C3 LSx Conversion Directory
Old Feb 15, 2009 | 10:13 PM
catchme76's Avatar
catchme76
Year of Corvette: 1976
Engine: 5.3LM4(aluminum block), LS6 intake, C5 Batwing Oil Pan
Engine Mounts: Carshop Inc adapters w/Energy Suspension mounts
Engine Accessories: Fbody PS,Fbody Alt. bracket w/Trailblazer Altenator, Hot Rod Air Sanden AC Comp
Waterpump: Stock/Aftermarket: Fbody w/modified heater fittings and CSR waterneck
Manual Throttle/Drive by Wire: Drive by Wire
Transmission: Upgraded LS1 T56
Crossmember (stock/modified/aftermarket): Modified Bowtie Overdrives 700R4 Crossmember
Exhaust Manifolds/Headers: Stainless Steel Long Tube Hooker Super Comps. 1-3/4" w/3" Collectors
Wiring Harness (modified stock/aftermarket): Speartech Modified 5.3LM4 Harness w/LS6 injector pigtails
Radiatior/Fan: Griffin 32" with LS1 fbody Fans and 2 TCI Push or Pull fans for AC Condensor
Fuel Pump/Lines/tank:Walbro inline w/C5 regulator and 16Gallon Fuel cell with sump.
Steering System: Homemade Grand Am Rack
Misc info: I have put 8500 miles on the car since May 2nd, 2009
Contact info:
Old Mar 23, 2009 | 01:00 PM
Hotrod406's Avatar
Hotrod406
Year of Corvette: 1971
Engine: 2001 6.0 LQ4
Engine Mounts: Custom, stock 4sp trans in stock location.
Engine Accessories: Custom, based on truck parts
Waterpump: Stock/Aftermarket: Modified truck
Manual Throttle/Drive by Wire: Manual
Transmission: Stock 4sp
Crossmember (stock/modified/aftermarket): Stock
Exhaust Manifolds/Headers: Custom
Wiring Harness (modified stock/aftermarket): Modified stock
Radiatior/Fan: Griffin rad, custom fan shroud with 2 11" fans. -20 lines
Fuel Pump/Lines/tank: Aeromotive A1000 pump -08 feed -06 return. Stock tank
Steering System: Stock power
Misc info:
Contact info:Tim Coeling t_coel at yahoo.com
Old Mar 28, 2009 | 11:28 AM
corvettelars's Avatar
corvettelars
2nd Gear
Year of Corvette: 1972
Engine:LS7 2007
Engine Mounts: custom
Engine Accessories: stock Z06 starter, generator, power pump, dry sump tank from Peterson racing
Waterpump: Stock/Aftermarket: stock Z06
Manual Throttle/Drive by Wire: drive by wire
Transmission: TKO 600 , 5 speed with Lakewood bell housing, stock Z06 clutch
Exhaust Manifolds/Headers:Custom, fit LS7 / C3
Wiring Harness (modified stock/aftermarket): Custom made
Radiatior/Fan: Aluminium radiator with 15" el. fan
Fuel Pump/Lines/tank: Aeromotive pump, std new tank and lines
Steering System: Consept one power steering
Misc info: works wery well
Contact info:
Old Apr 1, 2009 | 09:12 AM
PatsLs1vette's Avatar
PatsLs1vette
Year of Corvette:1973
Engine:2004 ls1 ls6 intake 5.3 pan modified
Engine Mounts:vetteworks
Engine Accessories:fbody alt.
Waterpump: Stock/Aftermarket:stock c5
Manual Throttle/Drive by Wire:manual
Transmission:700r4
Crossmember (stock/modified/aftermarket):stock with modified plate
Exhaust Manifolds/Headers:hooker sidepipes modified to ls1 flanges,custom augger style mufflers inside
Wiring Harness (modified stock/aftermarket):99 fbody modified by self
Radiatior/Fan:dual flexalites
Fuel Pump/Lines/tank:walbro 255 intank
Steering System:manual
Misc info:
Old Apr 27, 2009 | 04:43 PM
myoriginal77's Avatar
myoriginal77
Year of Corvette: 1977 - My original car I bought new in '77
Engine: 2004 C5 LS 1 - F body pan
Engine Mounts: Vette Works
Engine Accessories: Superpowers AC mount (nice work & nice guy)
Waterpump: Stock/Aftermarket: Stock
Transmission: T56 / reworked w/ steel forks, factory Hurst Shifter from 1999 Camaro.
Crossmember (stock/modified/aftermarket): Custom made by SRIII MotorSports - New Lenox, IL -- Tell Mike I sent you -
Exhaust Manifolds/Headers: Stock with chambered exhaust.
Wiring Harness (modified stock/aftermarket): Modified by those nice people in Indiana, and then by my friend Rich (the lizard) to the needs of the C3.
