Door gap issues
Put your hands at top and bottom of the rearward door edge and pull/push to see if there is movement in and out. If so, the rivets that hold the hinge bolt plate inside the door may need attention which unfortunately requires door removal.
I need more information...such as IF you can get the door to close all the way...regardless of how much effort it takes to do so. I would like a photo of it when it is completely closed.
IF you can..take one photo like you did showing the gap at the top of the door..and then another a few feet back...down on one knee and looking straight at the door gap so I can see the gap from top to bottom.
Get down on one knee and look at the top flat surface of the door by the handle...then when slowly closing the door...look at the end of the door at the top in relation to the top of your quarter panel and see when the door begins to go into the striker bolt...does the door go UP or DOWN.
Also...if your door gap at the front fender looks good and consistent...but the rear gap is all messed up..I would possibly look at the #4 body mount inside the rear wheel well and see what it looks like.
And I would agree...when raising and supporting your Corvette...due to being a convertible...CARE should be taken in where you position your jack and support stands so you do not have a problem in potential frame issues. I can easily prove it to you on how much flex your frame has...or can have if incorrectly supported. And these issues can occur regardless if the top is up or down. The convertible top does not have enough integrity to maintain anything when it comes to the body panels.
DUB
The door pin hits the striker bolt and moves up, it looks like it hits the very bottom left and tries to move up and then just stops.
Looking at the front and back of the car it looks like it tilts slightly to the driver side. It looks like the hood doesn't go down all the way to that side, and the windshield wiper door wont close all the way. ( just found that out recently after opening them for a friend to see how they work). Again it looks like it closes fine on the passenger side not the driver. Could this all be connected to the car leaning?
Thanks in advance
Your #4 mount on the body, looks like it is rusted or broken. If I'm seeing things correctly, the front portion of the box mount is missing. I say this because it looks to me that you have the ends of the two rivets that hold the front of the mount, but nothing attached to them?
Your 71 should have an alignment pin on the top rear of each door, and a matching female alignment receiver on each lock pillar. Are these alignment parts in place on your car? If not, this is contributing to your problems.
If the alignment pieces are there, but badly worn, especially the brass inserts in the female receivers, that will also effect the alignment of your doors. The brass inserts are not available separately. You have to buy the receivers as a complete assembly, to get new brass inserts, and they're not cheap at about $85 each. But they were put there by GM, to help prevent the problem you have. Below are the pin and receiver used on all 70-75 convertible doors.
I'd say that you need to check the condition of the #4 mounts more closely, check for shims in the #4 mounts, check to see if the door alignment pieces are in place and if they are in good condition. I would also pull the access covers inside of the rear wheel wells and get a good look at the #3 mounts, and maybe check your frame and rocker panels more closely for signs of rust.
Really need to get the door to close all teh way. And then take another photo when that has been done.
IF your door is moving when you are closing it as I believe you responded to..and NOT knowing if you have the guides that 'gbvette62' posted photos of.
I know you responded to how the door is moving UP when you go to close it...but when it is doing this....is the top of the door NOW no longer flush with the top of the quarter panel???
OR...when it is being closed and going UP...is the top of the door NOW flush with the top of the quarter panel?
Your response does make a difference in what to do next.
IF the door is flush with the quarter panel BEFORE you contact the striker bolt...do this.
I would be loosening up the striker bolt (as long as the ring in the center of the shaft is not spinning). If the ring on the shaft of the striker bolt has lost the rubber behind it...then that striker bolt is USELESS. If the striker bolt is OK..I would adjust it to get the door to close and then we can take it from there.
That previous comment is under the assumption that the wedged guide is set correctly. Often times I remove the guide pin on the door and get the door set on the striker bolt and then adjust the guides. Often times I can look at the guides and see excessive wear.
The condition of the number 4 body mount gusset plate has seen better days. I just needed to see it..and it does need repair...but it does not show any signs of sagging due to the metal being completely gone and the fiberglass pocket that this gusset cover is broken...which yours DOES NOT show signs of.
I do agree about the number 3 body mount area. This area is well known for problems due to rust.
DUB
I also tried closing it without that pin, and it didn't close correctly either.
When the door moves up after making contact, it becomes higher than the quarter panel.
It seems to me that the top front of the door gap is too large and that the door is sitting too far towards to back, but on the bottom half it is very narrow near the front and actually seems to sit lower.
Thank you all for your time and help
Knowing that when you go to close the door it raises up...correct? AND if you have the wedge shaped pin off the door...then it is time to take a TORX socket and loosen your striker bolt that your latch catches on.
BUT..as I wrote...you have to look at your striker bolt and make sure the steel ring is still intact and can not spin due to the rubber under it is gone.
Once you get the striker bolt loose and lower it just a little bit...snug it up can test your door while watching the levelness of it to the quarter panel when closing it.
DUB
Just one question, why would the metal spinning cause me problems with the bolt and the door?
YES...you need to get a new striker bolt.
How can a person expect to get a door...that is supposed to be TRUE and on good bushings so it does not move up and down... and latch onto the striker bolt that has the loose ring and causes the latch to NOT be secure when closed. OR act up when trying to close the door due to the spinning ring is hanging down and the latch is trying to pick it up and latch over the spinning ring?
Think of the ring on the striker bolt being like a key ring...and then you slide a pencil through the key ring. There is a lot of play in they key ring due to the circumference of the pencil being so small in relationship to the inner circumference of the key ring. SO....if your ring on your striker bolt is sloppy and spins easily and is dropping down due to no rubber...it needs to be replaced. JUST because you can grab this ring on the striker bolt and manually rotate it...does not mean it is worn out.....but it is the beginning of the end and it will not get any better.
I know it seems that this would not matter...but it does.
DUB
Is there any chance that because he has air shocks and the passenger side is leaking, that one side has a stiff air shock and the other is way down.
Could this be enough of a twisting force to tweak the body enough to mess up the alignment of the door?
jim
I need to know if your striker bolt has the ability to move up down in and out??? It should.
AND...if your door is STILL going UP when you close it in relation to your quarter panel....CAN the striker bolt be lowered an NOT worry about the witness marks on where it WAS located previously.
AND....if you take off the new striker bolt...and close the door and watch the back of the door to your quarter panel...your door should be perfectly LEVEL with the quarter with NOTHING such as the guide to change it swinging motion. Make sure that this is OK.
Let me know...because either I have missed something or did not ask something to get an answer.
jim
DUB
I took off the striker bolt and closed it and it acted the same way, then i tried it without the guide pin receiver, and still nothing, it still sits a little higher maybe an 1/8 of an inch and just seems like it can't close any further.
The car does lean to the driver side a touch but you have to be down at eye level with the nose of the car to tell.
