Will this fall?
Old Apr 6, 2017 | 04:10 PM
RickDett's Avatar
RickDett
Default Will this fall?
Year 1969:
Regarding the t top roof locating wedge inner mount base. When I loosen the screws the mount base under the body is loose, all I know is that thing falls that’s going to be a royal pain to put it back up there. So my question is is that base in a cage where it will not fall?
Old Apr 6, 2017 | 04:17 PM
69monzacpe's Avatar
69monzacpe
Originally Posted by RickDett
Year 1969:
Attachment 48080995
It's caged, it will move around but not fall.
Old Apr 6, 2017 | 04:27 PM
Alan 71's Avatar
Alan 71
Hi,
It 'might' fall.
If a lot of pressure has been put on the cage by trying to get a rusty triangular stud out of the threaded plate, the cage may have been damaged…. allowing the plate to drop.
Hopefully you'll be o.k.
Regards,
Alan
Old Apr 6, 2017 | 04:52 PM
oldgto's Avatar
oldgto
Originally Posted by Alan 71
It 'might' fall.
I`ve heard people say theirs dropped.... so I used a long bolt to eliminate the possibility. Take one bolt out, put your long one in, then take out the other. It didn`t interfere with painting at all.
Old Apr 6, 2017 | 04:57 PM
bazza77's Avatar
bazza77
if it falls it will go to a very hard spot to get at , but it can be done . If you pull the trim off you can visual to see if there's any damage to avoid the frustration of picking it out .
Also if you have snapped off the bolts in the steel block it is possible to cut open the "retaining area" and remove the block to fix .
edit , or do what oldgto has done ^^^^
Old Apr 6, 2017 | 07:31 PM
loup68's Avatar
loup68
Army
As someone stated above, use another bolt in the in the hole, or a piece of threaded rod to be sure that it will not drop. I had the bolts on one side come out easy and the driver side were so rusted that I ruined the caging of the caged nut plate, and it would have dropped if I had not used another bolt to hold it. Lou.
Old Apr 7, 2017 | 01:21 AM
RickDett's Avatar
RickDett
okay Thanks
Old Apr 8, 2017 | 12:39 AM
7T1vette's Avatar
7T1vette
oldgto has it right! Use that method so you don't take the risk of it dropping into the "BLACK HOLE OF DEATH".
To Will this fall?
