Three... two... one... lift off!
Old Mar 7, 2022 | 01:21 PM
  #621
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Nice work!
Old Mar 8, 2022 | 10:35 AM
  #622
danh63's Avatar
danh63
WOW! Nice work!!
Old Apr 20, 2022 | 02:47 PM
  #623
caskiguy's Avatar
caskiguy
Just went through your project again.....did I ever mention you're a tad bit meticulous RBrid ?
Beautiful workmanship.
Old Apr 20, 2022 | 04:13 PM
  #624
SuperBuickGuy's Avatar
SuperBuickGuy
Needs 49 more shades of grey
Old May 1, 2022 | 05:24 PM
  #625
RBrid's Avatar
RBrid
Unless you want pictures of my hair, I have no more shades of grey to show.
caskiguy, meticulous me? Barely
I have switched back to the mechanical side of things since the last post. Are you ready for an onslaught of pictures?
Old May 1, 2022 | 05:27 PM
  #626
RBrid's Avatar
RBrid
Default Balancer install
The first order of business was to install the balancer. I put it on an oil heater for a while and then immediately applied anti-seize & slid it in with the special tool. Smooth like butter.
Old May 1, 2022 | 05:28 PM
  #627
RBrid's Avatar
RBrid
Default Engine install
Next came the engine install using my wooden apparatus. No problem.
Old May 1, 2022 | 05:30 PM
  #628
RBrid's Avatar
RBrid
Default Transmission pilot bearing install
This required more force than I wanted. I should have put it in the freezer for a while before install.
Old May 1, 2022 | 05:32 PM
  #629
RBrid's Avatar
RBrid
Default Bellhousing to crankshaft alignment
I measured a misalignment of 0.003" with the stock dowels.
The maximum being 0.005" I did not have to use offset dowels.
Old May 1, 2022 | 05:34 PM
  #630
RBrid's Avatar
RBrid
Default Clutch install
After installation the plastic alignment tool went in and out without friction. Important for the transmission install phase to come.
Old May 1, 2022 | 05:35 PM
  #631
RBrid's Avatar
RBrid
Default Hydraulic bearing cushion gap
The required cushion gap is between 0.150" and 0.200". With the right shimming I ended up with 1.940" - 1.770" = 0.170". Should be fine.
Old May 1, 2022 | 05:37 PM
  #632
RBrid's Avatar
RBrid
Default Mini starter shimming
The clearance must be between 0.030" and 0.060". I used the typical high-tech paperclip for that adjustment.
Old May 1, 2022 | 05:39 PM
  #633
RBrid's Avatar
RBrid
Default Transmission install
Next came the actual transmission installation. It required quite a bit of wiggling and made me sweat but ultimately went in all the way.
Old May 1, 2022 | 05:41 PM
  #634
Mako72's Avatar
Mako72
Nice work!
Old May 1, 2022 | 05:42 PM
  #635
RBrid's Avatar
RBrid
Default Driveshaft and shifter install
Driveshaft install. Check.
Shifter baseplate install. Check.
Shift tower install. Check.
Shifter dust cover install. Check.
Shifter dust cover sealing. Check.
Old May 1, 2022 | 05:44 PM
  #636
RBrid's Avatar
RBrid
Default Fuel filter install
Here comes the 10 microns filter install for the Holley Sniper EFI system.
Old May 1, 2022 | 05:47 PM
  #637
RBrid's Avatar
RBrid
Default Engine and transmission shimming
Once all that was done Doug's side pipe brackets would not align with the 4 chassis slots. They would not align in the horizontal plane and not in the vertical plane. Damn.
To address that
- I added washers on the driver side engine mount (grade 8, 1/8" thick, 1" diameter).
- I raised the rear of the transmission by about 5/8".
I could fit both side pipes at that point.
I am concerned about clearance issues when I put the body on the chassis given all this shimming.
Anyways, other than that I have been working on the electrical system design and purchasing parts for it (cables, wires, cable splitter, fuses, fuse holders, fuse blocks, relays, relay holders, toggle switches, wiper toggle switch, toggle switch guards, engine start push button, key switch, shrink tubing, ring terminals, cable crimper)
That will be the subject of future posts...
Thanks for taking a peek!
To Three... two... one... lift off!
Old May 1, 2022 | 07:26 PM
  #638
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Since you raised the rear of the trans 5/8" I would carefully check the driveline angle, at the trans output and the diff input. Get it wrong and you will have vibration.
Old May 1, 2022 | 08:06 PM
  #639
RBrid's Avatar
RBrid
Default Driveshaft angle measuring
I hear you Leigh, and I had tried to measure the angles.
The driveshaft angle is trivial:
But what are good spots for the transmission and differential?
You need positions that are parallel to the axles.
On the transmission side, what is a meaningful position? A? B? C? D? etc...
Same for the differential side. What is a reliable position for the measuring tool so that it's parallel to the hidden axle?
I didn't feel like anything I measured other than the driveshaft itself was reliable, so I gave up and intended to drive it, see if there are any vibrations and in the positive put a shim at the differential side. Back to a drive test and repeat until I find the sweet shimming.
P.S.: Maybe these two front and rear tool positions are acceptable? Are these two surfaces parallel to the two axles?
Old May 2, 2022 | 09:49 AM
  #640
SuperBuickGuy
To address that
I shimmed mine - clearance and drive line angles were just fine
