New Willcox Tach Board
Tom
I actually tested my electric tach outside the dash before I installed it - because I was afraid of running into something like this. Depending on results then you may be able to determine whether it's the installed tach or if you disturbed some of the wiring going to the new tach board.
Contcat WIllcox dn elt tehm knwo what is going on.
I know that when I do them....not knowing if the Willcox tach board is different....
I have the ignition key ON and verify that I have the needle set to zero...then turn off the key and the needle goes up slightly. Then when I turn on the ignition again the needle goes to zero and when I crank and run the engine the needle is correct.
And I also have previously verified that the three circuits that go to the tach are correct. One of them is 12 volts (pink wire), one being the ground (black wire)..and the last one is the circuit from the HEI...which can be a tan wire in most cases.
DUB
I have already contacted Willcox & instantly received an email basically saying
"Please do not call our sales staff about technical questions.
With the current volume of questions in regards to repair and installation help exceeding my human ability! I will attempt to answer most questions as time permits"
The tach moves to "0" with the ignition on & moves up very little when the ignition is off. When I start the engine the needle pegs...if I rev the engine there is no change. I have already checked power and ground & both are good. Bypassed the filter with no change. Any other ideas?
One thing I would try (maybe because I don't trust myself) is to run a separate independent lead from the tach output to the tach..... just for sh*ts and grins..... Since you said you already checked Power and Ground, then this would be a thing to try. Can't hurt and it should be relatively easy.
"Im suddenly having problems with my tach not working as well. Even after installing a new tach board from Willcox it stays stuck at 5500 rpm. I verified power, ground, and tested the continuity of the signal wire as per Willcox's instructions and all are fine. It does not have a tach filter. "
The old tach board circuit is burnt. It would not operate at all. No needle movement just sets all the way at the bottom below "0" . The new tach moves when the key is cycled on will move to "0" & when off will go just a notch above. Once the engine is started it basically pegs & will not move even if I rev the engine. I checked the old circuit board again last night and it is dead - it does absolutely nothing...checked the new board the same way it is able to be "zero"d. I've also checked the signal wire for continuity it is within range.
And reading what you wrote..I knwo when I can checking the wire from the distributor cap that is for the tach..I have it disconnected for the distributor cap and or teh tach filter and also I have the tach out or the connector removed from the speedo/tach cluster and check that wire and make sure it is not grounded anywhere or picking up power from somewhere.
I do not know if the tach boards from WIllcox are like the ones I get where the tach filter is not required.
DUB
DUB this quote got me thinking. My new Willcox tach board did not help my problem. I do not have a tach filter. Could this be why the new board didnt work? As I said previously I have power, good ground, and continuity from the distributor.
Lack of a tach filter should not cause the problems you're seeing.
When a tach pegs as you described, in most cases the issue is either one of the nuts on the board is not getting good contact.
We had a customer last week that sent us his tach in and the nuts were so corroded that there was no way the would pass continuity without being replaced.
So you understand... if you don't have one of the nuts all the way tight making good contact the board will only read one side. There are two sides to the board signal out of the chip... sine and co-sine.
When the board functions, the sine pushes and the co-sine pulls until the board reaches approximately 2500 rpms.... then they flip and the sine pulls and the co-sine pushes... but if one nut is not making good contact then it will only read the other side when the ignition switch is turned on and thus the board will either go below zero or it will peg out depending on which nut is the issue.
If you ever have a question about something we make.. Sales has some knowledge but not enough to answer your question (thus the auto reply). But you can contact me anytime at support@Willcoxcorvette.com (as long as it's not a wiper motor issue..
) Now in regards to the filter.. Our board will run without the filter as will the original GM boards. The filter knocked the square off the signal and helped prevent voltage spikes. But the boards (even he original boards) were designed to read both square and wave so they will both function with or without the filter. But... .it's a smart idea to run the filter to avoid any voltage spikes.
So.. possibly the nut made good enough contact to roll, but I suspect the issue will return. If it does, I would remove the tach, back off the nuts just a tiny bit and then re-torque them to see if the problem goes away.
Willcox
As far as emailing support my email was sent on September 5th to support@Willcoxcorvette.com & I received an automated reply instantly with both emails I sent. If you would like I can forward those emails to you showing that the generated message was from "support" and not sales. The beginning of the auto reply started "Thank you for contacting our support team." I just wanted to make you aware in case this is not the way it should be set up.
Once again though thank you for the information on the re-torque of the nuts! The information in greatly appreciated because as you said the issue will probably return.
Ernie
