Anyone installed a Pypes system yet?
Old Mar 18, 2008 | 01:44 PM
  #81
NTMMD8R's Avatar
NTMMD8R
mzmgb
I am also having trouble with my Pypes system..... It appears to me that with the left side mid pipe (the one between the X and the muffler) is causing my muffler to reach about 2" shorter than the right side. I believe you were talking about the same thing earlier with these 2 pipes being completely different in length, etc.... Not only does the left side come up short, it appears to push the muffler in an upward incline compared to the right. Any advice?
Old Mar 18, 2008 | 04:15 PM
  #82
L82shark's Avatar
L82shark
St. Jude Donor '08
Originally Posted by cduemig
I got mine from Pypes a few weeks ago. It's the polished version. The x-pipe is 409 stainless steel (hard to polish) and the rest is 304 polished stainless. Mine didn't bolt up quite right. I had the collector extenders fabbed to the x-pipe, but then on the back one side fit fine, then the other was a little off. I had to force it in the right spot. I'm gonna have to take it to a performance shop to adjust the pipes and weld it up. I also have an issue where the x-pipe rattles in the crossmember holes. I used a welding blanket to cut pieces to stop the rattle. It also sits a little low causing scraping on speed bumps.
Overall, I wish I had just paid a custom fabricator to do the work...
I ordered a set of dual hangers from somewhere, these are the type that dont have the rubber bushings and hard clamp to the pipe. Kind of an "L" shape that that regular type exhaust clamp locks on to. I bolted them on to the rear of the crossmember on each side of the exhaust holes and ran a clamp around the pipe and pulled them up tight. Now the pipes are centered in the holes and cant clang around. Tossed the old factory hanger out from under the tranny mount. Seemed like once I locked the xpipe down everything from there on back went together pretty smooth. Pypes really does need to fab up some type of collector pipe so you get a complete system. And I am still waiting on the two additional exhaust hangers they were going to get right out to me.....
Old Mar 18, 2008 | 10:11 PM
  #83
mzmgb's Avatar
mzmgb
Originally Posted by NTMMD8R
mzmgb
I made a 1-1/2" spacer that I mounted to the crossmember and then I secured the hanger to that. This pointed the muffler in a much better angle and also helped to align the exit pipe with the opening in the rear panel. I cut off about 1" off the right side mid pipe in order to better align the mufflers. They both exit approximately at the same point.
Old Mar 18, 2008 | 11:02 PM
  #84
NTMMD8R's Avatar
NTMMD8R
Thank you so much. When I looked at you pictures, I was just dumb founded on how you got your mufflers to line up so nice and even. I'm affraid some of our forum friends might be in for a big suprise when they go to put on their spare tire carrier. I have wrestled that darn then for hours and never could get the dang things where they need to be. I was wondering if they had some guys named Sudoku and Rubik design these things, and if you get everything just so, and the moon is full, and the tide is at the right faze, that a little fairy would wave it's wand and poof! In reality......Those two items you listed make complete sense.....sometimes I just need a little push in the right direction. As far as Pypes goes.....shame shame...sloppy sloppy! I believe a major refund should be in store for those of us guinea pigs that expected an exact fit and a quality product, and ended up with sore muscles and a headache. Buyer Beware.
Old Mar 19, 2008 | 08:15 AM
  #85
mzmgb's Avatar
mzmgb
Amen.
You have to have the tire carrier in place when you do the final fit.
The sales rep asked me for some pictures when I was done. I offered them some suggestions, I'm not sure if they took me very seriously.
This can be a great system. I am happy with MY results.
I hope they realize, a one car protoype does not make for a release-ready product.
Old Mar 19, 2008 | 08:26 AM
  #86
L82shark's Avatar
L82shark
St. Jude Donor '08
Amen.
I couldnt have said it better, I am happy with the system now that it is on, but there are some tweaks they need to do with tolerances and add that friggin collector pipe to the set!
Old Mar 21, 2008 | 01:21 PM
  #87
Ccass's Avatar
0Ccass
Former Vendor
We just noticed this topic and will review it further but at first read, it appears that the main complaint is the missing piece of pipe between the headers and our system. I guess we should have called the system 'crossmember back' as most other exhaust companies do. I also noticed, several different suggestions for improvement. Notice I said 'different'. That's why we terminated the system where we did. Manifold customers don't need the extra pipes. Each header company makes their headers terminate in a different spot and at a different angle. We couldn't possibly design let alone include collectors for all the possible combinations.
Guys, I'm not saying that we can't improve on the product but it is still the ONLY 2.5" mandrel bent system on the market that includes an X-pipe to boot. You're paying for a niche product and I assume your paying because you see the performance advantages of such a system. The downside is that you have a little more work to do to finish it.
I will address a couple of other problem areas after I have had a chance to read through this again.
Don't get me wrong, we appreciate the feedback. Keep it coming but don't bury us here.
Old Mar 21, 2008 | 07:44 PM
  #88
mzmgb's Avatar
mzmgb
Ccass,
I don't believe we have been "trashing" or "burying" Pypes. I think most of us have been happy with the system.
Some suggetions, others may have their opinions.
-Fix the ad to state that there are extension / collector pipes available to bridge the gap between the header collector and the beginning of your system. At least the customer is not surprised by the "gap".
-Make the left side mid pipe the same as the right side, in length, bends and hanger rod length. The vette is symmetrical and this would be the greatest improvement you could incorporate. I could have installed the system in 2-3 hours not 2-3 days. Most of the time was working on fabricating a spacer to force the left muffler to hang lower and end at about the distance from the rear.
-Make sure the correct number of hanger blocks are shipped. (easy)
-Either remove the "polished" tips from the site ad or ship them with the system.
