Doorgunner's '68 Convertible Project
Old Apr 9, 2021 | 10:41 PM
  #5841
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by oldgto
YOU PEOPLE NEED HELPperiod
Old Apr 9, 2021 | 10:53 PM
  #5842
doorgunner's Avatar
doorgunner
In other news..........the engine stand is now a transmission stand.......
As my Recovery Room Nurse says........TAAAA DAAAAA!
ALSO......
since I am not an engineer....why would ANYONE put an upside-down drain plug....which will leave 2 qts. of used fluid in the bottom of the pan?
Old Apr 10, 2021 | 07:13 AM
  #5843
oldgto's Avatar
oldgto
OK.... I`m stealing this idea!
Old Apr 10, 2021 | 11:14 AM
  #5844
doorgunner's Avatar
doorgunner
Youtube video...........
The white metal tube needs to be about 20" long to allow for full end to end flipping of the transmission if it has a non removable bell housing
I need a T40+ to remove tne bell housing bolts on the 4L60E
Old Apr 10, 2021 | 12:46 PM
  #5845
MSGT-R's Avatar
MSGT-R
Thank you; you are a maintenance god!!
Old Apr 10, 2021 | 11:36 PM
  #5846
doorgunner's Avatar
doorgunner
Ohhh yeah......feast your little eyes on this Bubba-Test-Stand.......
May as well test everything at the same time (this went in my '34 street truck)
NOW....if I can remember to whom I loaned the test stand
Old Apr 13, 2021 | 11:28 AM
  #5847
MSGT-R's Avatar
MSGT-R
Start calling!
Old Apr 13, 2021 | 03:13 PM
  #5848
doorgunner's Avatar
doorgunner
Start calling!
Too many Borrowers.....Not enough memory I'll have to whip-up another one.
HOWEVER............
I could see how it happened....internal rod in the headlight vacuum actuator was broken off where it screws to the threaded clevis. I disassembled the actuator/drew a print of the original rod plus the missing threaded section.
Next stop was my friend's machine shop where I could machine a new rod......
( sure...I could have bought a new actuator...but where is the fun in that)...
Now.....a trip to the garage to thread the left end to fit the clevis/then reassemble the diaphram and canister.
3rd part from the left between flat washer & diaphram backing plate...remains of broken actuator rod
(pic is distorted because of "panning tool in my Kodak")
Also...I attempted to install the weatherstrip on the deck lid...and realized I never order the dog-leg rubber inserts that scew to the body channel which diverts water AWAY from the interior of the car
Old Apr 13, 2021 | 05:07 PM
  #5849
MSGT-R's Avatar
MSGT-R
IF you're going to lend tools, make a large white-board for the name, phone number/address, tool and date loaned.
I very seldom lend tools, but when I do, they had better be clean and back when promised.
Old Apr 13, 2021 | 10:08 PM
  #5850
doorgunner's Avatar
doorgunner
BRACE YOURSELF........I did (7 years ago). My grandkids wiped the board clean so they could draw pictures on it.
Old Apr 14, 2021 | 11:59 AM
  #5851
OldCarBum's Avatar
OldCarBum
My rule is I never loan tools.
After years of keeping to this, I loaned out my wheelbarrow to a friend who needed one to move a load of bark into his back yard.
One month later and several times asking for its return, I needed it.
I drove to his house, he wasn’t home, jumped his fence, grabbed my wheelbarrow, cut the lock off his gate and brought it home.
He was pissed.
Never again.
Old Apr 14, 2021 | 01:18 PM
  #5852
derekderek's Avatar
derekderek
ALSO...... since I am not an engineer....why would ANYONE put an upside-down drain plug....which will leave 2 qts. of used fluid in the bottom of the pan?
maybe because a recessed drain plug is better than a sheared off drain plug and NO fluid left in the pan? still beats the nonexistant drain plug in most tranny pans...
Old Apr 14, 2021 | 02:46 PM
  #5853
doorgunner's Avatar
doorgunner
Good point....I'll relocate the drain plug to the back- lower rear of the pan away from important stuff.
I'm going back to the machine shop today to fabricate an adapter that will connect the 4L60E trans to the 4L60(non-E) speedo-drive tailhousing.
Should be about $400 worth of fun/on Sale for $20 (price of the metal bar-stock)
Old Apr 15, 2021 | 12:44 PM
  #5854
MSGT-R's Avatar
MSGT-R
He was pissed.
Never again.
I loaned a Toyota repair manual and an 18MM 4x4 hub socket to a student of mine. Had to go and face him down too. Returned the book (dirty), and never found the socket.
Neighbor borrowed a M/C charger. Said that the battery was toast, wouldn't start. Now the charger is DOA. I suspect he tried to start the bike with the trickle charger attached. He pleaded innocence. It is more like stupidity.
Old Apr 15, 2021 | 02:21 PM
  #5855
The Phantom's Avatar
The Phantom
So the lessons for today class ... if you lend something, plan on it being gone never to be seen again!
Or “never a lender nor a borrower be!”
I know, I know we are all great guys and just can’t help ourselves and that’s all I have to say bout that.
Dave
Old Apr 15, 2021 | 03:52 PM
  #5856
loup68's Avatar
loup68
Army
I had a neighbor kid about 19 years old keep borrowing my tools. He would borrow one or two tools and return only one. He kept doing that, borrowing something else and only returning one or two. My most expensive tool was a flex-head 1/2" drive long handle ratchet that I received as a Christmas gift from my girlfriend. He borrowed that along with a couple of other things. One day I went to use the ratchet and realized he had borrowed it and not returned it and I had not seen him around for a couple of months.
I went and talked to his mother and she said that he had joined the Navy and was gone! Lou.
Old Apr 16, 2021 | 12:41 AM
  #5857
doorgunner's Avatar
doorgunner
Come to think of it....in '72 I loaned some ammunition to the left doorgunner ....he used every bit of it.......
then he wanted more
To Doorgunner's '68 Convertible Project
Old Apr 16, 2021 | 10:00 AM
  #5858
doorgunner's Avatar
doorgunner
I didn't go to the machine shop yesterday/I only have dimensions for the 4L60E face of the adapter.
I'm still waiting on the speedo housing to arrive by UPS so I will have the dimensions for it to transfer to the adapter.
I decided to make one trip instead of two to the machine shop.
Old Apr 16, 2021 | 07:24 PM
  #5859
OldCarBum's Avatar
OldCarBum
I had a guy ask for some ammunition once, so I gave him some.
He looped around and asked for more, so I gave him more.
Guess he got enough, because he didn’t loop back around again.
Old Apr 17, 2021 | 12:36 AM
  #5860
doorgunner's Avatar
doorgunner
then he wanted more
Before we took off I told him he needed 3,000 rounds (Two 1500 round ammo cans...if I remember correctly).
He said that was too much weight to lug around.
He ran out and demanded more.
I told him to use his * * * *ing bayonet.
