempting this method the side vent Grill area is to narrow I belive the Clutch Rod and steering column must be removed now that I have seen the previous posts
Bill
Old May 1, 2013 | 01:33 PM
Roco71's Avatar
Roco71
Its been three years since I did mine I know the vapor canister came out the side vent. I know that I did not remove any of the steering my car is an automatic no clutch rod. The only other thing that might have been off was the master cylinder (PB) I can't remember.
Old May 1, 2013 | 02:11 PM
Raphiki's Avatar
Raphiki
Try removing the screws on the inner fender so you can pull it back a bit.
Old May 1, 2013 | 02:25 PM
Alan 71's Avatar
Alan 71
Hi,
I don't want to be the 'doubting Thomas' here, but I don't see how the tank comes out through the side vent. The charcoal canister... yes, but the vacuum tank????
The dimension of the tank and it's 3 legs is greater than the dimensions of the grill opening, AND, the #1 body mount bracket restricts how much of the vent opening is actually available.
I think pivoting the master cylinder out of the way is the method.
Regards,
Alan
Old May 1, 2013 | 03:23 PM
7T1vette's Avatar
7T1vette
Just paint the tank same as engine compartment 'black-out' areas. They are both semi-flat or satin black paint.
Old May 1, 2013 | 04:06 PM
Roco71's Avatar
Roco71
Here is a photo of the mess I started with on day one. Note no wiring harness or vacuum lines are in place. The master cylinder did not have lines running to it (not even a push rod inside for that matter). Anyway pretty sure that I removed the master cylinder which in my case was not a big deal.
Old May 1, 2013 | 06:44 PM
69FASTFUN's Avatar
69FASTFUN
The only way you will get the tank out is to remove the power booster and master cylinder. If you take it out do yourself a favor and get the booster rebuilt it will save you the aggravation later and you will get a better engine compartment detail job.
Old May 2, 2013 | 09:34 AM
BuffaloBILL
Got it out last night Unpluged the Wiring harness at the firewall removed the master cylinder removed clutch rod worked it out
There was no way to get it out from the Side grill Vent locations The Brackets on the vacum tank are to long
Thanks gang
Bill
Old May 2, 2013 | 09:46 AM
Roco71's Avatar
Roco71
Thanks gang
Bill
That's good news Bill, One of the reasons I took mine out beside to paint it was to make sure that it was air tight. I read where another forum member had one that was leaking from a hole cause by a screw. Good time to check it.
To Striping Engine Compartment
