replacement for a 1970 quadrajet
Old Jun 23, 2016 | 04:28 PM
vettekid333's Avatar
vettekid333
2024 C3 of the Year Finalist - Unmodified
Default replacement for a 1970 quadrajet
where is the best place to get a rebuilt carburetor for a all original 1970 corvette? I went to change the fuel filter and found that the fitting that holds the filter is stripped. I want to keep it original if possible.
Old Jun 23, 2016 | 04:33 PM
71 Green 454's Avatar
71 Green 454
I would check with Lars first to see it he can repair the threads.
Or Cliff:
http://www.cliffshighperformance.com/services.html
Old Jun 23, 2016 | 04:41 PM
MelWff's Avatar
MelWff
or Cliffs High Performance for repair
Old Jun 23, 2016 | 06:07 PM
vettekid333
Or Cliff:
I have sent an email to lars but have not heard back from him. Would you happen to have a current email addy for him? I sent the email to v8fastcars@msn.com. I see that turn around for Cliffs is 12 months and I want to drive my car as soon as I can. I see that mid america corvette does have rebuilt ones.
Old Jun 23, 2016 | 06:42 PM
DUB's Avatar
DUB
Sent you a PM.
DUB
Old Jun 23, 2016 | 08:28 PM
john 72-04's Avatar
john 72-04
I faced the same situation last year. I hate to give this advice because I will get all sorts of negative comments because everyone on this forum will tell you it's impossible to get a commercially rebuilt carburetor that works properly. I went to Autozone of all places and purchased one for $315.00 13 months ago that I have had zero issues with. My original is in a box under my workbench and eventually I will have it repaired. I paid the $55.00 core charge to keep my original. Just a suggestion and a rather economical one at that.
Old Jun 23, 2016 | 08:37 PM
Dave J's Avatar
Dave J
I believe the turn around time for a simple helicoil install is much shorter. I would call Cliff and verify however. Which engine do you have and what is your carb#?
Old Jun 23, 2016 | 08:53 PM
The13Bats's Avatar
The13Bats
while it's too bad you feel like you have to toss out that disclaimer like with the topic of radiators which is very opinionated and becomes pretty much just a bash and belittle any cats who uses anything other than the token brand type thread qjet threads can go askew pretty quickly too,
I still consider it as on option and curious is yours Rochester or a knock off, did it tune in pretty easy, do you happen to know what cfm it is....
Old Jun 23, 2016 | 10:02 PM
BBCorv70's Avatar
BBCorv70
Cliff's turnaround for rebuilt carbs has been long, think it's down to 6 months now? For stripped threads they recently responded telling be 2 day turn around from the time they receive the carb. Repairing stripped threads only, not a rebuild. I'm considering sending a carb to them, threads are partially stripped.
Old Jun 23, 2016 | 10:06 PM
BBCorv70's Avatar
BBCorv70
Do you know who the rebuilder was? I had a Q-Jet rebuilt by Holley which was a total POS, had to replace the main body, hacked pretty badly. I've heard of others having bad experience with Q-Jets rebuilt by Holley. Based on your experience it seems there ARE some rebuilders who do a decent job. Wondering who did yours....
Old Jun 24, 2016 | 06:51 AM
Eljay's Avatar
Eljay
I got one from Jegs a JET Preformance, it runs ok but I think it needs to be tweaked a bit. My original is long gone. I have considered buying a proper #7040205 but at $1200 to $1400 I just can't justify that price. But at every swap meet I look at crusty carbs to see if I can find the one that the owner does not know he has the one that I want.
Old Jun 24, 2016 | 07:34 AM
john 72-04's Avatar
john 72-04
Bats...it is manufactured by Carter 650 cfm. No problems adjusting and has remained adjusted for 13 months.
Old Jun 24, 2016 | 07:37 AM
john 72-04's Avatar
john 72-04
BB.... Purchased at Autozone rebuilt by Autoline products out of Canada.
Old Jun 24, 2016 | 08:31 AM
rmgny44's Avatar
rmgny44
Mine was replaced with a rebuilt from United Carburetor of Chicago.
Price was reasonable. (around $350.00) No complaints!
Old Jun 24, 2016 | 09:55 AM
Faster Rat's Avatar
Faster Rat
My "all original" 1969 had a Q-Jet from a '67 passenger car. I replaced it with a BRAND NEW (date coded 0206 - probably '86) replacement Q-Jet for my application for $750, including freight. It was still in the GM box, shrink-wrapped to the plastic tray. Put in a new accelerator pump. Cliff says the air bleeds are too big and I need to change the jets and metering rods for my rebuild. It still pulled 408 hp / 502 torque on the engine dyno. I will let the next caretaker spend $1500 on a "correct" 7029215 carb that has hopefully been correctly rebuilt. Meanwhile I will enjoy driving the car.
Old Jun 24, 2016 | 09:28 PM
vettekid333
My engine is a 350/300 w auto. The carb number is 7040202 with a 00 dh under the number.
Old Jun 24, 2016 | 09:38 PM
7T1vette's Avatar
7T1vette
Since you already have the required "all original" carb, you just need to get it repaired properly. Lars Grimsrud can do that and I don't believe his turn-around time is anything like 12 months. Don't know why he hasn't returned your e-mail, but I suspect he didn't receive it...or maybe it came into his junk mail and he discarded it by mistake.
Send him another e-mail to V8FastCars@msn.com and ask if he would repair your carb body. IMO, I would just have him do a proper rebuild on the carb while he's at it. The total charge would likely be less than purchasing any other rebuilt carb outright. This way, you still have the original carb, it will not leak at the inlet threads, and it will be newly rebuilt and properly set up.
What a deal!!!
To replacement for a 1970 quadrajet
Old Jun 24, 2016 | 09:48 PM
lars's Avatar
lars
I have not received an e-mail from you.
I can repair the threads correctly. Drop me a note for info. The "rebuilt" carbs from the major parts suppliers are junk - please see my article about this.
V8FastCars@msn.com
Lars
Old Jun 24, 2016 | 10:00 PM
The13Bats's Avatar
The13Bats
so he story on the edelbrock qjet...telling me they all suck just because isn't what I am asking,
Are they a keck off from the original molds or what?
several different ones and no longer made, but neither is the original qjet
Old Jun 25, 2016 | 09:03 AM
vettekid333
What a deal!!!
Thanks for your help 7T1vette
