Gas !!!
Old Mar 13, 2016 | 08:09 AM
  #41
GARYFINN's Avatar
GARYFINN
From: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Ouch you guys are really tough.
Old Mar 13, 2016 | 08:29 AM
  #42
fishslayer143's Avatar
fishslayer143
Wow.... when did visiting a Corvette Forum turn into such a pizzing match in nearly every thread now? ...Can t you guys just get along? One guy rattles the cage and you all start barking... Take it down a notch... PLEASE!!!!!
Old Mar 13, 2016 | 08:43 AM
  #43
midigike's Avatar
midigike
Not getting in the middle,
But I have an original 68 327-300hp that I run 93 octane and at every fill add a bottle of lead substitute. It is around 4-5 dollars a bottle and you can find it at nearly all the parts stores by the chemical sections- brake fluid, oil additives, etc.
Old Mar 13, 2016 | 09:01 AM
  #44
fishslayer143
But I have and original 68 327-300hp that I run 93 octane and at every fill add a bottle of lead substitute. It is around 4-5 dollars a bottle and you can find it at nearly all the parts stores by the chemical sections- brake fluid, oil additives, etc.
And that would be the correct answer for an early C3 original engine without hardened valve seats to prevent seat depression ..
Old Mar 13, 2016 | 10:02 AM
  #45
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Troll's get what they ask for! And if he thinks he getting anyone upset, far from it! It's quite entertaining! But if you want to challenge someone about behavior's on the forum, why not ask the troll why he has to be a troll?
Old Mar 13, 2016 | 10:16 AM
  #46
GARYFINN's Avatar
GARYFINN
An example to other C3 Trolls ^^^ see this wasn't to hard.Thanks that's good info.
Old Mar 13, 2016 | 12:19 PM
  #47
fishslayer143
I was talking to ALL involved including OP.. Bring it down a notch.. and . You find arguing and insults entertaining? wow..really? Then maybe you are here for the wrong reasons. Just my opinion...
Old Mar 13, 2016 | 03:16 PM
  #48
CheezMoe's Avatar
CheezMoe
Oh brother! Well Thank you for your well thought out opinion. I don't necessarily disagree with you. However it is pretty common knowledge that if you ask a broad brushed question, and then act like an azz when folks try to get you to narrow it down, you should expect to get flamed. It's the way it works. So excuse me when I follow such a thread and get a chuckle.
Old Mar 13, 2016 | 03:21 PM
  #49
fishslayer143
Could it be, Perhaps that's why in 10 years of you being here and thousands of posts, you 've been thank only 5 times .. You put more emphasis on chuckles and flaming others than giving informative replies ..
Old Mar 13, 2016 | 10:23 PM
  #50
69Pman's Avatar
69Pman
you'll be fine with the high test pump gas. good luck and have fun.
Old Mar 14, 2016 | 09:22 AM
  #51
CheezMoe's Avatar
CheezMoe
Yeah whatever. Show me where I flamed anybody?!??! I gave a sarcastic answer to a stoopid question. ... Ohh I've only been thanked 5 times...I'm all ate up over it.
Have a great day! I'm going to!
Old Mar 14, 2016 | 07:26 PM
  #52
DUB's Avatar
DUB
Originally Posted by GARYFINN
Its obvious you people here are incapable of any kind of civil discussion how funny.
I disagree. Your question was answered...several times....with the information you provided.
In case you are not aware of it. It was not until your post #7 that you specifically mentioned the year of the car you were asking about. So your question was open ended and there was really no clear precise answer even though people did reply.
And just so you know... Which it is always wise to mention they year model in the first post. Because.....from 1968 high compression big blocks to the 1982 Cross-Fire fuel injected engines are light years apart.
DUB
Old Mar 15, 2016 | 12:07 PM
  #53
1974CorvetteJimCr's Avatar
1974CorvetteJimCr
Can these cars run on unleaded gas ????
Yes they can. The thing you need to avoid, if possible in your area, is ethanol. I run 93 octane non-ethanol gasoline.
There is a web site and app to find gas stations with non-ethanol.
http://www.pure-gas.org
Old Mar 15, 2016 | 05:03 PM
  #54
fishslayer143
yeah whatever. Show me where i flamed anybody?!??! I gave a sarcastic answer to a stoopid question. ... Ohh i've only been thanked 5 times...i'm all ate up over it.
Have a great day! I'm going to! :d
yaawwn
