Doorgunner's '68 Convertible Project
Old Sep 12, 2024 | 10:38 PM
  #7361
doorgunner's Avatar
doorgunner
2026 Loser of the Year
No work-ee on car today...I chased generator parts since the 'cane knocked out our electricity and both gens' went south/no spare parts available
Old Sep 12, 2024 | 10:53 PM
  #7362
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Ain't that always the way! Both generators drop out at once! And, no parts. Geeezzz,
Old Sep 13, 2024 | 05:14 AM
  #7363
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You've got my luck
Old Sep 13, 2024 | 06:12 AM
  #7364
doorgunner's Avatar
doorgunner
As long as the Gremlins stay away from the Vette!
Now that the stores have electricity I need to get a trans cooler...so fluid wont soak the shop walls. I need to connect the radiator-burp system/
install trans cooler/
set timing/
shift TH400 thru gears/
etc.
C'mon 7:30 a.m.- parts stores open
Old Sep 13, 2024 | 07:48 AM
  #7365
Rescue Rogers
Woohoo.....getting closer to running!!!!
Old Sep 15, 2024 | 12:51 AM
  #7366
doorgunner's Avatar
doorgunner
A little more work on the coolant hoses...(Don't tell anyone about my top secret cold air system)
Oversize aluminum radiator....
Pusher/Puller fans flow good after installing the puller fan with a 10 second ON-Delay relay to keep both fans from overloading the alternator (per member DBL TRBL )
Old Sep 15, 2024 | 04:40 AM
  #7367
4-vettes's Avatar
4-vettes
Top secret! Well, no worries Mate. I won't tell a soul.
Putting it up on the internet might be a issue however! Perhaps no one will look.
Old Sep 15, 2024 | 11:37 AM
  #7368
doorgunner's Avatar
doorgunner
And I thought this was a Members-Only site.
Back to the garage to put some coolant in the system and crank it to set lifters and timing after swapping heads.
EDIT: Didn;t happen...I needed to wire the coil/distributor/6 v. resistor/Starter
EDIT: Didn't happen today Monday.
Old Sep 16, 2024 | 05:42 PM
  #7369
doorgunner's Avatar
doorgunner
No cranking again today...
I needed to rewire/wrap the DIY electric fans harness,
While I was at it I removed all the un-needed wiring.
I also used "Yall's" advice and DIY'd a 1" thick circular spacer, then upgraded the cabin blower motor.
I couldn't force foam into the gaps between the radiator and the support,,,so I HVAC taped the gaps...
Time to call it a day..."It's a Day".
Where's the Tylenol...I have one of those wiring headaches
Old Sep 17, 2024 | 10:17 AM
  #7370
BigBlock77's Avatar
BigBlock77
Wiring headaches... Just saying the first word induces the second word. Best of luck!
Old Sep 17, 2024 | 07:59 PM
  #7371
doorgunner's Avatar
doorgunner
I don't know WHAT I'm going to do......................with ME?
The object of the game WAS to get the engine running and alt. charging...not so, ADHD/PTSD took control.
I separated the tie-wrapped wires at the alternator and the horn relay all the way to the firewall plug in order to wrap them with correctly with non-adhesive harness tape...didn't happen.....
The ADHD said "Hey...rewrap that light harness first"...so I did....I replaced damage wires from a spare harness I had-then I used the harness wrap to make it like new again....That's a lonnng harness.....
Oh well...at least something got did/done.
Old Sep 18, 2024 | 05:34 AM
  #7372
Rescue Rogers
You are still winning!!! At least you are out in the garage working, that's a big plus. You'll get there, we got your back!!!
Old Sep 18, 2024 | 05:47 AM
  #7373
4-vettes's Avatar
4-vettes
Step by step, your getting there!
Old Sep 18, 2024 | 08:04 PM
  #7374
doorgunner's Avatar
doorgunner
My lower spine officially had enough...it needed some help with the heavy stuff....swivels / folds away
Now....back to the alternator wiring.
Before.......
After...it looks better than it looks....horn relay and dual fan relays...
Old Sep 18, 2024 | 08:26 PM
  #7375
Rescue Rogers
I modified an older version to lift and have the crank cable. It didn't go high enough for a motor either...I took it out of the truck last year when I thought I had to junk it...but It passed safety so I fixed the other issues. Now I gotta hope it passes next week
Old Sep 18, 2024 | 11:23 PM
  #7376
doorgunner's Avatar
doorgunner
I got the H.F. 12V hoist and boom on sale. At its highest point it clears the bed by 53 inches, The electric hoist will allow me to pick a transmission off the ground and lift it 2" above the bed...an engine would probably clear the bed by a foot.
I need a pulley to mount on the end of the boom to feed the hoist cable through...and 15' of 12 ga. wire to run to the starter + connection.
Old Sep 19, 2024 | 07:55 AM
  #7377
litevette's Avatar
litevette
I just joined in, starting last night, reading your thread here. Great job getting everything to this point. Looks like you are super close. I’m sure the excitement is building, knowing it will be on the street soon!
To Doorgunner's '68 Convertible Project
Old Sep 19, 2024 | 12:33 PM
  #7378
doorgunner's Avatar
doorgunner
litevette....Thanks! I should have completed it 12 years ago,,,,but Life!
I owe the Forum members 100% of everything I have done correctly (I screwed up enough on my own).
By the way...I blame the PTSD on the fact that I have done the restomod/restoration BACKWARDS.
Old Sep 19, 2024 | 03:00 PM
  #7379
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
That's certainly one heckuva lift - hope it can do all you hope it does. Hang in there and keep up the good work. The finish line is out there somewhere even though I find that it keeps moving...
Old Sep 19, 2024 | 05:59 PM
  #7380
litevette's Avatar
litevette
I get ya! Life & doing things that set us back. I’ve certainly been there. Despite that though, you have persevered. I let too many go in the past due to either life, lack of funds, lack of knowledge or losing that luvin feelin. Sure wish I could have some of them back.
