Three... two... one... lift off!
I tried to fit the ones on the left onto the balancer and noticed something was wrong
(older picture)
My next big step is to mount all the engine accessories.
Just an observation...
Mark
with that said, expected HP is what determines the line size; and in this case, the stock line is adequate. Running a return line allows the system to bleed faster and keeps away fuel starvation issues when the tank level is low.
Photos of my latest progress coming soon to a screen near you...
Something that carries on is my daily rendez-vous with my vette. So here's the latest progress.
I had some more hardware to blacken but the local company I had been using for the black oxide treatment apparently closed down. So I did it myself with Evaporust and the rest of Eastwood's Metal Blackening Solution I had. Both worked pretty well.
Afterward I poured a bit of thin oil into the hardware pile to protect it further.
Nope - next I had to finish brackets and pulleys for the engine accessories. I added a bunch of other steel parts to the pile. I sandblasted them, then primed and top-coated with either black epoxy or Gloss Jet Black Single Stage Acrylic Urethane.
A sampling before sandblasting:
After sandblasting:
After gray epoxy priming:
After black epoxy:
After gloss acrylic urethane:
All together:
The pully alignments gave me a lot of grief, mostly because of a trickle-down effect of picture #1 in https://www.corvetteforum.com/forums...post1605078374. I couldn't use the original steering pump bracket and got another style one, which I had to file down to avoid contact with the alternator belt.
That gray bracket still has to be top-coated with black SPI epoxy.
I will remove the steering pump belt before the first engine start to take the entire steering system out of the picture.
Epoxy sealer:
Top coat: single stage PPG DCC Concept.
Color: light grey.
Texture: orange peel.
I'll have to do some serious wet sanding & buffing in the future.
- a general 4-prong cut-off switch,
- a small fuse block directly connected to the battery that will feed the relays for the fuel pump and EFI.
- 1/0 AWG cables to the mini-starter, the 250Amp alternator, an interior hub, an exterior firewall hub.
I cut some temporary composite wood plates to mock up component placements. I will ultimately use ABS plastic sheets instead.
That's all for now.
Thanks for taking a peek!
