AC with side pipes
Old May 6, 2024 | 06:41 AM
NHollyy's Avatar
NHollyy
Default AC with side pipes
What was yalls route into getting AC with side pipes? Any special brackets to order or anything?
No budget just wanna see how everyone/anybody went about doing it. Pics, tips or any tricks would be awesome.
Thanks, Nate
Old May 6, 2024 | 06:49 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
What, if anything do side pipes have to do with air-conditioning?
if your removing exhaust manifolds and installing headers. You may need a spacer on one bolt.
This however is obvious and pertains to headers.
Side pipes mount on the frame on the side of the car.
No where near anything to do with Air-con
Old May 6, 2024 | 07:35 AM
Golfobsessed's Avatar
Golfobsessed
Not sure what year/application but as 4-vettes said shouldn't come into play with the side pipes, as for headers I used the stock stud and about a 1" spacer for my headers... using the stock AC bracket, you can measure the manifold flange and the header flange and make a spacer for the difference, I just used a piece of stainless tubing I had.
Old May 6, 2024 | 07:40 AM
rdroket's Avatar
rdroket
If you're going to use vintage air all the brackets and spacers, come with the kit. Nothing to do with side pipes
Old May 6, 2024 | 11:35 AM
MelWff's Avatar
MelWff
Thanks, Nate
Did you try downloading the instructions for the particular set you are considering?
Old May 6, 2024 | 11:48 AM
Piersonpie's Avatar
Piersonpie
Installing side pipes, or any headers by extension absolutely overlaps with the air conditioning system.
You have a 1976, if it’s a late 76’ with the R4 compressor no additional brackets are needed. Just use the mounting stud in place of a header bolt on the very front hole.
If you have an early 76’ with the A6 compressor you’ll need an additional bracket that attaches with the header bolts. It’s one of the things that’s generic to a small block Chevy, so there’s ways to forgo the “corvette tax” on a simple bracket.
Old May 6, 2024 | 11:49 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
This ?seems? to be the info the O.P. didn't include in his post.
He needs to add details so you guys can advise him about what he needs.
Old May 6, 2024 | 01:32 PM
Bikespace's Avatar
Bikespace
Clearly the correct answer is "LS Swap".
AC and sidepipes (from this thread).
https://www.corvetteforum.com/forums...ispreloading=1
Originally Posted by todds74
These are Billy Boat LS swap side pipe headers.
Bonus:
AC and twin turbo. I'm using the same ICT Billet brackets for the LS6.
https://www.corvetteforum.com/forums...car-build.html
To AC with side pipes
