Doorgunner's '68 Convertible Project
Old Apr 19, 2021 | 07:07 PM
  #5861
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I manage to go to the shop today and machine the chunk of steel to mate with the 4L60E case........
My next trip will be to machine the other end to mate with the 4L60 mechanical speedo-housing....drill/tap bolt holes....machine flats on the adapter.
Old Apr 19, 2021 | 11:10 PM
  #5862
doorgunner's Avatar
doorgunner
Annnnnd...the cable-drive speedo-housing came in about 8:30pm......a couple coats of spraycan Metal Blast put the shine back on the housing.....
Old Apr 29, 2021 | 01:29 PM
  #5863
doorgunner's Avatar
doorgunner
I'm back at home after attending a conference in Florida.
I made a quick trip to the garage to disassemble the drums in the 4L60E transmission/I'm still trying to learn the terminology for the individual pieces.
I had to fabricate a $120 spring compressor to disassemble the drums/
REVERSE somethin'/somethin'.......
MAIN SERVO somethin'......
FORWARD somethin'/somethin'
I will order a Seal/O-ring Overhaul Kit this week and reassemble the Reverse Drum and output shaft.
Then I will be able to verify the thickness of the adapter I am machining for the new tailshaft housing to make sure the speedometer Drive gear and the Driven gear mesh.
Meanwhile I still need to install the weatherstrip pieces for the deck lid......
Old Apr 29, 2021 | 02:04 PM
  #5864
derekderek's Avatar
derekderek
get those weatherstrip pieces in wrong it will seriously hamper the 2-3 shift...
Old Apr 29, 2021 | 06:44 PM
  #5865
doorgunner's Avatar
doorgunner
R. U. rrr=elated to ABBY NORMAL?
Old Apr 29, 2021 | 08:27 PM
  #5866
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Old Apr 30, 2021 | 11:37 PM
  #5867
doorgunner's Avatar
doorgunner
"While I was at it".....
I just updated the last FORTY pages of "The Table of Contents" in my thread........
just in case anyone needs to know HOW NOT TO DO SOMETHING!
9/10/2013.................
NOTE: When I started this thread, I had no idea of what life had in store...so this is turning into more than a build-thread.
I'm new to Corvettes and want to buy a very neglected '68 convertible near my home with late '70s front & rear bumpers....
Side note: I've had the "fever" since 1968 when I saw that $4,550 red Corvette on the showroom floor at the local dealership.....and ended up with the $2,695 1969 Camaro convertible that was sitting next to the Corvette!
I'm not trying to "restore" to a factoy look since the car is a "basket-case" vehicle......I have no bodywork experience.....just want to get the body back to 1968-looks....and have a D.D./keeper just for me.....
Thanks for any input/threads-to-read...since I'm learning as I go....
Some of the experimental mods that I try on this car would NEVER EVER be tried by me on an original car!
Build Date Dec 14, 1967
Time for a TABLE OF CONTENTS!
