Three... two... one... lift off!
Old May 2, 2022 | 10:46 AM
  #641
69schemers's Avatar
69schemers
Nice car,
I like to use the machined vertical surface where the u-joint strap bolts rather then an as cast surface. I feel it is more accurate.
Old May 2, 2022 | 05:07 PM
  #642
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Ditto. Use the machined vertical machined edge surface of the trans yoke, and the diff yoke, after pulling the driveshaft.
You bought a Tremec right from Silversport?
Here is some info from them:
https://shiftsst.com/blog/post/drive...Spicer%20table.
Old May 3, 2022 | 02:44 AM
  #643
RBrid's Avatar
RBrid
Originally Posted by SuperBuickGuy
I shimmed mine - clearance and drive line angles were just fine
Thanks - this sounds promising.
Originally Posted by 69schemers
Nice car,
Thanks guys! This is very helpful information. I'm pretty sure I will be able to make meaningful measurements now. Using planes at 90 degrees from the axles is a trick I had not thought about.
(I did get a TKO600 from SST)
Old May 7, 2022 | 04:30 PM
  #644
RBrid's Avatar
RBrid
Default Bad Angles
I have been busy doing basic maintenance on the Alpine this week but managed to measure the 3 angles yesterday. I have a bad case of the W configuration - it's out of whack:
Engine to Driveshaft Angle: 3.2 - 2.0 = 1.2 degrees.
Driveshaft to Differential Angle: 2.0 + 1.6 = 3.6 degrees.
That's too much of a delta.
A little bit of math shows that if I raise the differential at the snubber by 1/3", I'll get good numbers:
Engine to Driveshaft Angle: 3.2 - 1.3 = 1.9 degrees.
Driveshaft to Differential Angle: 1.3 + 0.6 = 1.9 degrees.
A perfect match!
Now, how to raise the differential by 1/3"?
#1. Torque the snubber bolt . It wasn't torqued at all. Torquing it and thus compressing the rubber takes care of about 1/10".
#2. For the remaining 1/4", I wonder if I can cut off 1/4" from my rubber and steel guide:
Old May 7, 2022 | 09:44 PM
  #645
doorgunner's Avatar
doorgunner
2026 Loser of the Year
When you retorqued the snubber...the drive shaft angle also changed.....I think?
What is the new angle of the drive shaft?
What is the new angle of engine-to-drive shaft?
And the new angle of drive shaft to differential?
Old May 8, 2022 | 12:54 AM
  #646
RBrid's Avatar
RBrid
Default New Angles
You're right DoorGunner, after torquing the numbers are better:
Engine to Driveshaft Angle: 3.2 - 1.8 = 1.4 degrees.
Driveshaft to Differential Angle: 1.8 + 0.9 = 2.7 degrees.
Not quite where I want them to be yet. Current plan of record: cut off 1/8" of the bushing's rubber and steel, then measure again. I think I will be golden then.
Old May 8, 2022 | 10:32 AM
  #647
OldCarBum's Avatar
OldCarBum
Give Dan at Van Steel a call.
They offer a Derlin rear crossmember bushing kit that raises the rear differential.
They advertise 3/4” but I’ve read that measurement does vary.
Dan can help you with the drive shaft angles and I believe they also offer different bushing kits to set up the angles.
Old May 8, 2022 | 11:32 AM
  #648
doorgunner's Avatar
doorgunner
Keep us updated...I also heard that the diff. "rises" a certain amount and maintains the rise-angle while the car is being driven at a "constant speed".
Setting up a secure "pointer" aimed at a yellow dot on the side of the diff. could help determine the angle of rise on your specific car at highway speeds...
setting up a GoPro to record the event under driving conditions is "another Animal".
Old May 8, 2022 | 11:38 AM
  #649
doorgunner's Avatar
doorgunner
RATS! Now I need to check the angles on my driveline since the previous owner DIYed the one-piece trans mount to fit a TH400...
good thing it will be easy to check-correct since its been on tall jack stands for the last 3 years
Old May 24, 2022 | 02:18 AM
  #650
RBrid's Avatar
RBrid
Default New Angles
Thanks doorgunner and OldCarBum. I got in touch with Van Steel but they only offered that 3/4" raise which was way too much for me. I needed a 1/8" lift.
I ended up ordering a new polyurethane kit because on the ad picture it looked thinner than my rubber bushing. When it came, it was in fact as thick as the rubber one, so... I sawed off some of its material and landed on reasonable angles:
And the approximate result:
Engine to Driveshaft Angle: 3.2 - 1.2 = 2.0 degrees.
Driveshaft to Differential Angle: 1.2 + 0.8 = 2.0 degrees.
I call it a day.
Thanks for taking a peek!
Old May 24, 2022 | 11:05 AM
  #651
OldCarBum's Avatar
OldCarBum
Nice work as always!
Old May 24, 2022 | 09:03 PM
  #652
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Fabulous and meticulous!
At least your ideas help me, even if you are on the wrong "coast"! LOL
Old May 25, 2022 | 10:22 AM
  #653
OldCarBum's Avatar
OldCarBum
That all depends on how you look at the world.
Old May 25, 2022 | 02:48 PM
  #654
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
So how are we ever going to cruise together in our Big Blocks?
Old May 25, 2022 | 08:09 PM
  #655
Shovels and Vettes's Avatar
Shovels and Vettes
Leigh and I will drive from the east coast......meet you half way in St. Louis,......where they all started!!!!
Old May 25, 2022 | 10:16 PM
  #656
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Now THAT is a great idea!
Old May 25, 2022 | 11:53 PM
  #657
OldCarBum's Avatar
OldCarBum
I’m in for a coast to coast cruise!
To Three... two... one... lift off!
Old May 26, 2022 | 02:40 AM
  #658
RBrid's Avatar
RBrid
My vette won't be ready for years to come...
I visited Boston on the other coast recently, and it was beautiful!
My next post will be about a hot topic. Stay tuned...
Old Jun 19, 2022 | 02:54 PM
  #659
RBrid's Avatar
RBrid
All right, time for an update.
My next step was to address all the clearancing issues with my Doug's headers. They were hitting the Steeroids u-joint and bracket, and came a bit too close to the chassis. I meticulously followed this educational video to dimple my headers:
Making room for the Steeroids u-joint, on the driver side:
I was amazed at how easily the propane torch got the SS red:
It is so satisfying to butcher a shiny new SS header:
Result: about 3/16" clearance with the u-joint:
Making room for the chassis, on the passenger side:
Result: 3/16" clearance with the chassis:
Making room for a pipe, on the passenger side:
Grinding the Steeroids bracket:
Repainted and re-installed:
Result: 3/16" clearance with pipe:
And the result:
All mounted, with Hooker reserve flow mufflers to start with. I might switch to louder and less restrictive mufflers later. We'll see...
The entire exhaust system will be ceramic-coated inside and out after a break-in period.
Old Jun 19, 2022 | 02:59 PM
  #660
caskiguy's Avatar
caskiguy
Looking good Rbrid.
