ignition switch light?
Old Jan 18, 2016 | 11:14 AM
ronarndt's Avatar
ronarndt
Default ignition switch light?
My new dash wiring harness came with wires and bulb socket for an ignition switch light. Unfortunately my 68 convert has no place to install a light for the ignition switch. When did lighted switches start? I put a bulb in the extra bulb socket to illuminate the wiring in back of the dash. RA
Old Jan 18, 2016 | 11:57 AM
Alan 71's Avatar
Alan 71
Hi ra,
They weren't lit, even later.
Remember after 68 the ignition switch moved to the steering column and the driver just stabbed at it with the key.
This is why typically the painted area around the switch was scratched.
I'm not sure if it was ever lit.
Regards,
Alan
Old Jan 18, 2016 | 12:07 PM
ronarndt's Avatar
ronarndt
Default light
Originally Posted by Alan 71
Hi ra,
Regards,
Alan
Hmmm. The harness came from Lectric Limited, and it was pretty accurate, so I thought later production models had a hole somewhere for it. At least on the dash you can see the target for the key. All of my RX-7s had a small light for the ignition key, but also had a large (2 inch) metal trim circle around the key hole to prevent scratches.
Old Jan 18, 2016 | 02:04 PM
Alan 71's Avatar
Alan 71
Hi RA,
I may have missed something…. but a light at the ignition key is a new one for me!
I just reread the instructions for Operations Section of Flight Judging and while various interior and dash lights are listed I don't see anything about a light at the ignition switch?!?
We need AvalonJohn!
Regards,
Alan
Old Jan 18, 2016 | 02:12 PM
ronarndt's Avatar
ronarndt
Default light
Hi RA,
We need AvalonJohn!
Regards,
Alan
Alan- I would not have known what it was, but the very detailed wiring diagram from Lectric Limited shows it as a light socket for the ignition switch. wire colors match the diagram. I put a bulb in it just so the hot wire would not touch anything in the dash and short out. I'll post the diagram when I get home.
Old Jan 18, 2016 | 02:29 PM
cdl49's Avatar
cdl49
Our old switch had a spot for a light but the new switch did not so we did the same and put a bulb in and tied it with a tie wrap. My son and I could not see any light coming thru.
Dean
Old Jan 18, 2016 | 02:39 PM
Alan 71's Avatar
Alan 71
Hi Dean,
Well! It's ALWAYS nice to learn something about these cars!
Regards,
Alan
Old Jan 18, 2016 | 02:49 PM
ronarndt's Avatar
ronarndt
Default light
Dean
I had an ahah! moment when I read your reply, cause I still have the old switch and thought I would look at it to see if it had a light socket. But- remembered why I changed the switch in the first place a few months ago. The PO installed a generic switch that looked like it was for a lawn mower. I doubt if it was a lighted switch. RA
Old Jan 18, 2016 | 03:30 PM
cdl49's Avatar
cdl49
Here is 2 pics of the old switch. I don't see how any light could get thru the switch bezel and nut but there is a thru hole going to the key hole.
Dean
Old Jan 18, 2016 | 06:30 PM
Staylor63's Avatar
Staylor63
My ignition switch (1968) has a light socket and bulb, they look in age to be original. I thought the same thing....how does this bulb light anything?
Old Jan 18, 2016 | 06:50 PM
Alan 71's Avatar
Alan 71
Hi,
Now I'm curious what the light socket that's part of the harness looks like?
Regards,
Alan
Old Jan 18, 2016 | 06:53 PM
Staylor63's Avatar
Staylor63
Hi,
Regards,
Alan
i will take some pics when I get home!
Old Jan 18, 2016 | 07:09 PM
loup68's Avatar
loup68
Army
Gentlemen, original 68 ignition switches do have a light as CDL49's above photos show.
The light is to illuminate the key way slot at night, so that you can insert your key into the switch. It is not that bright, of course. I am guessing here, but since everything on a 67 was carried over to the 68's, I bet that they also had an illuminated ignition switch. Lou.
Old Jan 18, 2016 | 07:16 PM
loup68's Avatar
loup68
Army
After the original GM replacement ( service part ) switches were discontinued, all of the 68 reproduction ignition switches that I have seen do not have the light receptacle. Lou.
Old Jan 18, 2016 | 07:22 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I remember that from several GM products back in the '60's. I always thought it was cool! All you could see was a little glow inside the key hole.
Old Jan 18, 2016 | 08:14 PM
Staylor63's Avatar
Staylor63
Here is what I see...
Going right into the main harness.
Old Jan 18, 2016 | 10:44 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I've been looking for a picture of the original switch that I have and got side tracked today... you guys nailed it though.
The original switch 1116697 (as mentioned above) had a socket pocket made into it. Why.. I have no idea but at the time most switches prior had them... It didn't light up though since there really isn't any way for the light to escape from behind the switch.
The replacement switch CS62, sold by most parts stores used to come with a generic bracket that you screwed onto the switch before you inserted it in the dash... But I just checked a current picture and I guess they are leaving it out of the switch now. I think most just toss this bracket and install the switch without it.
-Willcox
To ignition switch light?
Old Jan 18, 2016 | 11:41 PM
Raphiki's Avatar
Raphiki
The switch didn't light up. All you could see was a dim light glowing inside the keyhole.
Old Jan 19, 2016 | 07:07 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Ive been redoing all my dash lights and found this same light and hole in my early 68. I do get a faint light through the ignition. Ill post pics tomoorow night.
Old Jan 19, 2016 | 07:11 PM
DUB's Avatar
DUB
Install an LED with higher lumens....and you will be able to see it. I did it on a 1957 Corvette and it shines like crazy.
DUB
