Road Course Junkies, Let's compare notes
Old Feb 28, 2006 | 01:20 PM
  #141
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Originally Posted by burners
What kind of wheels did you buy?.
steel craiger black soft 17x9
http://www.jegs.com/webapp/wcs/store...egory_rn=36662
Old Feb 28, 2006 | 02:09 PM
  #142
CrossedFlags77's Avatar
CrossedFlags77
Turtle, how much do those weigh?
Old Feb 28, 2006 | 02:20 PM
  #143
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Wow, those are cheap. I may need to get a set of those to mount some track rubber on.
Old Feb 28, 2006 | 05:41 PM
  #144
ZD75blue's Avatar
ZD75blue
I might get a set of those just to pull my beat to hell rally wheels off!
I'll keep those in mind, thanks turtle!
Old Mar 2, 2006 | 11:44 PM
  #145
turtlevette
i'll get the bathroom scale out this weekend and let you know.
I got the free shipping deal so saved another 50-80 dollars.
cheap bastard i am.
Old Mar 18, 2006 | 05:12 PM
  #146
turtlevette
Originally Posted by vwcorvette
T-vette,
I've thought of running my '75 at some track days like the ones COM does. I've done a bunch to my car, but don't want to make it completely unstreetable. Any suggestions? I do have track day experience, but with fwd VW's.
Has original springs for now, putting on Bilstein HD's soon. Have replaced everything on the front end including poly bushings for the control arms. Standard rotors with EBC greenstuff front and rear, new brake master and booster. Headers w/ dual exhaust (including high-flow cats).
Considering The jeep power steering box and mono-leaf rear spring(lbs?). Good as is or should I do more? It's an L-48 putting down 185hp at the rear wheels, through a th400. Don't thinK I need to do any engine mods for now.
Thanks in advance for any advice you have.
I would say just get out there and try a track day with the vette. See if its even something you want to do with that car. Don't worry about engine mods, believe me it will go as fast as your skills can handle. The C3 takes quite a bit of skill and finesse to negotiate around the track. Once you have some experience with the car on the track then you will know what adjustments you want to make to balance the car ect. You might decide you want to go back to a VW or Subaru or miata.
I would concentrate on getting some good wheels and tires first thing. See above.
I'm probably just going to go with some relatively sticky street tires. 275/40/17
i was thinking the sumitomo HTR Z for 88 bucks each. Treadwear rating of 160 should give a decently sticky tire and cheap enough so you can burn through them without breaking the bank.
http://www.tirerack.com/tires/Compar...10&sortValue=1
Old Mar 18, 2006 | 05:55 PM
  #147
DREGSZ's Avatar
DREGSZ
[QUOTE=turtlevette]steel craiger black soft 17x9
[QUOTE]
What do those weigh per corner?
Old Mar 19, 2006 | 11:25 AM
  #148
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Boy did I get a bunch of sespension set ups and tips this weekend at sebring. There was a few vintage rcaers there.
Old Mar 19, 2006 | 11:27 AM
  #149
turtlevette
Picts???
Old Mar 19, 2006 | 11:31 AM
  #150
GDaina's Avatar
GDaina
Haven't read any replies, but consicer using Hoosier street tires, next best thing to race tire compound, and they are DOT, so they qualify as a street tire. Tread is 5k miles if that, so, best to haul them to the track and change there. Expect to lower 2 seconds per lap on a 2 mile track compared to OEM tires.
Old Mar 19, 2006 | 11:35 AM
  #151
turtlevette
[QUOTE=Evan Ginsberg][QUOTE=turtlevette]steel craiger black soft 17x9
38.5 pounds. with a 29 pound tire mounted that puts me at 67.5. The guys with newer vetts are talking about tire and wheel weights in the 45 - 55 pound range. At least i shed 10 pounds with the wilwood dynalites.
There's just nothing cheap, wide and light that will work with the C3 without adapters which are illegal and dangerous.
George the street hoosiers are a good idea but expensive and i am poor. I have to race on a shoestring budget.
Old Mar 20, 2006 | 01:50 AM
  #152
aqua80's Avatar
aqua80
I've heard that these folks offer newer Vette rims to fit our C3's. http://www.bjschromeandcustom.com/
Have you guy's heard of this?
As far as the extra weight Turtle,,,,I really don't think you'll notice it. The increase in grip will out weigh the extra poundage.
