Motor Mount Replacement
Old Jan 16, 2007 | 08:10 PM
  #41
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Originally Posted by Durango_boy
How the heck can you get under the car with it not jacked up? I have a 32 waist and I can't fit...maybe it's my chest.
It's a real tight squeeze, but I managed it for a few years. I couldn't crawl completely under, but just enough to reach most of the engine parts. Lots of times I had to exhale to slide in. I don't know if I could still do it because I've put on a lot of weight, but I can still snake my arms far enough under to reach the oil plug.
Old Jan 16, 2007 | 08:57 PM
  #42
Fevre's Avatar
Fevre
Originally Posted by shafrs3
I use poly on the drivers side (lift from torque) and rubber on the pass side. I'd think solid mounts would transmit more noise?
What I did, no more vibration than with both rubber but the eng barely moves when you get on it as seen by me with the hood off.
Old Jan 17, 2007 | 10:13 AM
  #43
77BuffaloVet's Avatar
77BuffaloVet
I am glad I didn't put the hood back on before I went for my first test ride with the new top end installed. The motor was torquing up on the drivers side a good couple of inches...time for new motor mounts here...I guess I am stuck on the same question, poly? or solid?
Old Jan 17, 2007 | 10:49 AM
  #44
mr nasty's Avatar
mr nasty
When I built the motor for my 70Z28 I put in new stock motor mounts and the one on the drivers side lasted about 2 months. I switched to Moroso solid mounts (because of necessity) on the engine and a polymount on the tranny. No more problems.
greg
Old Jan 17, 2007 | 10:51 AM
  #45
Durango_Boy's Avatar
Durango_Boy
greg
Any noise or vibration? Seems no one gets noise or vibration.
Old Jan 17, 2007 | 11:31 AM
  #46
Stoge's Avatar
Stoge
I bought a rubber mount at NAPA to replace the passenger side mount (I think it was the passenger side). It was the 3rd mount that I had purchased, the ones from AutoZone and O'Reilly looked like the original but didn't fit. The NAPA mount fit but looked totally different. Either way, no more fan rubbing the radiator shroud.
FWIW I didn't loosen the distro cap or the exhaust.
Old Jan 17, 2007 | 12:12 PM
  #47
BerniesVette's Avatar
BerniesVette
Solid mounts! Forget about ripping the others apart and don't worry about vibration. V8's don't vibrate enough to worry about it.
Bernie
Old Jan 17, 2007 | 01:43 PM
  #48
evalu8r's Avatar
evalu8r
I just replaced mine to solids, broke the rubbers right away with the new 383. Huge difference is response and feel. Adds another exclamation mark to the already wow Weee!!!!!!!!
Chris
Yea one other thing, I did dent my oil pan beatin my head on it wishing I had put the on before puttin the motor in.
Old Jan 17, 2007 | 01:55 PM
  #49
Clint's C3's Avatar
Clint's C3
You guys are starting to convince me to order up a set of solid mounts.
http://store.summitracing.com/partde...5&autoview=sku
Has anyone had an issue with solid mounts?
If not, I am pushing the buton......
Old Jan 17, 2007 | 02:04 PM
  #50
77BuffaloVet
I'm right behind you...any last thoughts?
Old Jan 17, 2007 | 04:28 PM
  #51
Durango_Boy
Here's one...
...drink up boys...it's garage time.
Old Jan 17, 2007 | 05:19 PM
  #52
Clint's C3's Avatar
Clint's C3
The mounts are on order. As soon as they show up it will be garage time.
Thanks all for the advice.
Old Jan 17, 2007 | 05:45 PM
  #53
sperkins's Avatar
sperkins
Dammit! Looks like I'll be spending another $60. You guys have got to stop this madness!!
Old Jan 17, 2007 | 06:30 PM
  #54
Durango_Boy
Yeah with that high HP 327 you'll need a solid mount. My 350 went through a pair of rubber mounts and it's not even a power house.
Old Jan 18, 2007 | 07:39 AM
  #55
BerniesVette
I'm glad to see you guys aren't a bunch of sissys wanting to make a luxury car out of a C3! Seriously, solids are the way to go. Just like an aluminum radiator; do it once and forget it!
Bernie
Old Jan 18, 2007 | 10:20 AM
  #56
Durango_Boy
Bernie
Crap...now I need an aluminum radiator.
Old Jan 18, 2007 | 10:32 AM
  #57
sperkins's Avatar
sperkins
Don't go there!!!
To Motor Mount Replacement
Old Jan 18, 2007 | 10:37 AM
  #58
Durango_Boy
Don't go there!!!
What? You need one too? C'mon...we'll do it together.
Old Jan 18, 2007 | 11:31 AM
  #59
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You don't have an aluminum radiator ? You should seriously consider installing one, way better than the stock rad....
Old Jan 18, 2007 | 11:48 AM
  #60
Durango_Boy
It's actually on my list as soon as I can afford it. Mine is leaking from the huge hole the hood put in it when the garage door hyper extended my hood.
