Doorgunner's '68 Convertible Project
Old Oct 28, 2019 | 10:53 AM
  #5161
OldCarBum's Avatar
OldCarBum
Hey Tony,
Glad to see you are getting some work done on the Harley.
I've wired my share too.
What people don't realize is the fun part of doing it right is getting all those wires run from the switch housings, through the handle bars, through the forks and through the frame.
Fun times.
Stay healthy.
Old Oct 30, 2019 | 08:35 PM
  #5162
doorgunner's Avatar
doorgunner
2026 Loser of the Year
While the car is at the painter I decided to clean one of the door locks. To my surprise the mechanism INSIDE the door is the same quality as what you see on the outside...…the parts were greasy/corroded/tarnished……......…
I DECIDED TO SCRUB ON THE PARTS FOR ABOUT 45 MINUTES...….
The mechanism is assembled.....outside view and rear view below...........
I did manage to clean the inside of one of the dual gas tanks on the Harley.....no pics, but the inside was nasssssssty!
Old Nov 6, 2019 | 08:29 AM
  #5163
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Hey Doorgunner, who did you send it to for paint? Glad to see your project is still coming along nicely.
Old Nov 10, 2019 | 03:33 PM
  #5164
doorgunner's Avatar
doorgunner
Hey Sig...I was thinking about you....you're still in the same house? Hershel's Body & Paint is doing the work. He did a great job on my hood 2 years ago, but he has moved into a larger building/taken on more work, and is slower than Christmas.
The doors and body rearward have been ready for paint for 2 months.....but rainy-day insurance jobs keep bumping me down the list.
Sooooooooooooooo… in the meantime I'm working on the cap at my house...…..
prepping and tapering the edges of the triangular repair piece..........
The triangle is tapered and ready to go into place.............
Now...break is over......go back to work!
Old Nov 10, 2019 | 05:27 PM
  #5165
derekderek's Avatar
derekderek
there won't be a ridge on either side of that triangle patch? may want to lay up some extra glass under the patch edge in case you have to grind the seam lower. and LSU took care of bidness against that red algae bloom...
Old Nov 10, 2019 | 07:37 PM
  #5166
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Looks like youre enjoying some decent weather down there finally. Its in the 20's here in the mornings and warms to the 40's after lunch....snow and salt tuesday...
Old Nov 10, 2019 | 09:13 PM
  #5167
doorgunner's Avatar
doorgunner
You guys taught me that trick a while back...now every repair I make gets a "valley" on top which is filled in with 1' overlay per edge/then a valley underneath which is filled in with 1" overlay. per edge Then top and bottom is ground/sanded smooth.
Yep....Ole Miss was the top rival for decades against LSU....then after Nick Satan Saban bailed on LSU to go to the Pros/Alabama
we have had a grudge against him. They have hammered LSU often since our National Championship.
Payback was gooooooooood.
40's here at night...70's during the days.
Old Nov 11, 2019 | 08:56 PM
  #5168
moncal90's Avatar
moncal90
Nice to see you are still working on her DG. Btw, Happy Veterans Day and thank you for your service!
Old Nov 11, 2019 | 09:15 PM
  #5169
doorgunner's Avatar
doorgunner
Thanks moncal90......and right back atcha…..and if you didn't have to serve I'm happy for you!
I didn't work on the car today...had to help a friend at his machine shop....maybe tomorrow after lunch?
Old Nov 18, 2019 | 08:27 PM
  #5170
doorgunner's Avatar
doorgunner
I reached a stopping point on the Harley wiring rebuild so I put in an hour on the Vette clip...…..
About a month ago I cut out a bad section from the top of the passenger fender./then I shaped and beveled a repair piece..................
I'm checking the piece before I fiberglass it into place.....the repair piece in Pics 1 & 2 is reversed..............
I had to move the hood away from the repair area since it is already painted/I also moved the headlight repair panel away from the triangular repair piece in order to get a c-clamp on the second corner and third corners of the repair triangle.
I applied panel adhesive to the underside of the piece along the hood opening........then I filled in the beveled "vallley" with mat across one top edge............
Tomorrow I will remove the c-clamps and apply mat to the 2nd & 3rd corners. Then I will re-fit the headlight panel against the front edge of the hood and clamp the panel into place.
