Vacuum filter question
Old Sep 5, 2008 | 07:39 PM
demonx's Avatar
demonx
Default Vacuum filter question
I'm in the middle of replacing all my vacuum hoses and discovered this is missing and the hose runs straight through with no filter.
Is this an issue?
What is the purpose of this filter and should I track one down or reinstall without?
Old Sep 5, 2008 | 10:56 PM
tobyte1's Avatar
tobyte1
Originally Posted by Durango_Boy
The filter is just there to help keep oil vapors from getting into the vacuum operated accessories, where it can cause damage over time.
Better to have a filter but the system will work without it.
I thought just the opposite. That the filter was there to prevent trash(busted actuator, bad hose) from getting sucked into the engine. It is vacuum, not pressure.
Old Sep 5, 2008 | 11:04 PM
...Roger...'s Avatar
...Roger...
Is this an issue?
Demonx just a note about this vacuum drawing....its wrong...the hoses at the headlight switch and the headlight overide are reversed.
edit- here is a link to Zip's corrected diagram.http://www.zip-products.com/Zip/prod...45B882AA1F4055
Old Sep 6, 2008 | 01:28 AM
demonx's Avatar
demonx
Thanks for the heads up ... I'll have to double check as the diagramI upload is not the one I have down the shed. I've been working off the printout I got from Willcox with the hoses, but it pays to doublecheck.
As far as the filter, for now I'll leave it without but I'll be sure to add one to the next parts order I place.
Cheers
Old Sep 6, 2008 | 05:26 AM
7T1vette's Avatar
7T1vette
The filter is to keep bits of trash (chunks of brittle hose, debris, etc.) from getting ingested into the engine/valves. With 30+ year old equipment, who knows what will break loose next? They're cheap...and good "insurance".
Old Sep 6, 2008 | 09:03 AM
Durango_Boy's Avatar
Durango_Boy
Okay, I stand corrected.
Old Sep 6, 2008 | 10:13 AM
...Roger...
Not so fast......I was always under the understanding that the filter was for the protection of the 3 port Trico check valve.I thought it kept fuel vapors from rising into the check valve and ruining it "after" the engine was shut off.
As far as debris getting into the intake manifold...it would have to be very tiny flecks if it could make its way through the check valve.
One other thought I seem to remember Paragon recommending buying the filter when you bought one of their new check valves to protect the new valve.In their catalogs they had little helpful hints about things like this.
Old Sep 6, 2008 | 10:31 AM
pws69's Avatar
pws69
Why does anyone think that there is a SINGLE purpose for this filter??? It serves all of the functions mentioned above quite well!
You should use one!
Old Sep 6, 2008 | 10:49 AM
...Roger...
You should use one!
Good Point
Old Sep 6, 2008 | 10:50 AM
rponfick's Avatar
rponfick
I thought I remember something about it being a one-way check valve also, to maintain vacuum for a while when the engine is shut down. But, I could be mistaken since I am getting older.
Ralph.
Old Sep 6, 2008 | 11:06 AM
schmegeggie's Avatar
schmegeggie
Ralph.
Nope, I just replaced mine. It is nothing more that a filter. You'd be surprised how much crap gets sucked into the system when there is a leak somewhere.
Old Sep 6, 2008 | 11:16 AM
Alan 71's Avatar
Alan 71
There is a check valve just beyond the filter. It also splits the vacuum supply to the dash controls and the vacuum storage tank.
I think it's a good idea to keep the filter. If GM didn't think it was necessary they'd have saved the couple of $ per car, you can be sure.
Regards,
Alan
Old Sep 6, 2008 | 11:56 AM
SH-60B's Avatar
SH-60B
That's one trick filter that lets air go one way and "filters" out fuel vapors the other way.
Old Sep 6, 2008 | 12:50 PM
...Roger...
Your right...wonder whats inside???
Old Sep 6, 2008 | 01:00 PM
stingr69's Avatar
stingr69
Regards,
Alan
If it was not a good item to have, GM would not have bought them and installed them.
The general has WAY more collective engineering experience than all of us guessers combined. It does not hurt efficency or performance so go ahead and use one. ...Unless your name is "Bubba"
-Mark.
Old Sep 7, 2008 | 03:04 PM
...Roger...
Cheers
I have not seen the diagram from Wilcox but I would bet coming from him its correct.I have a corrected diagram for a later model that shows the area at the headlight switch and the pulldown if you need it.The one I linked you to was a little small.(not that size matters)
To Vacuum filter question
