77 Paint Code Help
Old Apr 24, 2022 | 11:02 AM
C0RVETTED0N's Avatar
C0RVETTED0N
I understand the 68-76 Corvette build records from St Louis were destroyed, but GM had the Allied-Vaughn Co. store dealer invoices on microfilm starting in 1977 for the St Louis plant. Thanks for the GM Heritage info. ☺
Old Apr 26, 2022 | 01:41 PM
Greg's Avatar
Greg
Just another Corvette guy
Any updates?
Old Apr 27, 2022 | 06:51 PM
C0RVETTED0N
Tried to run a CarFax, but 1977 Vette's have a shorter 13 digit VIN, & CarFax requires the newer 17 digit VIN. Same problem when trying to check for titles in PA using the VIN. Florida will do a title search for $15, I'm trying to get my son to have one done.
How hard is it to get the build tag from above the fuel tank?
Old Apr 27, 2022 | 07:22 PM
Greg's Avatar
Greg
It would be much easier to pull the rocker sill, it's only held on by 4 screws. Then you could pull the carpet back a bit and see true paint evidence. The tank sticker will be great to have as it will confirm a special paint code but it probably won't tell you what that color was.
Old Apr 27, 2022 | 08:29 PM
caskiguy's Avatar
caskiguy
Fuel tank is easy. Disconnect the battery. Drain the tank and pinch off the hose you disconnect.
Read this.https://www.corvetteforum.com/forums...k-removal.html
https://www.motortrend.com/how-to/16...ur-c3-corvette
Btw, Be very careful with the removal of the build sheet, photograph it first before removal.
Old Apr 27, 2022 | 08:35 PM
Bikespace's Avatar
Bikespace
Great info!
Also, make sure it's there first.
I could see mine from underneath, and was able to retrieve it without dropping the tank (78-82 has more room). You may be able to see it if you pull the rubber gasket back from around the fuel fill port. Or you could thread a borescope up there.
Old Apr 27, 2022 | 08:36 PM
caskiguy's Avatar
caskiguy
If you find a Build Sheet put it in a Acid Free document holder.
Old Jul 10, 2022 | 04:59 PM
C0RVETTED0N
Default New Info
My son decided to freshen the paint up, and in the process discovered a tag on the driver's side door. Is it possible this car was ordered in gray primer from the factory? They have found no other colors other than the black it was painted after the nose was modified. Only gray primer below that.
Old Jul 10, 2022 | 05:11 PM
Bikespace's Avatar
Bikespace
I don't know what that signifies. Perhaps the door was damaged before the car was even sold, or at any other time, and the dealer repaired it. Does the color (primer?) match on the inside of the other door?
Were you able to get your order sheet from the GM Heritage Center?
Old Jul 10, 2022 | 07:03 PM
caskiguy's Avatar
caskiguy
Post #4
https://www.corvetteforum.com/forums...31-primer.html
Old Jul 10, 2022 | 08:12 PM
Greg's Avatar
Greg
Agreed. It could even be a replacement door installed at the dealer so it would not have any paint color previous to installation.
I still say the only way to know for sure is to look under the rocker sill.
Old Jul 11, 2022 | 05:18 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
About a year ago I posted on here an identical tag. inside my passenger door, under the door panel.
Original Med Red car. All paint on the door, including the overspray under the door panel matches the original paint color.
Must have been a defect on that door at the Factory. This would not be applied by a dealer. Shows a repair to the paint was made before the car was shipped to the dealer.
The primer inside the door is different to my car, So I would assume that this door needed more work than mine.
Old Jul 11, 2022 | 05:24 AM
  #33
4-vettes's Avatar
4-vettes
Dug through my old photos, didn't want to remove door panel tonight.
