Doorgunner's '68 Convertible Project
Old Mar 3, 2015 | 10:10 AM
  #1101
Mike21175's Avatar
Mike21175
Side tracks are good. Keeps the cobwebs from clogging up the brain. All good thing happen with time and that S & S engine looks real good. Nice!
Old Mar 3, 2015 | 12:27 PM
  #1102
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Will do and thanks! It's been 30 days with only one PTSD episode, so I'm trying to get a good start on all the home repairs and vehicle repairs.
As for the S&S engine....there was a controversy years ago about the dependability of those engines. My engine was broken-in according to S&S instructions and has been a powerful/roaring powerplant ever since.
I upgraded from cast aluminum to chrome parts for the looks and for the ease of keeping the engine clean. If I can get the Vette engine to look 1/4 as good I will be satisfied!
Old Mar 3, 2015 | 06:28 PM
  #1103
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Gunner, pack up everything you need and move into the garage!
Old Mar 3, 2015 | 06:48 PM
  #1104
13611's Avatar
13611
I'm with Calo... My wife says that if I spent as much time on my car as I do surfing around the forum that it would be done by now! She's probably right!!!
Old Mar 3, 2015 | 11:53 PM
  #1105
doorgunner's Avatar
doorgunner
Now why didn't I think of that! Keep an eye on me Men....I need the guidance!
60300
Old Mar 5, 2015 | 05:30 PM
  #1106
doorgunner's Avatar
doorgunner
Today is................DASH DAY...........
The lengthened wiring harness and oil pressure tubing makes pulling the gauges an easy job.......
May as well get the steering out of the way.......
Now to work on the actual problem.....a stripped odometer drive gear....
The stripped gear/shaft is in the rear of the housing--upper right corner.......the new gear is laying to the right of the housing in the pic.........
The main shaft worm gear was burred so I had to remove it from the housing and file the burr off so the new drive shaft would turn smoothly.......(Pic is before filing the wide burr off the edge of the gear).........
1.5 hours later......it's turning smoothly and the odometer/trip meter is registering again.......
Back to the garage to lengthen the speedo/tach/light/ignition wiring harnesses and install the Alarm/Remote Start module!
60400
Old Mar 5, 2015 | 07:03 PM
  #1107
loup68's Avatar
loup68
Army
DG, where did you get the repair parts from? Lou.
Old Mar 5, 2015 | 09:46 PM
  #1108
Kris Tunetso's Avatar
Kris Tunetso
Doorgunner, you've done more in one evening than I think I could get done in a week. I'm not near adventurous enough to dive into the guts of an odometer, either.
Keep up the great work.
Old Mar 6, 2015 | 12:04 AM
  #1109
doorgunner's Avatar
doorgunner
Willcox......I use his repair guides all the time.
Old Mar 6, 2015 | 12:07 AM
  #1110
doorgunner's Avatar
doorgunner
Thanks Kris T........the PTSD is still giving me a break....so I'm tying up as many loose ends as possible.
60700
Old Mar 6, 2015 | 12:20 AM
  #1111
doorgunner's Avatar
doorgunner
Phase II of the Dash Work...........
The speedometer is re-installed into the dash panel........
The driver's kick-vent seal was completely worn off---the new seal is to the right of the door.....
The old and new lenses for the ventilation controls....2nd pic is lense installed...........
The P.O aftermarket steering wheel gets an old-school leather wrap..........
That's it until tomorrow.
60800
Old Mar 6, 2015 | 01:04 AM
  #1112
Kris Tunetso
Hey Doorgunner, I remember suggesting a few pages ago to put a quick disconnect into your center cluster harness so you could remove it easier in the future, but couldn't find the thread. Well, I found it! Have a look at post #12.
Old Mar 6, 2015 | 01:09 AM
  #1113
doorgunner's Avatar
doorgunner
That's a sharp-looking wiring-job! Thanks for reminding me---I just received a pack of quick-disconnects for my motorcycle---I'll "borrow" one for the Vette dash gauges.
Old Mar 6, 2015 | 05:38 AM
  #1114
SB64's Avatar
SB64
Nice work DG, all of what you just did Iam not looking forward too. Working in tight quarters wiring behind the dash etc. I like the quick disconnect for the gauges. Also extending the harness to work easier. Very nice.
r
Old Mar 6, 2015 | 07:57 AM
  #1115
Calo69's Avatar
Calo69
Hey Gunner, Who's got more miles on them, you or the odometer?
Let me know what mileage you start with I'm always looking for new numbers to play.
Old Mar 6, 2015 | 11:27 AM
  #1116
doorgunner's Avatar
doorgunner
r
R.......that is a pic that Kris T sent me to copy from.....I already lengthened the dash gauge wires, but a resto-mod disconnect will guarantee that I won't need to pull the gauges again...LOL!
Verrrrry funnnny....You win the "Hilarious" award........
55,279 is when the odometer stripped a gear.....according to the wear on the original rotors (0.004") and original brake pads on the rear rotors it's probably around 60-65,000 miles on the car/it has been broken-parked most of it's life----different engine, different transmission, 3 owners plus me---I've had it a year and a half---I could see it sitting for 10-15 years at a time with major mechanical problems.
Now as for my mileage: 365 x 65 x 12= 284,700 x 1.5= 427,050 + 48495= 475545 x 118= 56,114,310............give or take 3 miles
Feel free to use any combination of numbers.
I have to visit my V.A, Shrink now....will (probably) be back this afternoon to do MORE DASH WORK.
60950
Old Mar 6, 2015 | 11:43 AM
  #1117
Calo69's Avatar
Calo69
Good luck with doc.
Thanks for the numbers
To Doorgunner's '68 Convertible Project
Old Mar 6, 2015 | 06:23 PM
  #1118
DZRick's Avatar
DZRick
Thanks Men! I could finish all the remaining repairs/replacements in a weeks time but the PTSD doesn't let that happen
After the convertible top install is complete I want to replace the '76 tail light panel/clip with the used '69 clip that I found last year.....
I've never done body work before....so this should be fun making the car look like the '68 that it was originally.
The tail light panel is correct but the exhaust panel you have is for a '70-up.
The '68 will have the back-up lamps and a different shaped opening for the tail pipes. Half cut into the panel and the other half into the fender.
Like this.
You are doing a great job on this, hope to see it done soon.
Old Mar 7, 2015 | 02:06 AM
  #1119
doorgunner's Avatar
doorgunner
Like this.
You were reading my mind.....I was wondering where the backup light openings needed to be....now I know!
61000
Old Mar 7, 2015 | 08:38 AM
  #1120
briankeery's Avatar
briankeery
Nothing a die grinder and a little masking tape can't fix......