Scott...
Old Mar 20, 2006 | 08:22 AM
  #153
DaveL82's Avatar
DaveL82
Check out diamond wheel company. They make steel wheels including lighter ones for roadracing. The largest diameter is 16 inch so the problem is finding performance tires in 16 inch that give the correct width and diameter. Vettes use a 26.5 to 27 diameter tire on the rear and you could use a slightly smller one on the front.
I haven't yet looked for track only tires for 15 or 16 inch rims (possibly slicks?)
Dave
Old Mar 20, 2006 | 03:41 PM
  #154
CrossedFlags77
Hey Dave I was going to ask how your weekend went. The pic in your avatar is awesome. Got anymore pics? Did you get rained out?
The biggest slicks I found for 15" wheels are 225/45's which would most likely be way too small. Then if you move up to 16" wheels Hoosier offers a slick in 275/45 which would be perfect for the rear. Kuhmo also offers a couple different styles of slicks in 265/45/16 which would also work on our cars.
Old Mar 20, 2006 | 03:50 PM
  #155
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Hoosier makes 245/45. A few vintage racers had them.
Old Mar 20, 2006 | 04:00 PM
  #156
69autoXr's Avatar
69autoXr
These are not slicks, they are DOT approved treaded competition tires. Slicks are not DOT approved.
In the Hoosier Street TD, the appropriate sizes offered are 245/45-15, 245/60-15 and 275/60-15.
Hoosier does not make the 275/45-16 street td DOT tire anymore. The last time they made this tire was the year 2000. They do offer a non-DOT "Hoosier TD" vintage tire (25.5x10-16) that is basically the same tire except not DOT approved.
https://www.hoosiertire.com/rrtire.htm
There are also a couple of 15" sizes in the DOT radial.
Old Mar 20, 2006 | 08:09 PM
  #157
enkeivette's Avatar
enkeivette
Originally Posted by turtlevette
Whats this rear end jacking that can occurr on adding any sort of decent sized rear bar causes it to be as loose as Paris Hilton.
As funny as that is, I'm gonna have to disagree. I have a 1 1/4 front bar and a 3/4 rear bar and my car feels to be almost neutral steer when I lose it. My car oversteers a bit, but not much. I lost it pretty bad into a turn once and the car just slid sideways.
My car also prob weighs the same as your car, I have alum heads, intake, trans, wheels, no ac, no spare. I haven't read this whole thread so forgive me if someone already said this, but first and foremost I'd get rid of those 15s. You don't have massive fender flares for formula style tires like TT has, so 15s are working against you. Out of everything that I've done suspension wise, the 17s offered the biggest improvement.
Also I have 550 VBP front 360 VBP rear with Bilsteins FYI.
To Road Course Junkies, Let's compare notes
Old Mar 20, 2006 | 08:30 PM
  #158
turtlevette
how much have you played with it? What happens before you lose it? You can practice in a parking lot driving in a big circle as fast as you can. If it feels like the front is sliding forward instead of turning its got understeer. If it feels like the back is sliding out you've got oversteer.
I find i like a bunch of oversteer in autocross but on the big track looseness can be hazardous to your health.
Old Mar 20, 2006 | 09:04 PM
  #159
DaveL82's Avatar
DaveL82
Crossedflags - a few marginal pics since my wife took them from the club house. Too much rain to get near the track. Hope to get more on a dry day in April.
In regards to tires I supposed not one soltuion will solve everyones problems since some of us run flares while others don't, various wheels and depending on if its a sanctioned event rules limit tire use.
For me I'm running flares cut from Vanacours L88 panels. I'd go ACI flares in the future instead of cutting from a panel although it has worked well so far.
On the car right now I have CCW 17"x10" front rims with Kuhmo ECSTA MX 275/40-17 tires and on the rear I have 18"x12" rims with 295/35-18 tires.
What I'm open for is running used/new racing slicks or other DOT tires on 15 to 16 inch rims as a low cost alternative that would give similar width and diameters. Overall the Kuhmos are a not too expensive for the performance they offer. It would be nice to have other options available so I could have ready a set with lower cost wheels to keep on the trailer.
Dave
Dave
Old Mar 20, 2006 | 11:35 PM
  #160
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
My tires and wheels feel extremely light. I'll have to measure them sometime.
