Compressed air. I got an adapter hose from pep boys. Spark plug fitting on one side, shop air fitting on the other. I'm putting 90 PSI into the cylinder and there's no way the valve can go down.
Another way of keeping the valves up while changing springs on a fully built engine is using rope. I did this and it works great, justs takes a little more time. You insert a long piece of ~1/4" diameter rope thru the spark plug hole (make sure you leave some hanging out ), rotate the engine so that cylinder is close to top and the rope is filling the combustion chamber. Now you can take off that cylinder's springs and the valves won't drop down. After the the springs are in, rotate engine a little to loosen up the rope, slide it out and do it all over again on the next cylinder.
