Distributor size
Old May 6, 2016 | 08:22 PM
graveyard's Avatar
graveyard
Default Distributor size
Guys just wondering if the HEI dis will fit or hit anything on my car,i know they are a inch or so bigger.I have a DUEL SNORKEL air cleaner for a late build 1970 454.
Old May 6, 2016 | 08:32 PM
bj1k's Avatar
bj1k
Don't know about the 454 , but I have a HEI distributor on my 1972 350 engine . No clearance problems.
Old May 6, 2016 | 09:23 PM
graveyard's Avatar
graveyard
I might go with the pretronix,it is a good option also and does a good job from what i have read.
Old May 7, 2016 | 04:42 AM
7T1vette's Avatar
7T1vette
It will fit...but not if you still use the shielding hardware around the distributor.
Old May 7, 2016 | 02:41 PM
graveyard's Avatar
graveyard
I dont use the shielding so it should work.
Thanks guys
Old May 7, 2016 | 09:59 PM
bj1k's Avatar
bj1k
Thanks guys
I'm not using the shielding on mine and the aftermarket radio works fine without it . I think you only needed the shielding when using the old original spark plug wires which were not shielded in any way .
Old May 8, 2016 | 10:54 AM
71scgc's Avatar
71scgc
I have HEI in my 71 SB. Shielding won't fit, and you may have to do some cable routing changes, but it JUST fit behind the dual snorkel.
I switched to an open element breather and bought some room.
Carter
Old May 8, 2016 | 11:50 AM
graveyard's Avatar
graveyard
Duel snorkel is a tight fit for some reason,bigger i guess.
To Distributor size