I love the sound. So do my neighbors. Not my wife.
Thanks for reading our posts.
mike z
Old Mar 21, 2008 | 09:00 PM
  #89
L82shark's Avatar
L82shark
St. Jude Donor '08
Ccass,
I agree with mzmgb, I dont think us guys who bought the system have been trashing you. There are some quirks in the system that most of us worked through, but it seems we are mechanically inclined and were able to do so. Someone who isnt and buys a system thinking its a direct bolt on would have some issues. I am extremely pleased with the system overall and as you stated, I wouldnt be able to find a ss mandrel bent system for the price anywhere else. As far as connecting to the headers, another two pieces of pipe approximately 16" long and offset slightly in the center would allow it to connect to almost any header system, simply by rotating the said piece of pipe until it centered on the header and then cutting it off and welding the collector on. Below is a pic of the pieces I had fabbed up. For looks and sound it gets a 10 in my book, for installation, it gets a 7.5. And yes, I got the hangers! we are hooked up and ready to go!!!
Old Mar 22, 2008 | 10:30 AM
  #90
NTMMD8R's Avatar
NTMMD8R
Ccass,
Ditto, Ditto....
I was expecting the "gap" between the X pipe and the headers. The 2 month wait to get them???..that's life. To get the finished product missing hanger blocks and not having polished tips...as stated...OUCH! To wait 2 months, recieve missing, unfinished parts, and then have the pipes behind the x pipe not line up regardless of what you do...YOU"VE GOT TO BE KIDDING! I now have sore muscles, waisted time, and a general bad taste in my mouth about products that come from PA. Thanks to mzmgb's advice, I'm going to go out this morning and do some chopping and spacing and hope it all works out.
Old Mar 22, 2008 | 01:17 PM
  #91
Fevre's Avatar
Fevre
Originally Posted by L82shark
Why in the world would you fork out big $ for a mandrel bent system with X pipe and put those up stream to choke your eng? Get rid of those and get some of these:
http://store.summitracing.com/partde...0&autoview=sku
They are only $22, I cut them in the middle of the jog section and added a little extra length to the jog to line with the crossmember holes. Sorry no pics
Might be a nice throw in with the kit to help the bridge the gap, assume if Summit can sell them for $22 they should cost half that to manufucture or buy from Hedman
Old Mar 22, 2008 | 09:21 PM
  #92
L82shark's Avatar
L82shark
St. Jude Donor '08
Fevre, thank you for the assist, my main concern when I did this was just to have something on there to get it to a muffler shop where I could have something fabbed up, I was po'd over the compression bends myself. I had looked at Jegs and thought I had looked at summit. Thanks!
Old Mar 22, 2008 | 09:23 PM
  #93
Fevre's Avatar
Fevre
Glad to help a brother out, nothing worse than EASY hp left on table.
Old Mar 23, 2008 | 01:18 AM
  #94
Silver00V6Camaro's Avatar
Silver00V6Camaro
the hedman header extensions will not fit if you have a th400 car. I know this for a fact because i tried them and they either hit the floor or the tranny pan.
Old Mar 23, 2008 | 11:16 AM
  #95
apester4u's Avatar
apester4u
Does anyone know what kind of headers were on the Pypes test C3? I'm looking to get headers and exhaust system at the same time, so it seems to make sense to use the exact same setup as Pypes. Should help eliminate the gap issues they attribute to all of the different header sizes and shapes.
Old Mar 23, 2008 | 11:35 AM
  #96
Silver00V6Camaro
stock manifolds
Old Mar 23, 2008 | 12:31 PM
  #97
L82shark's Avatar
L82shark
St. Jude Donor '08
They will not match up to any type header I know of. They are designed so you can fab up a pipe to fit your particular header. They end just forward of the crossmember. Pypes does sell an extension which will allow them to mate up with a stock manifold though, but I havent tried it as I have headers.
To Anyone installed a Pypes system yet?
Old Mar 23, 2008 | 04:46 PM
  #98
jd1a's Avatar
jd1a
Must be me, I would think Pypes would supply a complete kit for the money they ask. Not going to the local shop to buy more parts to finish the install.
Old Mar 27, 2008 | 11:48 AM
  #99
Ccass's Avatar
0Ccass
Former Vendor
I guess you missed my explanation above..... "I guess we should have called the system 'crossmember back' as most other exhaust companies do. I also noticed, several different suggestions for improvement. Notice I said 'different'. That's why we terminated the system where we did. Manifold customers don't need the extra pipes. Each header company makes their headers terminate in a different spot and at a different angle. We couldn't possibly design let alone include collectors for all the possible combinations."
Old Mar 27, 2008 | 12:13 PM
  #100
Ccass's Avatar
0Ccass
Former Vendor
Ccass,
The polished tips are suppose to be a part of the system. One production run was made with the non polished tips. Owners of 68-73 cars don't use the tips. However, Anyone else who wants the polished tips, should just call customer service and we'll send you a pair. [/b]
mike z
I've answered the points below in bold.
Forums can be a very powerful tool to get a message out but when comments are made likes '2-3 days to install', 'a major refund should be in order', 'I can't understand why Pypes would not include pipes to connect to our headers' etc most readers only remember one thing....Pypes=problems. And that is an unfair conclusion. I have explained why below.
Agreed, already done on our website (Summit and Jeg's have been notified too.)
I'm pretty sure there is something about the undercarriage of this model that caused us to make the system asymetrical. Besides the asymetrical pipes should not require any additional installation time. Were your pipes labeled LH and RH? If not, maybe we could add labels to make it easier. If yes, then maybe our instructions should be easier because the average installation time here is about 2-3 hours
Absolutely, We have changed the error in our BOM system
mike