Advice/Finding the "Right Car".................................... ......pg. 1-2
Bringing "her" home.................................... ..................pg. 3
Removing interior & Re-insulating/soundproofing..............pg. 4-5
CAI (kinda')/Seat covers/Alternator mods.........................pg. 6
Temporary Exhausts/Seat covers/Salvage yard Vette.........pg. 7
More CAI/Cooling fan mods/Brake rebuild.........................pg. 8
Brakes/Differential/Trailing Arm Rebuild............................pg. 9-10
M. Cylinder/Distribution Valve/Re-center Differential Prob...pg. 11
4 Wheel Alignment and Problems................................ .....pg. 12-14
Suspension Alignment/Springs/Shocks/ChitChat................pg. 15-17
"Straightening Bubba's" Trailing Arms/Interior Carpet........pg. 18
Oil Pan Leak/More Suspension Repairs/Damper repair........pg. 19-20
Exhaust Wrap/Infra-red-Gun readings..............................pg . 21-22
Seat Covers/OilPan Gasket/Seat Covers............................pg. 23-25
Cooling system cleaning/RANT!/Gatlinburg Trip..................pg. 26-27
Sandbagging warped hood/Idle Chit Chat..........................pg. 28-29
Engine Overheating/Son and Depression/Seat Belts............pg. 30-32
Exhaust Mods/Softtop S. Carolina Trip/Top Rebuild..............pg. 49-52
Softtop Rebuild................................. ..............................pg. 53-57
Steering Column Rebuild................................. .................pg. 60-62
Allergy Treatment aarg/Broken Door Locks.........................pg. 63-64
Car Alarms/Parachutes/Projects................................ .........pg. 65-67
Rebuilding Door Mechanisms/Door Lock Rebuild...................pg. 68-69
Door Panels/Car Show/Speedometer Gears/ChitChat.............pg. 70-71
Passenger Door Panel-Again/Veteran's Discussion..................pg. 72
Calo69 Car Show Pics (lots of Vettes/etc.).............................pg.73
PTSD/Rant/Encouraging Members/Back on Track....................pg.74-76
SOLD '34 Truck/New grills/engine harness...P/B conversion......pg.76-77
P/B conversion/TH400 Re-wired................................... ..........pg. 78
Speedometer glitch-repair/cooling fan delay-relay(s) upgraded...pg. 79
New CAI Plenum/New-larger steering wheel.............................pg. 79
CAI and sidepipes............................... ..................................pg. 80
Steering wheel/sidepipe install/CAI..................................... ....pg. 81-83
Distributor problems........AGAIN................... .........................pg. 84
Distributor electric parts rebuild................................. .............pg.85
Rebuilt distributor installation/timing.................................. ...pg. 86-87
Upgrade to electric fuel pump.................................... ............pg. 87
Chrome FRONT Bumper Conversion/Click here for the condensed shortcut: https://www.corvetteforum.com/forums...post1590451458 ...pg. 88-93
Conversion Discussions/Cutting Fiberglass Grill Off.............pg. 93-95
Two Year Review of the Build................................... ........pg. 96
Chrome REAR Bumper Conversion/Click here for the condensed shortcut: https://www.corvetteforum.com/forums...post1590630203.......pg.97
More useful advice about fiberglass replacement..................pg.98-104
Motorcycle Discussions (while waiting for parts to be delivered)...pg. 105-106
Enlarging Cargo/Trunk.......pg.107-109
(click here for condensed Shortcut): https://www.corvetteforum.com/forums...post1590742891
More Chrome Front Bumper Modifications........................... ...... pg. 110-111
Fuel Tank Custom Modification/Click here for condensed Shortcut...........https://www.corvetteforum.com/forums...post1590803576 ...pg. 112-116
Tail light Clip Conversion.............................. ......................pg. 116-118
PTSD Chit Chat.................................... .......................................p g. 118-127
More Tail light Clip Conversion.............................. ........................pg. 128-130
More Enlarging Cargo/Trunk Area.................................... ..............pg. 131-135
More Tail Light Clip Conversion.............................. .......................pg. 136-137
Deck Lid Restoration............................. ........................................ pg. 137-139
Body Lift/Body Mounts & Reinforcement Repair/Replacing Front Crossmember and Braces........pg. 140-145
(for shortcut clik on the link to the right): https://www.corvetteforum.com/forums...post1591645717
Humorous Story About Visit to V.A. Hospital..............(Click on quick-link https://www.corvetteforum.com/forums...post1591683265) ......................pg. 143
Fabricate Support for oversize Radiator...............................p g. 146
Driver-side Fender Support Repair.................................. ....pg. 147
Test-Fitting Front and Rear Bumpers................................. ...pg. 149
Shimming Body Mounts for Door Gaps.................................pg. 150
Family Illness................................. .................................pg. 151
Family Tragedy................................. ...............................pg. 153-157
Emergency Sale of our house/packing to move away............pg. 158-160
More Tragedy................................. .................................pg. 161-162
Great Flood of 2016.................................... .....................pg. 163
Moving to In-law's during the Flood................................... .pg. 168-169