Radiatior/Fan: Stock C5 radiator and fans, modified to fit the stock core support, Stock upper hose from 2004 C5, lower picked off the rack at the local NAPA - Thanks guys !
Fuel Pump/Lines/tank: Walbro in line. This after much discussion (thanks to forum members.) I'm planning on a Bonneville run and decided external would be easier to fix. I'm using a new 1973 tank which has the bottom feed, I ran the tank outlet to the pump, to a C5 regulator, then to the stock line up front. Bypass from the regulator to the return line on the tank. Works GREAT !
Steering System: Stock - modified lines
Misc info: As per usual, too long in progress, losing parts and buying them again, but it's getting there. Running great now after a few glitches. Avatar shows it at the Bonneville Salt Flats.
Contact info: Frank@itpphoto.com Cell; 630-430-2487
Special THANKS to forum members 70 LS1 & Superpowers for the help, couldn't be where I am now without you !
Old Jul 12, 2009 | 02:41 PM
delbert62's Avatar
delbert62
Engine:2000 5.3 truck, LS6 intake, C5 Batwing Oil Pan
Engine Mounts: I built my own, Blueprint on LS1Tech.com(1" farther set back)
Engine Accessories: 2000 Truck, slightly modified, no A/C
Waterpump: Stock truck, relocated heater hoses straight down, drilled and tapped top for steam tube, Made my own straight thermostat housing
Manual Throttle/Drive by Wire:Manual throttle, custom "bellcrank" linkage to accomodate TV cable for trans
Transmission: TH350, Shift Kit, 2800 stall convertor
Crossmember (stock/modified/aftermarket): stock
Exhaust Manifolds/Headers: 2002 corvette short tube headers, 2 1/2 outlet to sideipes
Wiring Harness (modified stock/aftermarket): Modified stock,1998 PCM
Radiatior/Fan: Stock radiator, 1 16" fan
Steering System:Stock power steering, Custom pressure hose
Misc info:This was a budget swap. By using the stock trans, Ebay, and my loal salvage yards, I was able to do the entire swap(including sidepipes and headers) for just over $1200. It took about 3 months to gather up parts, and three weeks to change the motor.
Contact info:delbert62@mchsi.com
Old Jul 24, 2009 | 01:47 PM
DaveC3R's Avatar
DaveC3R
Cruising
Year of Corvette: 1979
Engine: 1998 LS1 from Camaro SS
Engine Mounts: Edelbrock #6701
Engine Accessories: I used a new Camaro balancer, and waterpump, a KWIK Performance bracket system to mount an alternator and power steering pump. AC will be added later using KWIK brackets. Alternator was on my old Gen I Chevy engine, a PowerMaster 140amp one that I did not want to part with... instead of getting a late model alternator I found that the PowerMaster would mount by simply elongating the uppper mounting hole a bit... works like a champ. Power steering pump was not so easy, I used a Detroit Speed pump (bought it with reservoir, duh... returned and got remote reservoir pump) with a -10 suction port and a Detroit Speed hard line for pressure with -6 male port... a remote Jegs aluminium reservoir... and a cool fined Darale power steering cooler.
Waterpump: Stock/Aftermarket: Stock water pump modified by plugging both heater hose inlet and outlet and drilling and tapping two new ports... both have -8 male ports now and I used braided steel heater hoses. Also installed CSR straight aluminium water neck with SKO 160 degree thermostat.
Manual Throttle/Drive by Wire: Carburetor!! Demon 650 mechanical secondaries... Edelbrock Intake. Runs great, two pedal pumps to start it, idles like a fuel injected car, got 22 mpg on recent 800 mile road trip. And lots of power.
Transmission: Tremec TKO 5 speed, conversion kit from Kiesler with hydraulic throw out. Love my Tremec.
Crossmember (stock/modified/aftermarket): Stock with bolt on bracket from Kiesler.
Exhaust Manifolds/Headers: Hooker shorty headers, block huggers. Summit #HOK-2313HKR
Hi Guys...
I had a request to give some more info on the headers I used for the 79 GrandSport...
Manufacturer... Hooker Headers
Part Number... HOK-2313HKR
Supplier/Cost... SummitRacing.com, current price $389.95
Features... Beautiful ceramic coating looks like chrome but much more durable, thick flanges to avoid warpage and leaks, 1 5/8" tubes, 2 1/2" collectors, comes with hardware, gaskets, and reducers
Fit and Finish... I was putting in an LS1 that did not have a stock starter and I applied the high torque mini starter from Summit (#SUM-820320) that can be 'clocked' to various positions and it fits nicely with the headers.
