Doorgunner's '68 Convertible Project
Old Dec 9, 2025 | 11:16 PM
  #8321
OldCarBum's Avatar
OldCarBum
We are all busy this time of the year.
Mrs. Claus has me checking the list twice again this year which leaves me no time to work on the Corvette.
I don’t trust the elf’s to do the quality of work I expect from myself and they are always on a hot cocoa break.
ho ho ho humbug
Old Dec 10, 2025 | 02:11 PM
  #8322
doorgunner's Avatar
doorgunner
2026 Loser of the Year
The elves are good at finding misplaced parts and pieces while I'm hanging Christmas decorations...
then hanging them on the pegboard where I can find them!.
Old Dec 10, 2025 | 03:31 PM
  #8323
litevette's Avatar
litevette
I'd rather elves than gremlins any day! 😂
Old Dec 10, 2025 | 05:12 PM
  #8324
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Elves would be nice
Old Dec 10, 2025 | 09:01 PM
  #8325
OldCarBum's Avatar
OldCarBum
What?
You guys don’t have Elf’s?
You must be on the naughty list.
Hang on, let me check!
Yep, just what I thought, you’re all on my naughty list!
Old Dec 11, 2025 | 05:23 AM
  #8326
Rescue Rogers
Thats awesome!!!!
Old Dec 11, 2025 | 08:23 PM
  #8327
doorgunner's Avatar
doorgunner
YOU GUYS STOP IT RIGHT NOW!
FRED FLINTSONE gUIDE TO EXTENDING FENDER LENGTH SO WHEEL IS CENTERED IN FENDER ARCH:
1. Rob the lid off one of your wife's...errr...your only wife[s storage bin.
2. Piece the lid together to rough-fit the contour of the door.
3. Mark the area to be cut off (allow for extra.
4. Cut the template to rough size.
Use a red marker to draw trim line on the fender extension.
7. Use a small-blade saw to trim excess material off of the fender extension.
8. Grind down high areas and fill in low areas on the extension tomorrow.
8. Fit the fender tomorrow and finish-trim the extension as needed.
Old Dec 11, 2025 | 10:42 PM
  #8328
doorgunner's Avatar
doorgunner
Anybody besides me get ads before they log in?
Old Dec 11, 2025 | 10:55 PM
  #8329
OldCarBum's Avatar
OldCarBum
I must be doing something wrong.
I don’t get adds but could welcome seeing more of the ones you’re getting
Old Dec 11, 2025 | 10:59 PM
  #8330
doorgunner's Avatar
doorgunner
Don't tell my !!!!
Old Dec 12, 2025 | 04:09 PM
  #8331
doorgunner's Avatar
doorgunner
2nd attempt of extending render....NOT PRETTY, BUT PRETTY STOUT THIS TIME.....
High areas are ground down/low areas are built up.....
A little more building up.....
Let it cure tonite and grind new high spots.
Old Dec 13, 2025 | 07:44 PM
  #8332
doorgunner's Avatar
doorgunner
It's time for some fitting on the passenger side.....level at the 2" x 4"....CHECK!
LeveL, at the headlites....CHECK!
(When I first bought the car I didn't realize the driver side fender crest was 1" lower than the passenger fender crest...I have to keep an eye on it/correct it as I fit everything. Also the center of the nose was offset to the driver side by 1" )
I DO have a 1&1/2" gap to fill in on the top of the driver fender (had to cut it off to prevent back surgery)
I need to stretch a string from the firewall to the center of the nose to keep everything square/parallel.
1&3/4" space between fender arch and the wheel front and back....CHECK!
SCAREY,,,,,HUH?!
The overbite on the passenger fender shows the massaging that needs to be done to get the contour on the fender the same as the other fender.......
I think I may have knocked down that PTSD Wall this time.
Wheel C!
Old Dec 13, 2025 | 07:54 PM
  #8333
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
That's a heap of work Mate. Looking good though. Can't wait to see it in paint!
Old Dec 13, 2025 | 07:59 PM
  #8334
doorgunner's Avatar
doorgunner
Thanks for the back-pat.
IF the PTSD holds off long enough I may have it assembled and the hood fitted, too. m The hood is already painted but needs 8 years of dust and overspray buffed off it.
WHEEL C!
Old Dec 13, 2025 | 11:19 PM
  #8335
OldCarBum's Avatar
OldCarBum
Nice!
It looks like a C3!
Old Dec 14, 2025 | 09:18 AM
  #8336
litevette's Avatar
litevette
Coming together nicely Tony!
Old Dec 14, 2025 | 09:45 AM
  #8337
doorgunner's Avatar
doorgunner
Thanks a bunch, Guys. I'm going stretch the centering string from the firewall to the V on the nose/take some measurements left and right from the frame to make sure the tip of the nose doesnt shift while I fab some pads for thr verical supports I made months agp...the supports/pads will bolt to the headlight bar and lower frame crossmember. then I can finish the contour of the fender extension where it meets the front of the door.
That's the plan for today.
Wheel C!
To Doorgunner's '68 Convertible Project
Old Dec 14, 2025 | 05:48 PM
  #8338
doorgunner's Avatar
doorgunner
Change of plans I forgot the garage has a 1.5” slope left side to right side
All my measurements are no good so I put a 1.5” block under the front wheel to level the frame
Gotta gone now.
I'm back (Monday morning)....
The top small sectiom of angle iron has been drilled and bolted to the headlite support bar......
I need to reove some shims from one support brace to get the headlite bar level (was in to much of a hurry)
Old Dec 15, 2025 | 09:44 AM
  #8339
c1nicole's Avatar
c1nicole
Wow T 🤩
always impressed with your work! Nice.
wouldn’t mind those feather pants above. 😉 tell my hubs to get those for Christmas.
Old Dec 15, 2025 | 05:11 PM
  #8340
doorgunner's Avatar
doorgunner
I got all the bugs out as far as level and squareness go (the camera distorts the bubble off-center)......
The pics aren't much different but the side-to-side was adjusted 1" to the passenger side...
This measurement is from the passenger upper control arm to the centered-string...
This is the measurement from the driver upper a-arm to the string......1/16" difference...close enough....