Trip to New Orleans and to Car Show..................................pg . 170-171
Fuel tank testing and fitting under car.................................pg.1 72-174
Support for Tank fabbing and fitting................................. ...pg. 175
Replacing rotted rear Cross member.................................. ..pg.176-177
More tank fitting with new crossmember............................. ..pg. 178-179
In-laws are united in Heaven.................................. .............pg.180
Moving to new home/new garage for Vette............................pg. 181
Moving Vette to new home/New garage & boxes....................pg.182-184
Repairing Rag-joint/Chit-Chat/New Sand Blasting Cabinet........pg. 185-186
Moving equipment into new garage/re-installing side pipes......pg. 187-188
Garage A.C./Insulation/new pegboard walls...........................pg. 189-190
Roadtrip (less Vette) to California.............................. ...........pg. 190-191
Hoist for hardtop added to garage.................................. .......pg. 192
Loading pegboard walls with Car/motorcycle parts...................pg. 193-194
Studying front Clip/work on Tail Clip/Repair cracked door jamb..pg. 195-196
Bonding exhaust panel to body/Fitting rear chrome bumpers.....pg. 196-199
4 year Review of work done so far..................................... .....pg. 200
Forum Chit-Chat with friends................................. .................pg. 201-203
Lowering garage onto slab after removing sub-floor...................pg.203-204
Painting garage floor/Bolting garage to slab..............................pg. 204-206
My Son's Memorial Day/Me learning to use a Wheelchair!............pg. 207
Forum Chit-Chat about Life.................................... ..................pg. 207-208
Repairing rubber fuel lines in engine bay...................................pg . 208-209
Forum Chit-Chat/Learning to use wheelchair in garage................pg. 209-210
Snow Storm of 2017/Forum Chit-Chat/Christmas 2017................pg. 211-216
Can't walk/Spine Surgery/Recovery/Chit-Chat............................pg. 214-216
First day on project since Surgery................................. ............pg. 216
Exhaust panel fitting/Finishing with body filler.............................pg.21 6-220
Door Gaps/Exhaust panel/Door Gaps.................................... ......pg.220-222
Garage Addition/Forum Chit-Chat/Garage addition/Door Gaps.......pg. 222-227
Deck lid/hinges/body gap repairs................................. ..............pg.227-232
Fitting rear bumpers to "new" tail light clip..................................pg . 232
Installing steel drain tubes under the deck...................................p g. 233
Leveling gas door with top of deck.................................... ..........pg. 233-234
Cutting new offset holes/installing rear marker lights.....................pg. 235
PTSD causing problems AGAIN................................... .................pg. 235-236
Steering column repair-rework......….........…......………........ .…pg. 237
Carb Backfire-readjust seat and floats/Chit-Chat...……...……..pg. 238-240
Bringing the car to the Paint Shop.................................... ............pg. 241-244
Re-organizing the garage and pegboards/collecting repair panels for nose...pg. 245-246
Rebuilding Harley/20 year update. Repairing tail lights and headlight mechanisms...pg 247-248
More headlight repair and Harley rebuild pics.....pg.249-250
Removing front clip/replacing fender side vents with correct style louvers...pg.251-252
Taking measurements/getting repair panels ready/removing '76 pieces/adjusting rear bumpers/repairing front clip/repairing fender wells...pg. 253-254
Repairing fenders/installing used headlight panel/fabricating radiator support for aluminum radiator...pg. 255-257
Roughing-in front bumper and grill/roughing-in hood/setting angle of headlite panel...pg. 258
Rebuilding door lock assemblies/more fender repairs/correcting wide wheel well arch...pg.259-261
Doors-Deck Lid-Body are at body shop 7 months and painted................................. .......pg. 262-268
Rebuilding tailites/Installing bumpers-license plate surround/ Vent Grills/Rewiring Brake Lites...pg. 263-268
Installing rear marker lites/Installing Deck Lid/Installing Reverse Lites............................pg. 269-272
More Tail lite rewiring/Installing installing gas tank (again)................................. ...............pg. 272-274
Forum Members Chit-Chat/Building door installer support/More Chit-Chat/Installing doors...pg. 274-278
More Forum Chit-Chat.................................... ........................................ ........................................ .pg. 279-282
More Tail Lite rewiring/More gas Tank Installation/Fabricating hidden filler neck for gas tank...pg. 283-286
New Sill Plates/New wheel trim rings/New Evap Canister/Repair headlite Actuators-Etc/....pg. 286-287
Make Test Bench to repair Headlite Vacuum System.................................. ...........................pg. 288
Repair-Recover Interior Trim and console pieces.................................. .................................pg. 289
Rebuild Parking Brake System.................................. ........................................ ........................pg.289-292
Begin 4L60E Automatic transmission Disassembly............................. ...................................pg. 292-294
(to be continued.......if God says the same!)
