spreader bar chassis
Old Apr 24, 2021 | 07:25 PM
  #61
Bikespace's Avatar
Bikespace
Originally Posted by interpon
Thanks all..
belt guard cover the lower rad hose on rear passenger side stud.
good to hear pulley not issue..
tried removing pulley cannot do it fan doesn’t sit right, unless im missing something .
Debating diy or buyng..i like idea of slotting rear side of bracket for easy removal/ install as it is a pita reach
I removed both the AIR pump pulley and clutch fan. The stock mount uses studs, with nuts at the clutch fan side. In my image above, you can see that I replaced the studs with bolts for my electric fan application.
I think the threads on the stock studs don't go all the way to the hub, and the nuts would have bottomed out on the stud, not the pulley? I forget the actual issue, but I wouldn't have bought parts if the stock parts worked. Perhaps you can make up the difference with washers (may not be the best idea). Or use fully threaded studs. Or you could cut the V-groove off of the pulley and just use the center section. But the pulley may not interfere with the spreader bar in any case.
Old Apr 24, 2021 | 07:33 PM
  #62
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Interpon could you or Richard elaborate:
[QUOTE[color=#000000]i just ordered from this thread @Richard454 posted.. 40 bucks shipped.. and complete build list.. Speedway Motors.][/QUOTE]
I looked on the web page and I could not find anything. Thanks Ike
Old Apr 24, 2021 | 07:44 PM
  #63
interpon's Avatar
interpon
I looked on the web page and I could not find anything. Thanks Ike[/QUOTE]
sure..there are two posts for spreader bars at the same time, one in general and one in performance
see richards post #14 here
https://www.corvetteforum.com/forums...-purchase.html
which references the diy thread @PainfullySlow
Old Apr 24, 2021 | 08:39 PM
  #64
general ike
Interpon. Thanks for the clarification I did not realize it was DIY components that you were referencing! Greatly appreciated!! Ike
