Doorgunner's '68 Convertible Project
I managed to get a bulge on the patch from being a rookie and pushing on the exterior where the hole was, then decided to quit before I patched the broken-off area at the trailing edge
I only needed it to be about 1/8" thick, rather than the 1/2"-3/4" thick that the previous owner's body shop applied.
I'll check it tomorrow night....if it all holds I will add a bonding strip across the deck underside.
*!##+# PTSD!
105300
I can't even imagine why anyone would put plastic bumpers on a '68 Vert, when it would be cheaper just to buy a '74 or '75 Roadster.
However, I have heard of early Big block C3 Roadsters having really bad chassis twisting in low gear and their hoods popping up around 90 mph, however, since you are doing an in-depth body/frame restoration, you shouldn't have any issues. Hey built them very different in '68-'72.
Good luck!
(P.S. Are you going with side pipes?)
Good luck!
*!##+# PTSD!
Good luck!
guess what my Left hand-fingernails looked like after making the repairs yesterday....no problem----I removed it from them with 80 grit sandpaper...................
My morning routine for the past 18 months starting at 0530L has been:
1) Take a leak
2) Put on a pot of coffee
3) Take a leak
4) Read the sports section of the paper
5) Take a leak
6) Finish the paper
7) Take a leak
8) Login to CF
9) Scan "Views" looking for the 6 figure posts
10) Stop to read Doorgunner's & RVZIO's posts
11) Take a leak
With Doorgunner down to attaching the rear clip and paint; and RVZIO into the assembly mode...I'm not quite sure once your projects are completed how I'm going to adjust for that void other than continuing with # 1, 3, 5, 7, & 11 above!
I may need some serious CF consoling.
Regards,
Tom
1) Take a leak
3) Take a leak
5) Take a leak
6) Finish the paper
7) Take a leak
8) Login to CF
11) Take a leak
Regards,
Tom
I'm only on Phase IV (Front Chrome Bumper Mod) and V (Rear Chrome Bumper Mod).........I still have to get to PHASE X!
I managed to do more patchwork on the deck and quarter panels this morning before errands started.
First I needed to test the previous patches/repairs that I did.....so being a doorgunner, I took a screwdriver and poke/prodded/stabbed the patches a few times......THEY HELD!
So I patched the rest of the damaged areas.....not pretty/but stout.....
Since our grandson just started driving he needed somewhere to park........
Now to sand all the patches down for the filler.
!!!I did a couple hours of sanding and tapering on the repairs today....rookie work at best, but the golfball/baseball-size holes where I ground out bondo patches are filled and sturdy...........
The nasty looking oversized antenna mounting hole is filled in........................
I sanded/attempted to smooth out the inner years of repairs rather than leave all the lumps and bumps.....................
I did another test-fit of the tail light clip/good thing that I did....I added too much fiberglass to the driver-side quarter panel when I made the repair/no problem---I'll trim 2" off the trailing edge.......
Since the Parts Pegboard is full, I found a safe place for the lower front and rear valences.................LOL............ .......
Now I need to do the repairs to the tail light clip on each corner where the bumpers bolt on, and fill in the side marker light opening since the others have already been filled in by the previous owner.
I'm only on Phase IV and V.........I still have to get to PHASE X!
I like your spare tire!!! I don't think it was original in 68 though!