Old May 1, 2021 | 10:38 AM
  #5868
OldCarBum's Avatar
OldCarBum
Wow Tony!
You didn’t write a build thread, you wrote a novel!
I can’t wait to see the final chapter.
Old May 1, 2021 | 05:19 PM
  #5869
doorgunner's Avatar
doorgunner
Wow Tony!
Then the Chapter on ROAD TRIPS begins
562000
Old May 1, 2021 | 05:25 PM
  #5870
JMH's Avatar
JMH
Thank god my best friend owns a tranny shop !
Old May 1, 2021 | 07:24 PM
  #5871
doorgunner's Avatar
doorgunner
No problem....it has less than 200 individual pieces that can be installed 400 different ways
Old May 1, 2021 | 08:00 PM
  #5872
loup68's Avatar
loup68
Army
You are one brave sucker, Tony! I wouldn't even think about taking an automatic transmission apart. Lou.
Old May 1, 2021 | 08:20 PM
  #5873
Rescue Rogers
Apart is the easy part. I take stuff apart all the time. Its pretty cool that when I put stuff back together I find all the extra parts that the engineers threw in there that wasnt needed. Most thing make alot of noise afterwards though...dont know why
Old May 1, 2021 | 09:31 PM
  #5874
doorgunner's Avatar
doorgunner
In 40 years I've collected a quart jar of "left-over" parts.....as soon as I remember where they fit...I'll (re)install them...(I red that somewhere)
but....so far....everything is still working without 'em.
(I am learning that the camera remembers everything)
Old May 2, 2021 | 10:38 AM
  #5875
OldCarBum's Avatar
OldCarBum
We done all graduates and alumni of BTU!
Bubba Tech University
Old May 4, 2021 | 12:17 AM
  #5876
doorgunner's Avatar
doorgunner
Update....the 4L60E rebuild kit came in.......this oughta' be fun.........
Old May 4, 2021 | 11:12 AM
  #5877
Elcransonator's Avatar
Elcransonator
Holy F*ck!!! Godspeed Doorgunner!!!
To Doorgunner's '68 Convertible Project
Old May 4, 2021 | 12:29 PM
  #5878
derekderek's Avatar
derekderek
some of that looks like it wants you to hang it on the wall and shoot at it. this is an e. what are you controlling it with?
Old May 4, 2021 | 05:53 PM
  #5879
doorgunner's Avatar
doorgunner
I appreciate it!
It wont be moving...I'll never hit it.
Well
....I have a choice between a $500 transmission controller......and a $60 gizmo that I have to learn how to write a program for. I'd rather do TWO rebuilds that write a program ("Old Dog/New Tricks" )
So...what Ima gonna do is do dry rebuilds on the trans using the original parts until I get the time down to One/1 hour
Annnnd I'll villeo it to prove it happened
Old May 4, 2021 | 06:05 PM
  #5880
derekderek's Avatar
derekderek
as easy as it is becoming to find 4l60 and 4l80 trans it may be better to use them with a standalone controller over a 700r that may have been redone 5 or 6 times...
