Headlight switch removal
Old Sep 12, 2015 | 06:14 PM
AirborneSilva's Avatar
AirborneSilva
Default Headlight switch removal
Before you say it, I did do a search... So, now that the search has failed me, again, can someone please tell me how to remove the headlight switch? Thank you!!!
Old Sep 12, 2015 | 06:46 PM
loup68's Avatar
loup68
Army
Tony, you have to loosen up the driver side dash panel to get access to the bottom of the headlight switch. It has a spring loaded button on it , that you have to push in to remove the headlight switch **** and shaft. Then there is a special nut that you have to turn to release the switch, itself. You my be able to use needle nose pliers or a large screw driver on that nut. I hope this helps you out. I have a 68 and I imagine the 78-up dashes are different to get to the switch. Lou.
Old Sep 12, 2015 | 07:06 PM
AirborneSilva
Thanks Lou, I have a 76, guess I should have said that LOL I also have the dash apart so it's easy to get to now, I'll see if I can't find that spring loaded button, now that I know I'm looking for something like that maybe I can find it Thanks again!
Old Sep 12, 2015 | 07:30 PM
BKarol's Avatar
BKarol
This might help: http://www.corvettemagazine.com/tech...-installation/
Old Sep 12, 2015 | 07:40 PM
AirborneSilva
Originally Posted by karol
Thank you both, I did get the stalk out but now turning that nut with a screw driver (even with a hammer ), doesn't seem to be happening. I did spray it with PB blaster and will let it sit for a bit. Thanks again to both of you
Old Sep 12, 2015 | 08:51 PM
bj1k's Avatar
bj1k
They sell a tool for taking that nut off but I just made one but you will need some tools to make the tool and some fabricating skills.
Old Sep 12, 2015 | 09:23 PM
AirborneSilva
Thanks, I was able to get it with the screw driver but did bugger up the bezel a little, not bad though so it shouldn't be noticeable
Old Sep 12, 2015 | 10:52 PM
Iceaxe's Avatar
Iceaxe
The secert to getting the headlight **** to release.... Pull the **** to the ON position, than push in the button and pull the **** the rest of the way out.
Old Sep 13, 2015 | 11:41 AM
7T1vette's Avatar
7T1vette
Sticking the tips of a set of needle-nosed pliers into the slots on that collar will usually work to get it loosened or tightened.
Old Sep 13, 2015 | 02:54 PM
AirborneSilva
Mine was so frozen on there that didn't work but that's how I will put it back on. I'm thinking I should probably buy a new switch, this one has had water on it. It did work fine but do I trust that it's going to continue to work fine???
To Headlight switch removal
