Why Bubba why?
Popular Reply
The thing I like about finding bubba is the experience it gives us to improve ourselves. This can be true to anything we do in life.
A older corvette is a blessing and a cruse at the same time.
The blessing is the enjoyment of learning, the cruse is learning never ends.
It went something like this; the real part cost 75 bucks new, but if we could find a part at the junk yard that would get me by or just bypass the part, (like smog equipment for example,) we would do it.
"Hey Junior, I gotta go to work tomorrow, how we gonna get this POS a running. No problem Bubba, we'll make er work."
Alan71 is a 0.
We're all about a 2 and a half. Admit it.
You know a 10 when you see it.
on mine I've found (among other things) a rear spindle flange that had been cut using a plasma cutter, and a turn signal lamp that had been wire incorrectly(which strangely enough didn't work)
I often times have to figure out WHY whey did what they did so I can further try to understand where their head was at the time....so I can fix it correctly.
DUB
Or is it if it makes the car unsafe?
I ask because I've "fixed" a few things on my car in a non-conventional manner but at a much lower cost than as it came from the factory. So is any innovative fix a Bubba fix?
Well, when my 327/350 HP engine started running very badly, I found out that there were no points left! He kept adjusting them until it was two bare metal pieces slapping together! Lou.
And there are countless examples....Just because a person does their own repairs and does not follow what GM did....does not always make them...what I call a 'BOZO'.
I get frustrated when some people choose to try to 're-invent the wheel' and fail badly in their repair because they are trying to win the award on who can do it the cheapest....which...****NEWSFLASH**** there is no award for doing a repair the cheapest....and then bring the Corvette to me to try to fix what they did. Others may feel that they can make it better than GM and do well at it.. and others may fail to take into account some dynamics that are not always apparent...and their idea does not work.
A perfect example is NOT using the french locks on your half shaft U-joint flange bolts (1963-1979) and use split lock washer instead. I always use the french locks...because if GM could have gotten by and saved money by using split lock washers...they would have. And this is one of those dynamics I an referring to. Yes I have seen these bolts with lock washer that were still tight...but I ALSO have seen them loosened. And that is all I needed to see just ONE time to make my choice an easy one. A bolt can not loosen if the head of the bolt cannot turn...and that is what the french lock does.
So I have no problem in what anybody does here on the Forum to their own Corvette. But I will say that if I see or read that something is not being done correctly and it relates to safety...or it can possibly coem back and bite them and they have to do it all over again...I will 'chime' in. And that is only because I am actually taking time out of my day to extend some experience and advice to HELP that person. If they take my often times brutally honest and direct comments as an insult...then oh well. Fix it how you want to do it...because I do not have to worry about it.
What I just love about modification that a person does is IF they took the time to think things through and not just consider how it is being installed but if they can actually make sure that what they are doing is going to LAST! So many things I find are where a 'kit' is offered with a specific amount of wire length (for example) and the person just slap a part wherever they can due to the wire length...instead of stopping and thinking that if they added more wire they can mount a part in a much better area. OR...leavign 10 feet of coiled up wired all jammed in an area because they do not know how to shorten it correctly and solder/shrink wrap it...or crimp on new terminals.
DUB
'Reliability' is not one of Bubba's hallmarks; but 'ingenuity' is.
The act of bypassing a non-functional feature in your car is NOT a Bubba repair. It's more of a Cletus. {Cletus was Bubba's mechanic.}
