New crate engine is now a steam engine....bad problem...
Engine Basics: Detonation and Pre-Ignition
http://www.streetrodstuff.com/Articl...tion/index.php
" The Keith Black pistons unique thermal conductivity, ring location and varied end use requires special attention be paid to top ring end gap. KB pistons make more HP by reflecting heat energy back into the combustion process and, as a result, the top ring runs hotter and requires additional end clearance. Increasing ring end gap does not affect performance or oil control because normal end gaps are realized at operating temperatures. Failure to provide sufficient top ring end gap will cause a portion of the top ring land to break as the ring ends butt and lock tight in the cylinder. The broken piece may cause further piston or engine damage. Safe top ring end gaps can be found by multiplying the bore diameter by the appropriate ring end gap factor from the clearance chart below.
Example: 4" bore "Street Normally Aspirated" = 4" bore x .0065 = .026 top ring end gap. NOTE: Second ring end gaps do not need extra clearance. Dyno and track testing has shown that 34 degrees or less total ignition timing makes the best HP and time. Excessive spark advance, lean fuel mixture or too much compression for the fuel and cam used will make heat sufficient to butt piston rings with as much as .060" ring end gap. The entire top land can expand enough to contact the cylinder walls, when close to melt down temperatures are reached."
Turn the crank and look to see if the ring gap changes substantially from top to bottom of the cylinder. If you can see a change in ring gap chances are they never bored the cylinders.
makes sense to me.
Lonely Vette again........
Loaded up and ready!!
Miscl. shots of different cylinders....notice the markings....
Wishing you luck with the outcome.
Came out much quicker this time!! Nothing like experience.
Other questions.....the vertical marks are on the #3 cylinder which had the broken piston top, but no break in the cylinder wall.
Thanks once again for the support guys, and it means more than you realize!!
I was a novice vette owner just a year ago who knew how to do nothing more than change the oil. With the help and encouragement of members of this board, I have now pulled two engines, replaced one, and will do a second reinstall shortly!! Bottom line, this board is awesome!! I'm still learning, but I went from a looking at a head swap as a major task, to now it would be a piece of cake.
Nothing like hands on experience!! Oh....I have had some help from some good friends that have guided me as well, and one in particular who was riding shotgun when the engine misfortune happened.
For you new wrenchers.....don't be afraid to jump in and just "do it". Read this board, ask questions, and be willing to take advice. You would suprised at the $$$$$ you can save by doing some of your own major projects!!
Hopefully this message thread has educated a few, as I know it has me!! Still learning, and wondering what the next project will be?? Tranny? (way to many parts!!
(sorry man, ya gotta be able to laugh in times like this!)So very very very true!!
Hey, I am now over the dissapointment with the failure, and looking forward to dropping some new power in again!! Out with busted, in with the new!!
Let us know as soon as you have more info.
DR. Jay
ESU
