No Go on New engine parts.
Old Jun 8, 2006 | 05:40 PM
  #121
JustinD's Avatar
JustinD
I'm not sure.
Old Jun 8, 2006 | 05:46 PM
  #122
...Roger...'s Avatar
...Roger...
Did you do another comp.check with only 2 to3 strokes?If you have a vacumn gauge it should read around 15 inches of vacumn.
Old Jun 8, 2006 | 05:56 PM
  #123
spedaleden's Avatar
spedaleden
I watched your video and it looked to me like the motor is runnig counter clockwise. The motor should run clockwise.
Old Jun 8, 2006 | 06:10 PM
  #124
...Roger...
Looking from the front- its going the right way- look how the fan scoops the air.
Old Jun 8, 2006 | 06:53 PM
  #125
JustinD's Avatar
JustinD
Ya, it is turning the right way.
Old Jun 8, 2006 | 09:13 PM
  #126
...Roger...
Have you tried backing off each valve 1/8 turn ? Try that it might tell us something.I cant imagine your engine being so timing sensitive--you've had the timing all over the place.You didnt give up did you?
Old Jun 8, 2006 | 09:17 PM
  #127
JustinD's Avatar
JustinD
No, but my frustration level is through the roof. So take off my valve covers and back off all my valves 1/8 turn? When I adjusted them I tightened until it stoped tapping then went 1/4 turn more.
Old Jun 8, 2006 | 09:23 PM
  #128
...Roger...
Do that and if things get better then we'll know your too tight.
Old Jun 8, 2006 | 09:46 PM
  #129
JustinD's Avatar
JustinD
So, I started loosening my rockers and they seem too loose if I back them off. So I put it back. The way they are now there is no play in the rocker, but I can spin the pushrod.
Old Jun 8, 2006 | 09:50 PM
  #130
...Roger...
That sounds good.
Old Jun 8, 2006 | 09:53 PM
  #131
...Roger...
Originally Posted by dwncchs
That sounds good.
What are you going to do next?
  #132
JustinD's Avatar
JustinD
So you think I could have bent some valves? How would I have done that with my rockers a 1/4-1\2 turn to tight? When I did it with the engine running before I started it that is about how much I loosened them to get it right. Plus I never heard a metallic noise.
Old Jun 8, 2006 | 10:00 PM
  #133
...Roger...
When you took the play out the first time had you primed the engine?No oil in the lifters would let them bottom out.If they were and you went a 1/4 it might have done it.
Old Jun 8, 2006 | 10:02 PM
  #134
...Roger...
I dont know how wild your cam is --the wilder it is the easier it would be to bend valves.Is your cam hydraulic----could they have given you solid lifters in your kit?
Old Jun 8, 2006 | 10:05 PM
  #135
JustinD's Avatar
JustinD
There was alot of assemly lube coating all of the parts, and I filled the oil through the heads with the valve covers off pouring it into each hole were the pushrods were evenly. That is when I had the rockers to tight. I tried starting it adjusting the timing and other assorted stuff and cranked it quite a bit. Then I took the play out and hit the key it fired right up and smoke a little bit from the assembly lube that was all over. I adjusted the all the lifters to stop tapping. Then backed off until it tapped and then tightened 1/4 turn after it stoped, 1 by one.
Old Jun 8, 2006 | 10:06 PM
  #136
...Roger...
Bent valves can be ruled out with a vacumn gauge or by a cylinder leak test.
Old Jun 8, 2006 | 10:07 PM
  #137
JustinD's Avatar
JustinD
This is the exerp on the package:
You get fully assembled Holley cylinder heads, an intake manifold, and a Lunati cam with 235°/240° duration at .050, .490/.490 in. lift, and 112° lobe separation. You also get lifters, hardened pushrods, head bolts, a double-roller timing chain and gears, and assembly lube.
The cam isn't very wild at all. Just more so than stock which is a dog.
To No Go on New engine parts.
Old Jun 8, 2006 | 10:08 PM
  #138
JustinD's Avatar
JustinD
My buddy has a vac gauge. I can get it tommorow. Do I just hook that up to my manifold vac?
  #139
...Roger...
Leak test is the best.
Old Jun 8, 2006 | 10:09 PM
  #140
...Roger...
Yes should hold steady around 15