Old Nov 18, 2019 | 09:25 PM
  #5171
Jack605's Avatar
Jack605
Lookin good DoorGunner keep at it.
Jack
Old Nov 19, 2019 | 05:31 AM
  #5172
doorgunner's Avatar
doorgunner
Jack
Thanks Jack....lots going on down here....
V.A. says Liver damage...
this oughta' be fun...."Part 309"
of never-ending post-war lab-rat experiments
(Little-known Fact: More Vets Die From Post-War Crap than from Combat)
Old Nov 20, 2019 | 07:19 PM
  #5173
doorgunner's Avatar
doorgunner
I squeezed in another hour on the triangular repair and rough-sanded the long edge that I fiberglassed a few days ago. I will fiberglass the underside of the repair piece before I sand the top smooth...…….
All the strands are rough sanded away...………
The view from the passenger "seat" forward. The headlight panel is about 1/16" higher than the top of the fender/hood surround. When I apply fingertip pressure the two pieces match...…..
NOTE TO MYSELF: ALIGN DRIVER-SIDE OF HEADLIGHT PANEL BEFORE FIBERGLASSING PASSENGER SIDE OF THE REPAIR TOGETHER!!!
Old Nov 21, 2019 | 07:56 AM
  #5174
blue by you's Avatar
blue by you
Keep up the good work, it looks great
Old Nov 26, 2019 | 01:16 PM
  #5175
doorgunner's Avatar
doorgunner
Blue_ thanks. I've been going thru lots of med. tests lately/now two days sofa-time after bone marrow biopsy from left hip (thank you Agent Orange.gov) and have only an hour here or there to work on the car.
I did manage another hour which I tweaked the headlight panel on the Driver;s side more to get a netter fit on the Passenger's side...…….
Passenger's side after rough-adjusting top corner of headlight panel on the Driver's side fender...…..
The Drivers side top corner headlight panel where it meets the fender still has about 1" overlap which I need to rough-trim away and re-fit before making final trim cuts in order for tit top to lay flat with the top of the driver fender.......
Once the driver side fender top/headlight panel are bonded together I will cut away all the lower fender section "piled-on" fiberglass on the lower driver side and begin fitting the parking light repair panel into place/same thing with the passenger side fender.
I will install the hood hinges and hood surround gasket to level the hood surface with the hood surround & headlight panel before I apply any leveling adhesive to the fender tops.
NOTE TO ME: I also need to fit the headlight re-nforcement bar to the underside of the headlight panel once I am satisfied with the leveled areas.
Old Nov 26, 2019 | 01:43 PM
  #5176
SamTheSham's Avatar
SamTheSham
You definitely have your work cut out for you. Very brave to take this much work on. Good luck with the medical issues. Take care of yourself. Have to keep reminding ourselves we aren't as young as we once were.
Old Nov 26, 2019 | 02:41 PM
  #5177
C3_DH's Avatar
C3_DH
Man, I've been watching this thread... doorgunner, you are da man! No way would I jump into that fiberglass work! Keep at it brother!
To Doorgunner's '68 Convertible Project
Old Nov 26, 2019 | 08:10 PM
  #5178
doorgunner's Avatar
doorgunner
Thanks Members.....remember-I never touched fiberglass until I bought my 1st Vette Project car....Experienced Forum Members are guiding me thru the process!
Old Nov 27, 2019 | 08:43 PM
  #5179
doorgunner's Avatar
doorgunner
It's finally starting to resemble a Vette "nose"...………the driver side
"crusty" previous repair is cut out..............................
The passenger side which was fitted yesterday is bonded in place...….not "pretty" but very stout.....…...…...……...…...…
The driver side of the headlight panel is bonded in place......also stout........but ugly.….........….
The headlight panel is now bonded in place................................... .....
I accidentally got something right on the first try...………
Passenger side bumper reinforcement................
Driver side bumper reinforcement......…………………...…........
Center of headlight panel angle "right-on"...…...……......……...…...…..
Old Nov 27, 2019 | 10:30 PM
  #5180
OldCarBum's Avatar
OldCarBum
Tony,
Nothing ugly about the quality of work you are performing on that front end.
Very Nice as always!
Have a Happy Thanksgiving.
Be thankful for everything you have.
