Road Course Junkies, Let's compare notes
Old Apr 11, 2006 | 11:16 AM
  #181
gkull's Avatar
gkull
Turtle - When it gets cold, I shut my windows! I'm glad that your liking your tires.
Don't guess about camber settings. Get yourself a tire temp gauge.
Old Apr 11, 2006 | 11:49 AM
  #182
69autoXr's Avatar
69autoXr
Originally Posted by turtlevette
...thinking towards the future to do fender flares with 17x12 running the 315/35/17 on all 4 corners. The problem is finding wheels that don't need adapters. I would have gone with 10" wide but you can't find them. They would have fit with 5" backspace.
CCW's-complete custom wheels-they'll make wheels as big as you want and you won't need adapters. Yes they seem pricey, but they're not bad for what you get.
Old Apr 11, 2006 | 12:11 PM
  #183
DaveL82's Avatar
DaveL82
I run CCW wheels on my 80 with flares. 17 x 10 front and 18 x 12 rear
Old Apr 11, 2006 | 12:52 PM
  #184
Twin_Turbo's Avatar
Twin_Turbo
Yes, there are some tracks in germany, but they are either way in the south or the east, nowhere near me. Oscgersleben is probably the closest and it's over half a day of driving just to get there. And they don't have trackdays apart from the Oschersleber Test Tage (test days) where you run w/ a bunch of idiots, imagine porsches, bimmers, go karts, bikes...just about anything with wheels on it on the track.
Old Apr 11, 2006 | 02:11 PM
  #185
flood's Avatar
flood
This is a great thread.
My car currently has the a-arms out and will all be going back together with poly bushings 550 springs and bilstiens. Hopefully by the end of summer it will have a new rear composite spring and some rims.
Those cragar steelies are the right price!
Then here for a track day to see what the weakness is. (I already know its HP)
http://www.pueblomotorsportspark.com/map.htm
The straight is used for the drag strip. With a 4 speed and 3.70 gears I will be passed. But its all good. I jsut want to get out there and drive without ph34r of cops and oncoming traffic.
Old Apr 11, 2006 | 02:18 PM
  #186
gkull's Avatar
gkull
3.73 gear and your speed limited????? You just need a motor that turns more RPM. I can drive @140 mph with 4.11 gears.
Old Apr 11, 2006 | 02:40 PM
  #187
flood's Avatar
flood
yeah 5k and its all over...actually it never really starts. Stock L48
I always planned on doing suspension then motor. Well suspension is nearly complete. Now I want to autox / road course it for a few times before I have to sink money into the motor. Im going to be sooo incredibly toasted at the track.
Gotta start somewhere.
Old Apr 11, 2006 | 03:55 PM
  #188
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
At 6500 rpm I can go roughly 140 in 3rd gear with 3.55's. The only think holding me back from 7500 is my lifters.
Old Apr 11, 2006 | 03:59 PM
  #189
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
These tires grab pretty good and i was able to create some real seat of the pants Gs in the turns especially the banked one. What bothers me is that it looks like i'm getting positive camber in these picts. I'll have to dial in more initial negative and i think i'm gonna go to solid steel bushings to help. Most of the serious guys in the club dial in so much negative it looks like the wheel is going to fall off.
The guldstrand bushings will shorten your upper a-arms and lengthen your lowers and you will gain more negative.
How can you race in stock seats? I can barely hold on when I take corners in my car.
Old Apr 11, 2006 | 04:02 PM
  #190
Twin_Turbo's Avatar
Twin_Turbo
You can get normal steel bushings w/ nylon liner from VSE or from other speedshops.
Old Apr 11, 2006 | 04:14 PM
  #191
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
What applications fit our cars?
Old Apr 11, 2006 | 04:23 PM
  #192
Twin_Turbo's Avatar
Twin_Turbo
impala
Old Apr 11, 2006 | 04:26 PM
  #193
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
impala
do 71-89 bushings fit?
Old Apr 11, 2006 | 04:32 PM
  #194
Twin_Turbo's Avatar
Twin_Turbo
I thought it was the pre 70..not 100% certain, why nto measure the arms and contact speedwaymotors. I have mine from VSE and they don't fit a stock arm at all.
Old Apr 11, 2006 | 04:34 PM
  #195
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I think they are from pre 70 also.
Old Apr 11, 2006 | 05:48 PM
  #196
jetvette's Avatar
jetvette
http://members.***.net/keiferpkr/buttonwillow.wmv
FREAKIN' IN-CAR LAPS....HOW SWEEEET IS THAT?
When are you in Buttonwillow again? I live in Bakersfield but work a lot out of state. I would coordinate a trip home to be in B'willow when you guys are scheduled.
Old Apr 11, 2006 | 08:22 PM
  #197
69autoXr's Avatar
69autoXr
Dave do you need any spacers for the wheels to clear the calipers?
To Road Course Junkies, Let's compare notes
Old Apr 11, 2006 | 08:24 PM
  #198
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I just got off the phone. Ordered the Guldstrand all steel bushings. I don't want to fool around with trying to fit generic ones. These are expensive but should be straight forward. The lower need to be tack welded in and the upper are knurled.
I have a 5 point harness that holds me in the seat pretty good. Those are C4 seats which have a lot of side bolster. I'm not against a racing seat and that may happen this year.
I want to also get the rear strut rods with the hem joints. I am moving towards making things more solid. Also going to finally install my spreader bar. its going to be tricky with the mechanical fan.
Old Apr 11, 2006 | 08:35 PM
  #199
turtlevette
You don't think that thin nylon sleve will eventually get brittle crack and slide out? I've seen other applications with nylon like that self destruct.
I figure a few wraps of teflon tape between the shaft and Guldstrand bushing will keep things sliding good and quiet it down some.
Old Apr 11, 2006 | 09:01 PM
  #200
turtlevette
I want to encourage everybody but don't want to blow smoke up anyone's as either. You are right to give it a try before you go adding all kinds of hp. The car will be all you can handle with the L48. You might want to try autocross first to get a feel for how to control the car at lower speeds. Plan on getting passed by all the rice rockets like the subaru WRX and such. An ego can be dangerous out there. Your car will be slower. End of story.
On average we have about 2 or 3 wrecks per track day. On last saturday a brand new Subaru lost a wheel and beat up the front end, another guy hit a huge oil slick from a guy that blew a motor in front of him and he hit a tire wall. Lots of car damage from hitting oil. Nothing you can do when a car throws a rod in front of you.
A few years ago a guy rolled his brand new 350Z at Lime Rock. It looked like someone put it in a car crusher.
A guy just died on last Saturday at Buttonwillow.
Don't worry about who is passing who and just learn how to drive and have fun.
