U-joint nightmare
Old Oct 3, 2006 | 01:19 AM
  #41
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I figured out how to carefully remove a u-joint so that it isn't destroyed in the process. I'll polish the inside of the bores, oil them, and try this all again.
Old Oct 3, 2006 | 10:20 AM
  #42
noonie's Avatar
noonie
Originally Posted by DWncchs
I dont have one of those mics.These clips were snug in the groove.So if you add the 3.625 and 2 clips at .0563 you come up with 3.7376.I did not stress the flange at all.I removed each one by using the 1/2 shaft to force the cup out.That way you dont bend the flange and thats the way I remove all of mine.If you use a press and force the joint out using the other cup you generally stress the flange even with a plate installed.
I just wondered what the allowable clearance would be by subtracting the two different measurements (Length of ujoint and inside of shaft flange).
Old Oct 3, 2006 | 11:40 AM
  #43
shafrs3's Avatar
shafrs3
Originally Posted by I'm Batman
that's why I was thinking that it's a slight problem with the joints.
Why don't you measure them with a micrometer, this would remove all doubt. According to my cheap Harbor Freight made in China vernier calipers, the brand new Brute Force U-joint I have lying around as a spare measures 3.619", if I compress it's jaws onto the caps with my fingers. I think this is about right, these clearances would leave about .005" operational clearance per side. My C-clips are measuring .0585" using a good mic.
Cheap Harbor Freight made in China vernier calipers are only about $15.
If you are concerned about small measurements you need to be able to measure them, otherwise your just guessing.
I actually have a slight bit of BACKbend in one of the drive flanges, using the method described by DWncchs, and the clips still won't go in.
I still think you've got bent ears.
How did you determine you have a backbend?
Old Oct 3, 2006 | 12:38 PM
  #44
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I did what DWncchs suggested and put a shim in the thin part of the drive flange and tightened the bolts. You could actually see a bit of difference front-to-back in the clip groove with the joint installed.
I'll run by HF later today and get a set of their cheapo verniers and see what I come up with.
Old Oct 3, 2006 | 01:14 PM
  #45
...Roger...'s Avatar
...Roger...
Batman just got some more joints in and measured them.These are in Borg Warner boxes.8 measured 3.624,1 measured 3.625,,,1 measured 3.635--pulled the caps off and measured the trunnions-they all measured right at 3.373 except the 3.635 and its trunnion measured 3.383---EDIT---shafrs3 said his clips are .002 larger than mine-check yours-all of mine are .056-.057
Old Oct 4, 2006 | 01:19 AM
  #46
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Batman - Sorry this might not help you much, but after reading your problems, I wanted to make sure I didn't bend the flanges so I removed U-joints with a die grinder. Took awhile, but they came out. Then to install the joints I mounted the flange back onto the TArm. Pressed the U-joint in with a large C-Clamp. Piece of cake. I also pressed the U-joints into the arms with the vise.
I think Ironcross might be right.... During my installation it looked like I had extra room (after pressing) to install (2) clips?!? Good luck....
Old Oct 4, 2006 | 01:43 AM
  #47
noonie's Avatar
noonie
Gr8Wht
Your stuff looks way way too clean.
Old Oct 4, 2006 | 06:51 AM
  #48
...Roger...
Gr8Wht what brand of u-joint are you using ?
Old Oct 4, 2006 | 09:13 AM
  #49
DR.Jay's Avatar
DR.Jay
Do you have the grease fittings installed in the joints? You may want to try removing them if you do. You could possibly be hydrualic locking the joint by trying to compress the grease. If you remove the grease fitting this will allow the traped preasurised grease to escape.
Just an idea.
Old Oct 4, 2006 | 03:28 PM
  #50
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Just an idea.
Non-greaseable joints. Thanks for the suggestion, though.
Old Oct 5, 2006 | 04:37 PM
  #51
Gr8Wht's Avatar
Gr8Wht
CF Veteran
They are Spicers. Part Number #5-799S (If I remember correctly). Non-Zerk U-joints.
Old Oct 5, 2006 | 04:39 PM
  #52
Gr8Wht's Avatar
Gr8Wht
CF Veteran
Originally Posted by noonie
Gr8Wht
Noonie,
I'm in know hurry, just having fun. That's probably why.... The trailing arms look nice, huh? I have to thank Gary (gtr1999) for that. Doesn't he do a great job?
Old Oct 5, 2006 | 07:04 PM
  #53
noonie's Avatar
noonie
Originally Posted by Gr8Wht
Noonie,
If that's just a sample, then your car has got to be gorgeous.
Old Oct 5, 2006 | 10:11 PM
  #54
19LEW71's Avatar
19LEW71
Search this thread I had the same problem
I ground the caps ever so slightly.
******Half shaft u joints very tight*****
Old Oct 5, 2006 | 11:39 PM
  #55
shafrs3's Avatar
shafrs3
So Batman, what did you find? Give us your root cause analysis.
Old Oct 6, 2006 | 02:41 AM
  #56
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've been busy and lazy this week. Haven't had any wrench time. I'll try to let you guys know tomorrow. Thanks for all the help.
Old Oct 6, 2006 | 09:40 AM
  #57
Durango_Boy's Avatar
Durango_Boy
I may have to re-do the joints in my half shafts. As I was putting the tires back on, I tested, and there was more play than I was comfortable with.
Can the half shafts be removed and worked on without presing the hub out of the trailing arms? Also, what's involved with getting the yokes changed in the rear end?
To U-joint nightmare
Old Oct 6, 2006 | 01:35 PM
  #58
dog_jerry's Avatar
dog_jerry
I have the same question !
Old Oct 6, 2006 | 02:01 PM
  #59
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You can easily unbolt the drive flange from the hub - shine a light on the inside of the T/A and you'll see what I mean. I'd recommend taking the spindle nut off and pulling the inner portion of the drive flange, too - you can use it as a backing plate to stiffen the drive flange while messing around with the joints.
Old Oct 6, 2006 | 02:03 PM
  #60
Durango_Boy
And the yokes? Do they pull out of the pumkin or are there clips on the inside holding them?
