Motor Mount Replacement
Old Jan 22, 2007 | 02:40 PM
  #81
BerniesVette's Avatar
BerniesVette
Good thing it is stone!
Bernie
Old Jan 22, 2007 | 07:11 PM
  #82
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Wow over 1000 views on replacing a motor mount who woulda thunk
Old Jan 22, 2007 | 07:43 PM
  #83
Durango_Boy's Avatar
Durango_Boy
Well, it's something all of us have two of, no matter the year or model.
Old Jan 22, 2007 | 08:06 PM
  #84
gmg1977's Avatar
gmg1977
I went solid with my big block, no problems so far
Old Jan 22, 2007 | 08:40 PM
  #85
MotorHead's Avatar
MotorHead
I am going to try solids in mine with poly tranny mount
Old Jan 22, 2007 | 11:26 PM
  #86
Shark Racer's Avatar
Shark Racer
Originally Posted by Buffalo Dude
It's a real tight squeeze, but I managed it for a few years. I couldn't crawl completely under, but just enough to reach most of the engine parts. Lots of times I had to exhale to slide in. I don't know if I could still do it because I've put on a lot of weight, but I can still snake my arms far enough under to reach the oil plug.
My JACK can't even get that far under my car.
6'2, 250, no way in hell I'm getting under there. I can get slightly under the spare tire carrier and that is IT. I did do my header collector bolts and nuts with the car on the ground, but long arms account for ALL of that.
On the subject - I installed ES polys a few years ago and like em a lot.
Old Jan 23, 2007 | 10:05 AM
  #87
Clint's C3's Avatar
Clint's C3
Motor mounts are like belly buttons, everybody's got 'em.
I did the swap last night using solid mounts from Summit
http://store.summitracing.com/partde...0&autoview=sku
a mere $25.88 plus handling charge.
I lifted the motor slightly using a floor jack and 2 X 6 on the pan near the front where it transitions over the crossmember to the deep part of the pan.
The right side was easy, it took less than 15 mins. The left side was more difficult as I had to remove the left side header to get access to the through bolt. This meant removing plugs, wires etc also.
I was happy to see the left side mount had completely separated so my diagnosis was correct.
All the bolts came out easily, I did not have to remove or loosen the tranny mount. While the motor was slightly lifted, I started all the bolts and threaded in about half way before lowering the motor and final tightening.
There is a slight vibration I can feel in the steering wheel and in the floor pan. It is not objectionable and probably not noticeable to anyone not familiar with the car. Over all I am pleased and it's good to know this should be the last time I need to take on this project.
Old Jan 23, 2007 | 10:14 AM
  #88
Durango_Boy
That's the unhindered power of the beast you feel. It's something you will come to love.
Did you notice any differences in how it feels when you get on it? Does it feel like it responds quicker?
Old Jan 23, 2007 | 10:23 AM
  #89
Clint's C3's Avatar
Clint's C3
Luxury, schmuxury! I am all about unhindered power.
I can’t say there is a noticeable difference in power but she is responsive when I jump on her and it’s much better than the vibration I was getting from the motor torquing over and jamming the exhaust against the floor pan.
Old Jan 2, 2011 | 10:59 PM
  #90
kwikcc's Avatar
kwikcc
considering changing motor mount on my 73 sb. Does anyone known if the poly or the solid mount lift or lower the engine from its original position, have a vbp spreader bar installed and have very little clearance under fan hub to consider.
Old Jan 3, 2011 | 09:34 AM
  #91
Clint's C3's Avatar
Clint's C3
The solid mounts don't change the engine position at all. I recommend them.
Old Jan 3, 2011 | 01:44 PM
  #92
kwikcc's Avatar
kwikcc
thanks.
can you shim them to lift the engine slightly, and does the combination of solid mounts with a spreader bar stiiffen the frame to much with potential cracking problems down the road.
Old Jan 3, 2011 | 02:23 PM
  #93
Clint's C3's Avatar
Clint's C3
You should be able to shim between the mount and the frame a bit if you need to. Are you having problems lining up your drive train?
As long as everything is properly positioned (not in a bind) and you are not stressing your fame, mounts etc., the solid mounts should contribute to frame stiffness with no issues.
Old Jan 3, 2011 | 07:51 PM
  #94
kwikcc's Avatar
kwikcc
no alignment problems just thought by shimming i could get a little more distance between the fan hub and the spreader bar. right now i can put the width of 2 hacksaw blades between them not really sure if that is enough room.Don't really know how much the engine travels up & down, i understand that it twists right to left
Old Jan 3, 2011 | 08:19 PM
  #95
WESCH's Avatar
WESCH
Hi
There are some threads about melted poly motor mounts and I saw one on a 65 racecar with a clone L88 motor .
If the exhaust headers are too near to the poly mount, the poly simply melts away.
Rubber does not melt, nor does solid mounts.
I am presently still running the old rubber mounts with the HOOKER side pipe headers on my BB 68 without any problems.
There is a modification that can be done to the mount by drilling a hole through it and installing a bolt loosely in order to stop any up movement of the engine in case the mount rubber or poly breaks.
I am kind of afright that a solid mount could crack the engine side wall. The material is not really thick there, is it ?
Rgds. Günther
Old Jan 4, 2011 | 10:47 AM
  #96
Clint's C3's Avatar
Clint's C3
The motor will not twist if you use solid mounts. The mounts attach to the cross member and side of the engine block, which are both plenty strong.
Old Jan 8, 2011 | 11:27 PM
  #97
kwikcc's Avatar
kwikcc
Thanks for all the input. I plan to go solid with motor mounts and poly trans mount.
Can anyone give me any tips on how to replace that trans mount. Do I need to remove
the crossmember or can i just jack up the trans to r/r the mount
To Motor Mount Replacement
Old Jan 19, 2011 | 09:42 PM
  #98
riacreedon@gmail.com's Avatar
Default '70 small block motor mount replacement
Okay. 2x8 under oil pan is jacked up; weight is off the mounts; tranny mount bolts are loose, all (6) motor mount bolts are out. On passenger side , the mount has separated but won't come out. Why can't I remove the mounts? What's with 'self locking'? What am I missing here?? Thanks.
Old Jan 20, 2011 | 10:58 AM
  #99
Clint's C3's Avatar
Clint's C3
Are you sure you have all the bolts out? Did the one on the right side come out? Check all the bolt holes on the mount you removed and on the new mounts and double check the bolts are accounted for on the left side. If so it may just be stuck with years of accumulated crud. Carefully pry it off with a pry bar or large screwdriver. Good luck
Old Jan 20, 2011 | 05:27 PM
  #100
Thanks. Color me stupid. I missed the one bolt on both sides that's underneath. They're out now!
