Doorgunner's '68 Convertible Project
Old Aug 14, 2024 | 11:07 AM
  #7321
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Not surprised anymore, does it have a country of origin on the package?
The combo was well made by Echlin but the condenser which is attached to the points plate could have been made in Bejing.
I'll get a separate points and condenser this morning and watch out for country of origin-not that that means much.
Ahhhhh PTSD/Brain /fog...isn;t it great!
Old Aug 14, 2024 | 03:51 PM
  #7322
doorgunner's Avatar
doorgunner
I returned the A Z points/condenser combo and bought separate point and a condenser from NAPA.
The engine fired up and ran about 15 seconds until it used the gas in the carb.
(The engine normally runs on a 5 psi electric pump at the tank).
I tried to upload the video to YOUTUBE but it wouldn;t accept it.
Anyhow...now that I'm sure the engine is debugged I can hook my new hoist to it and install the TH400 trans...
Then back in the engine bay it goes to be connected to the electric pump and fuel return line and set the timing
Brain damage...it took only two days to get the engine running
Old Aug 14, 2024 | 04:34 PM
  #7323
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Good thing you had an extra condenser...I would never had thought of it causing a starting issue
Old Aug 14, 2024 | 07:47 PM
  #7324
loup68's Avatar
loup68
Army
Years ago, I was in Corvette Cleveland Corvette Club. A woman's car stopped on a busy street in front of a member's house that I knew. He happened to be an engineer at our local NASA.
He raced a C-2 at Nelson's Ledges road course. He checked it out and I think that she had just had a tune-up very recently. It was a bad new condenser and he put a used one on and she drove away. Lou.
Old Aug 14, 2024 | 11:10 PM
  #7325
doorgunner's Avatar
doorgunner
Lou...I have an extra set of points, rotor cap, and a condenser that will go in my travel tool box
I did a little more re-wrapping of the easy wiring....and a pack of new firewall grommets....
I saved the driver-side wiring for tomorrow before I reinstall the engine/trans,,,,,
WHEW!
Old Aug 15, 2024 | 10:29 PM
  #7326
doorgunner's Avatar
doorgunner
Forget the driver side rewiring today I found a couple more holes in the tunnel while I was scraping the grime off the fiberglass/patched the same.
I put a coat of rattlecan Gloss Black on the tunnel-it's ugly but it resists oil and grime/easier to clean...but UGLY.
Now for the dust on everything. I got tired of dusting all the new paint off so I bought some Dollar Store clear shower curtains to cover stuff.....
As my Emergency Room Nurse said...."Taaa Daaa !"
Old Aug 16, 2024 | 05:13 AM
  #7327
Rescue Rogers
Good idea!!!
Old Aug 17, 2024 | 01:17 PM
  #7328
doorgunner's Avatar
doorgunner
Well...I scraped all the grease and grime off from the lower firewall and frame to the crossmember at the kickups...wiped it all down with acetone and applied 3 rattlecans of Gloss Black Enamel to the frame/tunnel/underside of the floorboard.
NO pics...the Gloss Black looks to ugly to be photo'd.
I am going to the garage with my new-to-me engine hoist and bolt the TH400 to the engine for installation into its happy place.
SAMPLE PIC......
Be back in an hour or two with pics/
Old Aug 17, 2024 | 05:42 PM
  #7329
doorgunner's Avatar
doorgunner
BEFORE.....
AFTER.......
I bolted the TH400 to the engine and managed to use my 150 (-20) lb. body weight to roll the assembly over the chassis....
Lunch time! Maybe I will bolt the assembly in place after a time-out from our sponsor.
Old Aug 17, 2024 | 11:00 PM
  #7330
doorgunner's Avatar
doorgunner
I'm back...ran out of matching nuts bolts washers but install it anyway.
It was 3/8" too low at the tailshaft/installed a spacer and snugged everything up.
PAY NO ATTENTION to the ugly Gloss Black......OR the nasty garage floor......
Old Aug 18, 2024 | 07:25 AM
  #7331
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The gloss black is beautiful. We're not at all concerned with your garage floor!
We tune into this channel to see the fantastic automobile!
Old Aug 18, 2024 | 10:49 AM
  #7332
Vibguy's Avatar
Vibguy
There is nothing wrong with gloss black. My TR4 has a gloss doghouse, did semi-gloss on the C3, flat on the F250 and I am now using low gloss on a Mustang. I think now my favorite is the low gloss, but the gloss sure cleans up nice.
Old Aug 18, 2024 | 12:26 PM
  #7333
doorgunner's Avatar
doorgunner
OOOOOPS......One of my installation pics didn't load onto my thread......
The gloss black just shows every pitted area but the upside is it's so easy to clean.
It took an hour to smooth out the engine crossmember and paint it....then I spilled a little acetone on it and the paint on the right side wrinkled.
Ohh well...practice practice ............
Old Aug 19, 2024 | 04:57 PM
  #7334
doorgunner's Avatar
doorgunner
No pics today. I spent 5 hours cleaning out a month's worth of trash, sand, dirty paper towels that accumulated while giving the engine, trans., engine bay, tunnel and crossmembers a good cleaning and painting.
Later this afternoon I'll replace the worn nuts/bolts that hold the trans in place at the crossmember, the shifter cable, kickdown wiring, etc while the car is still on jack stands.
Old Aug 20, 2024 | 02:13 AM
  #7335
OldCarBum's Avatar
OldCarBum
Looks fabulous!
Old Aug 20, 2024 | 12:44 PM
  #7336
doorgunner's Avatar
doorgunner
Looks fabulous!
Thanks Members and ........O.C.B.---I'm good with a camera
Old Aug 20, 2024 | 08:18 PM
  #7337
doorgunner's Avatar
doorgunner
Today was a slow day....chasing xmsn filters, ordering new u-joint straps-----
I bagged and tagged the original ones for sandblasting---and then LOST the bag.
Anyhow I installed the new trans filter....the 10 year old shifter cable....the speedometer cable and touched up the pan just enough for the paint to try to wrinkle in spots
*I can never get away with using to different brands of rattlecan paint
IF I would have TRIED for wrinkles it wouldn't happen!
To Doorgunner's '68 Convertible Project
Old Aug 22, 2024 | 01:47 AM
  #7338
OldCarBum's Avatar
OldCarBum
You aren’t the only one!
Old Aug 23, 2024 | 11:20 PM
  #7339
doorgunner's Avatar
doorgunner
Tiny steps.....the CORRECT u-joint straps/bolts came in.....
How did I manage to buy a can of Gloss Black fine-metal flake paint?
Old Aug 24, 2024 | 11:55 PM
  #7340
doorgunner's Avatar
doorgunner
Today was a Bad day. My wife's puppy of 14 years died of heart failure this at 6 am morning while I was bathing her. My wife is out of town for 2 days. It was very sad/she was a small dog and very affectionate.
See you in Heaven Lexi
