Dirty Engine Compartment
Old Jan 7, 2008 | 06:14 PM
mdbilger's Avatar
mdbilger
8th Gear
Default Dirty Engine Compartment
Hi,
My 1972 coupe which I have owned for 22 years is 98% original. For the last number of years the engine compartment has become dirty especially after breaking two original heater hoses. I had the car ready to go for a pressure cleaning but bulked on it since I have concerns the original labels, etc. will disappear and the process will cause electrical problems. Many car shows around central PA use a hood up format and not that I am embarassed about an original small block but I would like a cleaner engine area short of pulling the motor. Anyone have any ideas or solutions on this? I really don't like the harsh Gunk type products as they are not environmentally friendly but I have heard Simple Green can work? I still have a number of months until the snow melts. Thanks.
Mike B.
Old Jan 7, 2008 | 08:53 PM
Durango_Boy's Avatar
Durango_Boy
Just be careful when applying a cleaning agent, and use gentle tools like small brushes and rags. Purple Power and Simple Green work well.
Old Jan 7, 2008 | 08:57 PM
1981Z06Vette's Avatar
1981Z06Vette
Be careful with any cleaners around aluminum or printed labels. I'd use Simple Green, as it is less harsh. It will take more elbow grease, but your'e less likely to hurt anything.
Old Jan 7, 2008 | 09:15 PM
jbowles49's Avatar
jbowles49
Default simple green
Simple green is a great cleaner for automotive applications. You might want to look at a book titled Ultimate Auto Detailing for an exhaustive
look at engine detailing.
Good luck
J Bowles
Old Jan 8, 2008 | 07:45 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You could also cover up the labels with cut plastic pieces with tape around the edges. As stated, just be careful and take your time.
Old Jan 8, 2008 | 09:06 AM
bj1k's Avatar
bj1k
Default Professional detailer
Take it to a professional detailer , they know how to detail it with everything in place and do a professional job. Just be sure to mention your concerns about the labels. What part of Pa. are you from ? I do detailing here in my restoration shop as a sideline. My main specialty is metal restoration.
Old Jan 8, 2008 | 10:17 AM
GaryS's Avatar
GaryS
I use Simple Green, a soft parts brush, and a moderate water stream to clean my car. Using this approach, I have never ruined or damaged a label or original marking. Go slowly, use caution and you will have a nice engine bay.
No need for professionals when you can do this yourself. Don't spray the distributor (duh!) and you will be fine.
Old Jan 8, 2008 | 01:29 PM
7T1vette's Avatar
7T1vette
You can use Krylon semi-flat black spray paint to touch up shabby looking painted areas. Clean vacuum hoses with mineral spirits or paint thinner wiped on with a rag (do the thinner carefully an quickly to keep paint markings on the hoses and don't drop any on exterior paint). Follow hose cleaning with a polymer vinyl protectant...like Nu-Vinyl, etc; never use petroleum based item, as it will break down the hose material over time.
Old Jan 8, 2008 | 07:54 PM
bj1k's Avatar
bj1k
The number on that Krylon semi flat is 1613. I use it all the time in my shop. It is a perfect match to what the factory used on most cars and Krylon is the best aerosol on the market.
Old Jan 10, 2008 | 09:41 PM
mdbilger's Avatar
mdbilger
8th Gear
I live in Selinsgrove which is a far piece from Calbot. I wish you were closer since I would likely let you do the work. Around here they just want to blast it with high pressure. Thanks for the advice.
To Dirty Engine Compartment