My Rating on the part... ***** (5 stars)... these things look great, fit easily without modification on this swap, and the exhaust sounds great. I've been running around since June 1 with a dual exhaust, but I just added an X pipe this weekend and it sounds better and runs smoother. Bye the way, the mufflers are Supertrapp, which look ok, but are totally tunable from pretty quiet to wide open!
I'll add pics later.
Wiring Harness (modified stock/aftermarket): MSD 6010 controller... no complicated harness or wiring. Pluged in the cam sensor, the crank sensor, the coils, a map sensor, and power, ground, and tach... that was it. It's computer programable for whatever timing curve you want, but comes with 'pills' that are present... plugged one in and haven't screwed with it since. The controller has a built in rev limiter, a low level rev limiter for when I'm using linelock, and it can take up to 10 degrees of timing out for my nitrous bottle. Nitrous is not hooked up yet, but this will make living with it much easier.
Radiatior/Fan: 4 core Jegs rad, Flex-a-lite dual electric fans... never gets over 180 degrees.
Fuel Pump/Lines/tank: Stock fuel tank, Edelbrock electric fuel pump, braided steel pressure and return lines, Aeromotive regulator with bypass.
Steering System: Steeroids rack and pinion.
Misc info: Paint scheme lifted from 96 GrandSport with lots of clear. Intro Mullholand 17" wheels. Vette Brakes and Products suspension system with front and rear transverse fiberglass springs and fabricated a arms and trailing arms. Baer 6 piston calipers on big crossdrilled rotors.
Contact info: davec3r@gmail.com
Last edited by DaveC3R; Jul 25, 2009 at 10:33 PM. Reason: Request from Superpowers, more info on headers
Old Aug 10, 2009 | 02:04 AM
86atc250r's Avatar
86atc250r
Engine: 2002 Firebird LS1 (LS6 block), mild cam (224/228 @ .050 113+1 LSA .595), stock heads, etc. Speed Density tune (removed MAF)
Engine Mounts: Generic - Vetteworks style (not 1" back)
Engine Accessories: F-body minus A/C - will add that back at a later time
Waterpump: Stock/Aftermarket: Stock F-body, modified heater hose locations -- modified stock water inlet (CSR has engineering problems IMHO)
Manual Throttle/Drive by Wire: Manual throttle body
Transmission: 4L60E w/3200 stall Vigilante converter
Rear End Gear: 3.55
Crossmember (stock/modified/aftermarket): Stock w/Vettworks adapter for trans. Lowered crossmember 1/2" for header/collector to floorboard clearance - no noticeable driveline vibes
Exhaust Manifolds/Headers: Kook's stainless steel long tube F-body - 1 3/4 primaries stepped to 1 7/8 -- 3.5" collectors.
Wiring Harness (modified stock/aftermarket): Modified stock - relocated computer to left side of car.
Radiatior/Fan: LT1 F-body dual electrics wired for two speed operation
Fuel Pump/Lines/tank: In tank pump using 82 sender & late model truck pump, stock lines, C5 regulator/filter.
Steering System: Stock - will be building my own rack setup when time allows
Misc info: Modified original speedo, is now electric instead of cable driven, 2.5" all tig welded, mandrel bent, stainless exhaust, x-pipe, & mufflers. Wideband O2 sensor integrated into the harness. LED taillights (LED bulbs, OEM lenses), HID low beam headlights, HP Tuners for dialing things in.
Contact info: PM me
Old Aug 16, 2009 | 09:22 PM
jraddington's Avatar
jraddington
Default Ls1!!!
Year of Corvette: 1974 Coupe
Engine: LS1 from a 2002 Camaro SS
Engine Mounts: Vetteworks
Engine Accessories: Stock F-body PS, ALT. Street & Performance AC bracket, belt, compressor.
Waterpump: Stock/Aftermarket:Stock with drilled/tapped 90* heater hose barbs.
Manual Throttle/Drive by Wire: Manual throttle, Lokar cable kit
Transmission: 4L60E from the 2002 Camaro SS
Crossmember (stock/modified/aftermarket): Modified 74 vette removable crossmember.
Exhaust Manifolds/Headers: Patriot ceramic coated block hugger headers.
Wiring Harness (modified stock/aftermarket): Modified factory harness.
Radiatior/Fan: Aluminum Dewitts radiator, dual electric fans controlled by factory computer.
Fuel Pump/Lines/tank: Factory tank, electric pump and stainless AN hose
Steering System: Stock camaro pump ( with cooler removed ) to stock 74 vette system. I am after a different setup with AN lines, any help???
Misc info: Tuned with HP Tuners, all emissions equipment removed, Aluminum driveshaft from a Firehawk ( shortened ), Vintage Air AC system, Custom Autosound stereo.
Contact info: jraddington@gmail.com
Old Sep 1, 2009 | 09:28 PM
Scooter70's Avatar
Scooter70
Year of Corvette:1970
Engine:2001 LS1, LS6 intake, F-body pan, TR224/224 cam
Engine Mounts: Custom designed and fabricated by me.
