C3 Door Shaved project
Not at the car now- but will post some pics later.
Oh- go to the junkyard and look at the emergency cable pull trunk release set-ups. There's so really neat pieces you can scavenge off the inside of the trunk .
I moved the door lock as well-Used a M-B door lock pull-
And here's the button to release the door- and yes -I have it wired so driving down the road the door will not unlock... the brakes or e-brake has to be on.
Just the locks.
https://www.corvetteforum.com/forums...thread-16.html
If you like it go for it. I personally like it am planning on doing it to mine. I don't do thinks to my cars because everybody else likes it I do it because it is what I like it just has to be done with quality workmanship.
Back to the issue-
As far as a back up plan- you don't need to run another power wire to the battery- just a couple of small gauge wires off the door lock ( or solenoid ) something sort of easy to get to then you can simply hit it w/ say your Dewalt/Makita drills battery pack.
And I do recommencement a cable pull as well... you could make it accessible through the door handle- when you push the handle down-have a cable end accessible and maybe use a paper clip to pull on it.
And I do recommend a safety type electric lock out on the solenoids- as I would not want to be driving down the highway and pop the doors...
Here's my attempt to have a nice clean pull on the door handle,
This is the first bracket I whipped-second generation will have a longer lower arm- to get a little more leverage.
Back to the issue-
As far as a back up plan- you don't need to run another power wire to the battery- just a couple of small gauge wires off the door lock ( or solenoid ) something sort of easy to get to then you can simply hit it w/ say your Dewalt/Makita drills battery pack. Yes , I thought of that too.
And I do recommencement a cable pull as well... you could make it accessible through the door handle- when you push the handle down-have a cable end accessible and maybe use a paper clip to pull on it.This real do able
And I do recommend a safety type electric lock out on the solenoids- as I would not want to be driving down the highway and pop the doors...Good idea
You can program it when you walk away- the doors lock- walk up and the doors unlocks- I'm using the trunk release to pop the driver's door.
A little over $100- seems to be a well built piece and has a constant draw of less than 10mA.
I ordered a power lock actuator and linkage w/ door handles that are complete, mine were broken which was the reason for trying this shaved door opener thing.
Oh well lesson learned.
DB
First..That is a nice 77 you have there....you have done a great job on it..Nice work area, lift, impressive. Done all the work your self, Mechanical, Paint, Electrical, interior, Dam... good job.
I've been on this project 6 yr's now (medical got in the way) but it has not seen the inside of a shop other than my garage.. I had to re-move the motor and take it to ST. George UT, when living in Mesquite, NV. for a rebuild, Twice. 1 st. motor was a 396 crate @ 60 Thousand over bore with vibration from low end to high rpm. Now I have a 350 ci /300 hp. motor runs good.
Why ?? that's kind of open. I noticed the inside door panel is different from mine, your rods run on the out side of the sheet metal and between the door cover pad, mine are inside next to the window. You have electric windows, I have manual, you probably already have electric locks, mine manual.
you have room at the bottom of the door and the access openings look bigger....
I did not want to cut a hole large enough to waken the structure.
When I got the car the passenger side door handle did not work it was missing the L shaped lever used to push on the door linkage to open.
the door locks were not operational. so I removed them thinking I would use a shaved door hookup.
It's not going to work for me, So I will attempt installing a power lock which was not there before and see if that will work.?
DB
SO I am looking at the door trim...Here is where I need some input please..
At the top of the door where the window comes out, there are two peace's of trim, one is chrome, which screws to the inner top lip area of the outer door skin. The other is the weather strip that looks like it is to push into the holes in the door where the chrome strip
went. Problem..HOW do I get it pushed into place....???? I am about to place a punch on each split plug and hit it with a mallet.This does not sound right to me..so HELP..PLEASE.IS THERE A WAY TO DO THIS????