Engine Accessories: F-body alternator. No PS.
Waterpump: F-body
Transmission: F-body T56 with Pro 5.0 shifter modified to fit original console
Crossmember (stock/modified/aftermarket): Stock crossmember with custom bracket (by me)
Exhaust Manifolds/Headers:F-body manifolds mated to 2.5" MidAmerica chambered exhaust system
Wiring Harness (modified stock/aftermarket): 2001 Fbody modified
Radiatior/Fan: Summit 31x19 rad w/dual flexalites
Fuel Pump/Lines/tank: Walbro 255 external pump, 1999+ Corvette filter/regularor, stock 1970 fuel tank
Steering System: Manual
Misc info: Featured in AutoTuning Swait magazine November 2008. See sig for my site.
Old Oct 8, 2009 | 02:08 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
World Castings now has a Motown LS block. From what I understand it is a conventional Gen 1 "style" block that allows the use of Gen 1 components but you can put LS heads on it.
I am thinking about doing one with LS7 heads and a carb You can use a 6.125 inch rod with 4.125 in. bore for a monster that will make an easy 700HP. I don't know all the details but I am sure some will want to go this route
Old Oct 9, 2009 | 10:42 AM
SUPERPOWERS's Avatar
SUPERPOWERS
Yep, I just fail to see the cost benefit. You can't reuse your headers or intake. And you don't have the benefit of the 6 bolt mains. You can reuse your crank and rods but you need LS pistons. I guess one of the biggest assets is that you can reuse your accessories.
The Motown block is $2100 the LS7 block is $2500
the jury is still out for me.
here is some more info
http://www.theengineshop.com/product...pdf_file-6.pdf
Old Oct 26, 2009 | 12:43 PM
  #33
patbull's Avatar
patbull
Default side pipe
hi am restoring this 1970 coupe and got the LS1, i would like to know
if it possible to put it side pipe
i check whit melross thy make the headers for the swap
i ask them thy told me thy can leav it whit no conector
then built it up from there
is there a better way more simple way to do that
i got this on one tread
modified SS Hooker sidepipes with LS1 flanges
any info would be very nice
thanks for your time
pat
Old Oct 26, 2009 | 01:29 PM
  #34
SUPERPOWERS
I have a set in development right now. Coming soon.
Old Oct 26, 2009 | 08:29 PM
  #35
mikey's Avatar
mikey
several of s have modified hooker side pipes for SBC to fit the LS flange.. mine was a real re-routing mess on the driver's side to make room for the original Z-bar setup.. worked, came out nice, but don't know if i'd go through all that again! would either just go with a shorty header and single pipe out each side, more like the original side pipe cars, or maybe switch over to hydraulic t.o. bearing to not have to re-route so much header pipe around the z-bar. probably option 1 though, because i didn't want to have to reinforce the firewall for a hydraulic clutch..
james, will your headers in development work w/z-bar?
Old Oct 27, 2009 | 01:53 AM
  #36
SUPERPOWERS
Josh
Mikey, I am actually using Big Block headers for the development. The big block have equal distance primary c-c like the LS motors. All I should need to do is get an LS flange and then squeeze the primaries in a tad. They should be ready very soon, and then ready for market soon after that.
Old Oct 27, 2009 | 07:06 AM
  #37
patbull's Avatar
patbull
maybe you already know but you can check it out for the z bar
http://www.speedhound.com/LSX%20swap/C3Zbar.html
check whit keisler for the hydraulic clutch
http://www.keislerauto.com/vmchk/gm/...-products.html
superpowers how long it will take you to put it on the market
i ave 1968,1970,2-1972 that i ave to put side pipe but tow of them got
sriiimotorsport frame
the 1968 convt am putting the LS9 in it
thank for your time keep use informe
pat
To C3 LSx Conversion Directory
Old Oct 27, 2009 | 11:11 AM
  #38
SUPERPOWERS
Trey at Speedhound is a good friend.
I make hydraulic clutch masters.
Should be in a few months for release.
And holy crap, nice stable!!
Old Oct 27, 2009 | 12:00 PM
  #39
patbull's Avatar
patbull
i ave my company that restore corvette
my website should be up in about 2 week
i own the 1970 the others are pepole that want them done during the winter
i just ave one frame done by mike at sriii it very nice it all c6 suspention whit 9 IRS
wiilwood 14 inch disk
if you want i can cary your stuff on my web site
all be the fisrt in canada to ave those side pipe
am triying to put the pic of the frame inside my post but i cant any tip will be nice
thanks
pat
Old Oct 27, 2009 | 12:23 PM
  #40
patbull's Avatar
patbull
click on view my puplic profile
you can see the frame
